teamasr Samba Member
Joined: August 04, 2009 Posts: 159 Location: SF Bay Area
Posted: Fri Oct 22, 2010 8:41 pm Post subject: Swamp cooler - Window mount? |
Does anyone know how this swamp cooler is mounted into the window? Is there a kit for this, or was the frame/glass of this bus cut out to accommodate the outlet? Did VW make these back in the day?
Semper_Dad Samba Member
Posted: Fri Oct 22, 2010 10:09 pm Post subject: |
This has to be a custom window frame setup. Notice the bottom tab on the support rod. Looks to be at least spot welded to the frame. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
64 ragtop volks Samba Member
Posted: Mon Aug 19, 2013 8:12 pm Post subject: |
Made some plastic windows for the swamp cooler.not sure what brand it is though
Spiderwebb Samba Member
Posted: Mon Aug 19, 2013 9:51 pm Post subject: |
does anyone have a diagram of the inside of one these so I can see how it works / cools the air via water vapor...??!!
thanks |
Posted: Mon Aug 19, 2013 10:44 pm Post subject: |
Inside is a squirl cage or bail wrapped with a straw like mat that is "spring loaded"you pull the string and it rotates the cage through the water as you drive air comes across the wet straw mat cooling the air.they work really well in dry climates.just pull the string every 10 or 15 minutes.adding ice helps even better.when you are stopped no air is comming thru the cooler.same principle as evaporative cooler sold at home depot or lowes,but they use an elecrtic pump to get the pads wet.hope that makes sense |
ejon Samba Member
Joined: September 21, 2012 Posts: 128 Location: oregon
Posted: Mon Aug 19, 2013 11:43 pm Post subject: |
those were a dealer item and only made for roll up widows, so anything you do to make one fit a spilt is a #### job.
niether one pictured is the Vw cooler, believe it or not they didn't cool down a damn thing unless you were doing 60+ mph. and thats in a car..
ok they would cool, IF it was blowing right on YOU.
The only time they look cool is sitting in a car show.
just go buy a $100 wal mart AC unit a 299 $ colman generator, cut a hole in the damn roof and Then
Be Happy |
Hansolo99 Samba Member
Joined: December 04, 2010 Posts: 524 Location: So Cal
Posted: Tue Aug 20, 2013 8:10 am Post subject: |
ejon wrote: |
Be Happy |
A full custom like this? Now that's an idea!!
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Tue Aug 20, 2013 8:19 am Post subject: |
ejon wrote: |
Be Happy |
When it's 105* you take what little you can get from whatever source you can get it.
Talk about a shit job, your idea is the pinnacle, but it looks like it's working for your Lincoln. Be happy.
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Tue Aug 20, 2013 9:22 am Post subject: |
Not affiliated but linked to show models: http://www.theoldcollectorsgarage.com/carparts/original-1940s-50s-swamp-coolers..htm
Allstate could be bought from Sears.
My great uncle always had one in his cars. If I cupped my hands and stuck my face right into the output air it was cooler. Then I'd get yelled at for Bogarting the cool. It was my job to fill it with the radiator hose at gas stops. It smelled dank. |
Posted: Tue Aug 20, 2013 11:38 am Post subject: |
I guess it hard to cool off with your head so far up your ass.i got 7 degrees cooler air with just water.and 13 degrees using melted ice water woth temps at 98 deg.yesterday.ill take my shitty hackjob bus anyday over a pavement princess.they work best in DRY climates. |
BarryL Samba Member
Posted: Wed Aug 21, 2013 7:07 pm Post subject: |
64 ragtop volks wrote: |
I guess it hard to cool off with your head so far up your ass. |
Who you referring to?
Are you the guy that drove to OCTO from Texas? |
slow36hp scott wimberley
Joined: August 09, 2004 Posts: 3113 Location: mukilteo washington
OG67westy Samba Member
Joined: September 05, 2008 Posts: 286 Location: San Marcos Texas 78666
Posted: Fri Aug 23, 2013 2:26 pm Post subject: |
BarryL wrote: |
yes, that's the guy...and I think he was referring to ejon...hope you don't mind me answering for you, dwight... |
bonecollector Samba Member
Joined: September 16, 2003 Posts: 311 Location: Southeast Idaho
Posted: Sat Aug 24, 2013 8:11 am Post subject: |
The cooler pictured on this bus is a Firestone. _________________ CHECK US OUT ON YOUTUBE: http://www.youtube.com/watch?v=xsaYK9P6m68
WWW.VOLKSWEAR.COM |
Posted: Sat Aug 24, 2013 12:45 pm Post subject: |
Yeah thats me.I made the rodie from texas to so.cal and back 2977 miles.im at 6500 now and still rolling it ratty and loving every minute of it.roll it hard or roll it home.built for fun and built to run. |
demon1018 Samba Member
Joined: September 12, 2009 Posts: 930 Location: crystal river, fl
Posted: Sat Aug 24, 2013 2:06 pm Post subject: Re: Swamp cooler - Window mount? |
slow36hp wrote: |
teamasr wrote: |
custom frame with cut plastic window. Surprised Clayton hadn't commented it is really slick |
you consider this a hack job??? weather it works or it doesnt ' it looks awesome on there and to most people' you would never know if it was stock or not. |
