airkooledchris Samba Member
Joined: January 25, 2005 Posts: 2639 Location: Where the pacific ocean meets the redwood forest
Posted: Thu Oct 21, 2010 8:10 am Post subject: ba6 recirculation fan importance |
I am nearly 100% done pulling the BA6 from my 81 Vanagon.
had to drop the gas tank to get the wire loom out completely in tact, but did manage to do so.
I am *thinking* about putting this into my 79 bay, but one thing I know im going to have trouble with is the recirculation fan. I haven't pulled it completely from the Vanagon yet as there is a ton of connections for it to splice the cabin air back into the heater boxes and
A. the connections/etc aren't going to be the same for the bay, so id have to fab something both to route into the heater boxes on the baywindow
B. id have to cut and make a port for the fan to draw in the cabin air from the bay
C. the recirculation fan and its connections are so rusted and hardened in place currently that im going to have to cut the brackets off with a small saw just to get them out.
I want to say that this BA6 will work well enough just drawing the incoming air from the stock heater boxes, but will not using that recirculation fan cause any running issues with the BA6 in terms of the wiring?
just not sure if ill need to connect it to 'something' so it at least thinks its still hooked up in order for the rest of it to work properly.
lots of other potential headaches im sure with retrofitting it into the bay, but I did carefully pull every other bit of this system out from the Vanagon.
the parts ill have to fab will be a switch to turn it on, instead of the heater switch-ground that it normally uses and rubber mounting points to connect it to the underside of the body.
any tips, suggestions, feedback or tomfoolery welcomed. _________________
metahacker wrote: |
... i would say that, if it's an option, (edited) not listen to any forum pessimism.. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 45342 Location: Surrey B.C. Canada, Land of the giant flying moose!
Posted: Thu Oct 21, 2010 8:21 am Post subject: |
You need the fan, not only is the engine fan output not enough the heater will likely overheat and shut off due to lack of flow. Besides half the fun of a gas heater is being able to turn it on and warm up the inside of the bus before you even start the engine  _________________ Rust NEVER sleeps and stock never goes out of style.
Posted: Thu Oct 21, 2010 8:50 am Post subject: |
ok, so it definitely needs it for the airflow, I hadn't considered that aspect.
I suppose it doesn't HAVE to be drawn in from the cabin, but it needs the flow of this fan in addition to the one mounted above the motor in the engine bay.
fwiw it's the exact same fan, seemingly, as the one for the stock baywindow heat, just mounted a few feet closer to the heater.
is the idea that it needs the both of them, or just that I would need this second one (who's original idea is to pull in cabin air) for when I run the heater without the bus running, where that stock heater fan wouldn't be running?
since they are the same fan as one another, I wonder, and assume I cannot, if I could just wire the stock heating fan up to be triggered on when the BA6 wants it - instead of it only kicking on when the stock heat is running. _________________
metahacker wrote: |
Posted: Thu Oct 21, 2010 10:45 am Post subject: |
Wellll...... I guess that would work..... your anti return flaps in the shroud would have to be in 100% perfect working order. Already slightly warm air from inside the bus is alot easier to heat and doesn't stink (like engine anyways), drawing from inside also ensures a good flow even if all the windows are rolled up and the door vents are closed. _________________ Rust NEVER sleeps and stock never goes out of style.
Posted: Thu Oct 21, 2010 10:51 am Post subject: |
the stock heat in my 79 actually works pretty darn well, especially as to the 'smell' factor. I know what you mean though, my old 75 and 76 both had working heat, but it always had that stench of exhaust to it.
I kinda sorta figured it wouldn't be an smart, albeit easier, thing to bypass in the swap. ill have to see about modifying it to tie into the baywindow system or get the correct baywindow parts for this. just in case ill pull everything else from the van in case I can adapt it. _________________
metahacker wrote: |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 18333 Location: Oklahoma City
Posted: Thu Oct 21, 2010 1:17 pm Post subject: |
airkooledchris wrote: |
I kinda sorta figured it wouldn't be an smart, albeit easier, thing to bypass in the swap. ill have to see about modifying it to tie into the baywindow system or get the correct baywindow parts for this. just in case ill pull everything else from the van in case I can adapt it. |
If your BA6 has the stench of exhaust when it runs it is usually because of one of several things ...or all combined.
(a) The o-ring between the turbocharger and cup section where it fits into the heater body is not sealing properly. This allows fuel and vapor to leak around the seal between this cup and the air exhcange area...allowing fumes to be drawn into the heater
(b) The ceramic or asbestos mantle on the inside is deformed or leaking exhaust into the air passage.
(c) Your exhaust pipe flange is leaking or the exhaust pipe is positioned incorrectly. If the heater is running rich, the exhaust can get pulled back up into the intake vents for fresh air for the engine. Ray |
Posted: Thu Oct 21, 2010 1:32 pm Post subject: |
the BA6 I just finished pulling from my 81 Vanagon doesn't have any particular smells to it at all. The baywindow bus im considering adapting it into has the cleanest smelling stock heat that ive had in a baywindow.
there was some concern that if my stock heaterboxes don't smell very good that skipping the recirculation fan would make that worse, but I don't have that issue to worry about.
I'll still have to see about how to pull in cabin air though, so im not overtaxing the stock heater fan in the engine compartment (or overtax the heater by not providing enough flow.)
at the very least ill use the second fan to provide additional flow _________________
metahacker wrote: |
josh Samba Member
Joined: July 13, 2003 Posts: 1773 Location: laid back in the tall grass
Posted: Thu Oct 21, 2010 11:52 pm Post subject: |
I adapted a vanagon BA6 to a bay window years ago.
This is all from memory but...
There should be a circle stamped in the sheet metal behind the rear seat. This is where the hole for the recirculating air blower goes.
The front of the heater should be coupled where the front of the old heating duct was. The flapper valve housing from the vanagon should be coupled to fill in the gap behind. I think I may have trimmed or otherwise modified the vanagon housing to fit (It's been awhile).
Be sure the combustion air intake tube is connected to draw air through one of the holes in the frame cross members. If the tube is left in open air road draft can pull the flame through the tube and catch it on fire.
Someone recently added a BA6 repair manual from 1979 to theSamba archive literature so you can see how all of the parts are oriented on a bay.
The heat these things put out is awesome!
Good luck. _________________
modok wrote: |
...If If stoner A takes a hit and then stoner B goes right away(not waiting two seconds), he's trying to suck on it while it's still got a vaccum, doesen't get much of a hit at all! Cause it hasn't filled back up all the way yet.
Stoner A is cylinders #2/4 B is #1/3 The plugged bowl is the throttle, the bong is the manifold |
Sage79 Samba Member
Joined: September 13, 2008 Posts: 426 Location: Holland MI
Posted: Fri Oct 22, 2010 4:06 am Post subject: |
I just got my BA6 working this week. (It needed a good relay and the two sets of points cleaned up after getting both fans to run). It seems that the recirc fan puts more air into the system than the engine fan and booster fan combined. I agree with BD's first reply that the BA6 will quickly overheat without it. You may be able to re-engineer it but only if you examine the air flow through the BA6 heat exchanger during all of the design conditions.
The heat is awesome! It will burn your hand coming out the defrost vents! _________________ Dirk
'79 Westy 2.0FI
'73 Sportsmobile 1.7dual Solex 003Auto - now my daughter's
'77 delux 2.0FI 090Auto - now my son's |
Posted: Wed Nov 24, 2010 2:50 pm Post subject: |
josh wrote: |
Good luck. |
did you go out and find any of the baywindow specific BA6 stuff to use during the install or did you just use ALL of the original Vanagon bits, modified a bit here and there?
I carefully removed the BA6 from the Vanagon setup and am thinking about tackling this project soon. Wondering if I should be searching out any specific parts from the baywindow setup that would make my life easier when mounting this...
the Vanagon, and im assuming the stock baywindows that had the BA6, had those mounting tabs welded to the underside of the body - that the BA6 mounted to with the little rubber pads. I failed to cut these off of the Vanagon underbelly and wondering now if I need those or if something can be fabbed up to serve the same purpose.
ill continue searching the forums for tips people have posted about swapping the BA6 from the Vanagon to the Bay, and very happy it's already been done by others. _________________
metahacker wrote: |
jure-slo Samba Member
Joined: November 06, 2009 Posts: 245 Location: Slovenia (Europe)
Posted: Wed Nov 24, 2010 3:06 pm Post subject: |
If you need any specific photos...my '78 bay with stock BA6 is on the car hoist right now because I took the engine out. It wouldn't be much truble to remove the belly pan... _________________ '79 Bay-window, 2.0, duals solexes, automatic
'76 Triumph spitfire 1500
'86 Polski Fiat
'72 Mercedes W115, 200D |
Posted: Wed Nov 24, 2010 3:30 pm Post subject: |
jure-slo wrote: |
If you need any specific photos...my '78 bay with stock BA6 is on the car hoist right now because I took the engine out. It wouldn't be much truble to remove the belly pan... |
Primarily the sections where the stock heater boxes tie into the BA6 and how the fresh air from the cabin is routed into the heater... I have some really low resolution shots of the overall view, but if you have it on a hoist and are able to take better high resolution pictures of the area's mentioned above - that would be fantastic!
Thanks! _________________
metahacker wrote: |
hazetguy Samba Member
Posted: Wed Nov 24, 2010 3:46 pm Post subject: |
there are a lot good pics in the gallery: http://www.thesamba.com/vw/forum/album_search.php?...t_dir=DESC
here's where the heaterbox air enters the heater:
this shows the area where the cabin fresh air is routed into the fan. the galvanized piece to the right of the orange opening piece (which is actually a hole in the firewall) is a piece that is riveted to the opening.
a complete BA6 is one thing i would really like for my bus. _________________ Parts and mechanical restoration services available. I restore and rebuild fuel pumps, distributors, spindles, etc.
Check my ads or send a PM. |
Posted: Thu Nov 25, 2010 1:02 am Post subject: |
This what you were looking for?
'86 Polski Fiat
raymino Samba Member
Joined: August 26, 2009 Posts: 85 Location: Durango, CO
Posted: Sat Nov 27, 2010 3:43 pm Post subject: |
front
rear showing my rubber duct being preserved/protected by duct tape (I'm saving my good one for the big event).
The air circulation blower is also necessary for the cool down or "run-on" phase to complete. If you were running your BA6 at full blast and somehow lost all juice, your BA6 would get quite hot for a time. The air circulation blower keeps working even after you turn your bus off and walk away. Kind of like the electric fan on those water cooled jobs. You need it.
The "air circulation blower" is definitely different from the "hot air blower". I wish they were the same as good BA6 air circulation blowers are verging toward unobtanium. You should get yours checked out and also make sure that rubber duct (round on one end and square on the other) that connects to the air circulation blower is servicable. If not, be on the lookout for one. I think this blower is the weak link in the BA6 system.
I have taken BA6 parts off of vanagons and used them in my BA6. My '79 Westy came with one installed, so I can't help much with that floor duct intake for the air recirculation blower. I think that will be your only issue.
You will love your BA6, even in balmy Eureka. I think you will regret it if you don't stick to the stock BA6 setup, working air circulation blower and all.
Meantime, it's my theory that bus heat with a BA6 installed, but not working (just using the stock heat), is less efficient than the stock heat without the BA6. I recommend that you install one of these ...
view looking to the rear showing the air circulation blower/body connection (coffee can lid duct taped here).
While you are getting your BA6 shaped up, you can use this replacement pipe to see just how much you can get out of you stock heat, following Ratwell's chart. More pics are in my gallery.
Ray _________________ '79 Westy Headflow Masters 2.0L FI
'87 GTI 16V Sold!
'06 Jetta 2.5 Package 2
'71 Super Marine Blue |
mattcuddy Samba Member
Joined: October 22, 2003 Posts: 2033 Location: Philly, PA
Posted: Sat Nov 27, 2010 8:40 pm Post subject: |
I have a thought on how to get cabin air into the BA6, for busses that don't have that big hole cut under the rear bench seat (and without a donor section from another bus)
Why not just take the stock heaters output channel that points to the rear, from under the middle passenger seat - and make this the cabin air to BA6 recirculation point?
in more obvious terms, change this thing from BLOW to SUCK instead:
why the hell not?
If I can do this, I think my next hurdle is going to be fabricating a mount for the actual heater unit itself. _________________
metahacker wrote: |
josh Samba Member
Posted: Sat Nov 27, 2010 9:32 pm Post subject: |
josh wrote: |
Good luck. |
ill continue searching the forums for tips people have posted about swapping the BA6 from the Vanagon to the Bay, and very happy it's already been done by others. |
I didn't have access to any bay parts when I did the swap. I used 99% Vanagon parts. I didn't cut any of the mounting tabs off of the vanagon. I don't think they would be the right size anyway. I just fabbed some out of sheet metal and welded them up.
I live in CA too and I don't see a lot of these. I used to spend a good portion of my free time at auto wreckers and I came across two vanagons with gas heaters. I found one bay with a BA6 a few years ago and took the heater but left the bay specific ducting. It's welded in and really well integrated into the body. It would have taken more time cutting, grinding, drilling and cussing at the pick n pull than I was game for. _________________
modok wrote: |
josh Samba Member
Posted: Sat Nov 27, 2010 10:14 pm Post subject: |
why the hell not?
If I can do this, I think my next hurdle is going to be fabricating a mount for the actual heater unit itself. |
I think that's going to be too restrictive. I wouldn't draw air for the blower through any path that gets smaller than the blower opening at any point. Centrifugal blowers are good at overcoming some resistance on the output side but not on the input side. Choke down on the input and you could burn out the motor.
The vanagon I pulled the system from had the blower mounted directly to the body at the hole under the rear seat with a cover to keep debris out. I mounted it the same way in the bus. The rubber outlet tube didn't reach the flapper duct anymore so I found some ducting material the same I.D. as the tube and and piece of steel tubing that fit inside to act as a coupler. The ducting material was actually similar to the heater hoses in the engine compartment. I don't remember what the original app was.
If I do this again, I will cut the hole under the seat. I can understand why you wouldn't want to cut a big hole in your bus. The important thing is to find a way to get clean air to the blower without restricting the flow.
As for fabricating A mount for the heater, I don't think a single mount is going to be practical. It's probably better to fab individual mounting tabs as original. Also, the only way to really line up the mounts is to have the heater in place when fitting them. If you can't weld you could clamp the heater, boots and flapper box in place, secure it with some straps and take it to a welding shop.
If you can weld, cut and bend sheet metal it really shouldn't be that difficult. Once you take the old heating duct out and lift this thing into place it should be like a puzzle where 90% of the pieces fit just right and the 10% that are left over need a little persuasion. _________________
modok wrote: |
Posted: Tue Nov 30, 2010 9:17 pm Post subject: |
Thanks a lot for the replies. Ill continue to post back here rather than PM'ing you so others who might tackle this down the road will have more resources...
Im a little confused on the above, did you mean you did cut a hole in the one you have now, or that you would if you ever redid it?
I did save the little plastic screen for the hole that was cut under the rear bench, though the rubber thing that connected the two was kaput and ill have to re-do that part (I think you did the same.)
the points on the bus where the BA6 mounts is definitely a little different than the Vanagon, but ill probably just do what you did and pull the stock setup and just hoist it up there to see what fits and where it'll need tweaking.
I agree on the air-flow thing for the cabin air, when I was mocking it up earlier I saw the way that fan actually works and figured id either have to do it like the Vanagon and cut the hole - or not use that metal vent under the floor, but perhaps use that hole with some kind of cover and screen.
this is what I have, minus the wiring stuff:
metahacker wrote: |
