Real time help Girling caliper orifice question.
IdahoDoug
IdahoDoug is offline
PostPosted: Mon Oct 25, 2010 10:43 am    Post subject: Real time help Girling caliper orifice question. Reply with quote
In cleaning up my calipers, I note there are two orifices in the piston chamber for fluid from the lines to push on the pistons. One of the orifices is clear and I can push a wire down into it and far out of my sight so I'm happy I've got it cleaned. The second orifice I can not clear. This second one appears to be a false hole that was only drilled deep enough to cause my question.
Can someone confirm that this is so? I'm literally at the workbench ready to rebuild the calipers but if these are supposed to be open then I'm going to toss them as I cannot clear them. It's an 87 and these appear originals - Girlings. Thanks!
DougM
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader
thummmper
thummmper is offline
PostPosted: Mon Oct 25, 2010 10:48 am    Post subject: Reply with quote
bleeder
IdahoDoug
PostPosted: Mon Oct 25, 2010 11:19 am    Post subject: Reply with quote
Score - why didn't I think of that. Was a fleck of crud strong enough to resist my mouth pressure on the opened bleeder valve. Got a wire through it from the other side. Both are clear now. Thank you!!
DougM
thummmper
PostPosted: Mon Oct 25, 2010 10:05 pm    Post subject: Reply with quote
I like you Doug
