ShootingFish Samba Member
Joined: July 25, 2010 Posts: 330 Location: Portland, OR
Posted: Thu Oct 21, 2010 4:25 pm Post subject: Square Headlamp Size? |
I am starting the hunt... Yes, I know that it is going to be a difficult one, for some square H4s. But I need to know the size first.
Anyone out there with the 411?
SF _________________ SF
Props aren't just for boats....
'88 2WD ALH-TDI Westy
'90 Syncro 16 Doka |
K58 Samba Member
Joined: July 01, 2006 Posts: 1173 Location: Santa Barbara
Posted: Thu Oct 21, 2010 8:01 pm Post subject: |
Could you be a little more specific?
The standard H4 is 200mm or roughly 7" X 6"
The Vanagon has an odd size and is not directly interchangeable.
Posted: Thu Oct 21, 2010 10:21 pm Post subject: |
That is a great start on info... Thank you.
Vango Conversions Samba Member
Joined: October 04, 2010 Posts: 1054 Location: Seattle, WA
Posted: Thu Oct 21, 2010 10:28 pm Post subject: |
If you're looking to improve your square headlight lighting, don't focus too much on getting H4s. Yes, most of the bright round headlights (not sealed beams) use H4s but the bulb itself isn't really much better. It's the optics of the after market lens and reflectors that work better, not the bulb.
If you can find some better square headlights that fit the van please let everyone know, but I wouldn't limit your search to only lenses that accept H4s. |
K58 Samba Member
Posted: Thu Oct 21, 2010 11:27 pm Post subject: |
You mean http://gowesty.com/ec_view_details.php?id=3093&category_id=&category_parent_id=
I actually have it already and have been pretty happy with the change in the lighting... I have just been reading about the Euro Spec H4 lenses and was curious about what that might do for the lighting.
Thoughts? _________________ SF
SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 2458 Location: Highnam, UK
Posted: Fri Oct 22, 2010 4:24 am Post subject: |
I've been looking into this for a while and have started taking note of modern truck headlights which run HID's.
I have an HID conversion kit fitted to Limey and love the bright lights but don't like the light leak off points which can potentionally dazzle other drivers. I'd love to get a more modern headlight to replace both the main and spot light units.
MG _________________ T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD |
78BayDriver Samba Member
Posted: Fri Oct 22, 2010 9:25 am Post subject: |
Does anybody hae a 90-94 Passat? If so, can you measure the WHOLE lens area? I just had an idea and want to see if this works.
Michael _________________ 1987 Vanagon GL 2.1 Flat Stanley (present)
1991 Golf GTi Forest Green
1981 Vanagon L 1.6 Diesel
1978 BayWindow Bus
1974 Bus
1990 Jetta
1979 Dasher Wagon
1972 Beetle |
K58 Samba Member
Posted: Fri Oct 22, 2010 7:55 pm Post subject: |
SyncroGhia wrote: |
MG |
here's what I did to get "real" HID's...next project is the Westy
http://www.jeep-xj.info/HowtoBiXenonProjectors.htm |
Posted: Sat Oct 23, 2010 11:37 am Post subject: |
That's what I'd love to do but how do you get around the lense? We need a clear lense which is the same size as the current one...
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
Posted: Sat Oct 23, 2010 11:57 am Post subject: |
K58 wrote: |
ps. don't waste money on a GoWesty headlight downgrade |
Would you care to elaborate on what you mean by your comment? Just curious.. _________________ SF
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Sat Oct 23, 2010 12:05 pm Post subject: |
There is a higher bulb output but the DOT lenses dissipate the light and it makes the improvement negligible.
There are E-code headlight assemblies that are sometimes available but the cost is high. They direct the light output much better than the US spec units. |
Posted: Sat Oct 23, 2010 12:20 pm Post subject: |
I totally get that... Though it seems that the e-codes are not only expensive, but nearly impossible to locate.
Throw into this the fact that the current vanagon square lights are no longer in production, we are going to be between a rock and a tough spot in the not too distant future. That is why I am looking for some other options. It is sounding like the Ciebe E-Codes with Saab adjusters may be the way to go, or projectors, though it looks like those could be too deep to fit... _________________ SF
a914622 Samba Member
Joined: July 29, 2004 Posts: 840 Location: Westend of HWY2 , Wash
Posted: Sat Oct 23, 2010 2:11 pm Post subject: |
I was at the same spot your in know. I just picked up a set of Cebies form a wrecking yard. One thing i noticed was stamped right on the light is 70/60W. Im going to trade out one of the hellas i have in there now and see if there is any differance in light output using the same bulbs.
I did look at the 411 and the lights are way wrong.
jcl _________________ 87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru |
K58 Samba Member
Posted: Sat Oct 23, 2010 2:57 pm Post subject: |
ShootingFish wrote: |
K58 wrote: |
Would you care to elaborate on what you mean by your comment? Just curious.. |
sure, do a search of the GW headlight upgrade and read about the overheating issue.
also, I have a set of Euro spec H4's if anyone's interested.
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6355 Location: Honolulu,Hawaii and France
Posted: Sat Oct 23, 2010 2:58 pm Post subject: |
some people have mounted in Europe the old eurovan lights,not the same look though
I think we have to look at lenses that are pretty flat because of the body metal behind...like the Projektzwo ones.
Good luck finding something that fits nicely |
Posted: Sat Oct 23, 2010 5:33 pm Post subject: |
ALIKA T3 wrote: |
I dont know if i didnt tell ya, you may not see the headlights are not stock. _________________ 87 gl powerd buy 2.5subaru
Posted: Sat Oct 23, 2010 7:29 pm Post subject: |
I think I saw your picture on another thread:you're right,hard to notice on a pic,but I would have noticed in reality.
It's a good match,I just donc like the round corner on the rectangular light....That'd be better looking with same shape square lights,but it's better than nothing,right?? |
K58 Samba Member
Posted: Sat Oct 23, 2010 10:23 pm Post subject: |
ALIKA T3 wrote: |
Try to let go the idea of a Volkswagen Vanagon (or Eurovan ) headlamp putting out better light than a 200mm E-code H4 housing. The square Vanagon lights suck plain and simple and all the aftermarket wiring isn't going to improve them enough to make a very noticeable difference.
a914622 has successfully given the Vanagon the only real headlight option.
With a real H4 wiring harness and 100w bulbs you will be able to see better than all of the other motorists with woefully insufficient lighting. |
