earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sat Oct 23, 2010 5:42 pm Post subject: Tell what you think of this idea. |
OK
so I was out in my garage today looking for some thing and found a set of Honda GL1100 gold wing heads, I got to looking at them and thought the valve springs look like they would fit in a 36 hp head. I pulled out the intake valve from the GW head, they have dual springs that are about the same size as the VW spring then I looked at the valve ,its almost the same length as a VW valve, here are the specs on the GL parts...
Valve dia-Intake 38mm / ex 32mm
valve lenght- 4.05" [about .025" longer then VW]
stem dia- .259"
spring dia- outer 1.132"/ inner .805" [VW is 1.085"]
spring lenght-1.710"
Do you think they could be fit to a VW head by sleeving the VW guide down and putting in new seats? Let me know what you think.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
grueni Samba Member
Joined: November 03, 2008 Posts: 582 Location: Germany
Posted: Sat Oct 23, 2010 11:52 pm Post subject: |
sounds and look good if you rebuild or tune your heads. 38mm and 32mm is very close but possible maybe it is better to machine the intake valves to 37mm or 36mm depends on how good your portjob will be its very hard because the meat in the port isn't that big for a real high end port for 38mm. spring pressure would be interesting. and you have to open the valvespring seat like the blackline crew and i did.
weiht of the parts would be also interesting.
i like them _________________ 1960 1584cc turbocharged, 35,5/32 (11,117s 1/4mile ) |
blacklineracing Samba Member
Joined: March 21, 2009 Posts: 128 Location: Salt Lake City, Utah
Posted: Sun Oct 24, 2010 11:11 am Post subject: |
Sounds like it would fit to me, we ran 38mm intakes and 32mm exhausts valves in our race engine and the worked well. What is the installed height of the valve springs? |
grueni Samba Member
Posted: Sun Oct 24, 2010 12:00 pm Post subject: |
coltom/justin....did you get the port into the 85-90% area ( about 34mm diameter in the port of your 38mm valve? i tested on heads and got go through the wall in the port. my heads have a 32mm port all the way bit its kind of save because it is also for street use and for 77 bore there a 38mm make no sense.
those goldwing valves could be a cool option. bmw/opel has also some valves with 6mm steam and about 103mm length that will be good for 36hp tuning.
cassey could you weigh all the parts, vales, springs, retainer. this will be great.
wishes
christian _________________ 1960 1584cc turbocharged, 35,5/32 (11,117s 1/4mile ) |
Posted: Sun Oct 24, 2010 1:04 pm Post subject: |
OK
I dont have a installed height for them, just free length, wire diameter on the honda springs is- outer .150" Inner-.111"
I did weigh them but the only way I could do it was with the scale I use for reloading my target ammo in "grain" [7000gns per a pound] and convert them with a program I found on line, OK, here we go
Honda parts
Retainer-----215.0gns-13.93gms
inner spring-321.7gns-20.84gms
outer spring-669.0gns-43.35gms
38mm valve-964.3gns-62.48gms
keepers------24.3gns----1.57gm
total gram wt.-----------142.17 grams
VW parts [pulled from a stock head]
stamped retainer-133.5gns--8.63gms
single spring------513.0gns-33.24gms
intake valve------782.6gns-50.71gms
keepers-----------39.6gns----2.56gms
total gram wt.----------------95.16 grams
these are the numbers I came up with with the parts I have on hand, I dont know the variables between the honda parts but from whit I have seen they keep a pretty good tolerance. I know you can turn a gold wing 7500 RPM's no problems and I spun them 8500 a few times so I think they should work for a 36hp motor.
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7215 Location: Videbaek Denmark
Posted: Sun Jul 25, 2021 3:17 pm Post subject: Re: Tell what you think of this idea. |
Those Gold Wing valves are actually Alfa Romeo But yes I have had my eye on those too.
I have already done A LOT of simulations on the subject. Two things to remember. Thist is going to be a street car with some track time, so driveability is paramount. In the simulations there is a very fine line between 36 & 37 mm intake valves. More than that and the port volume seems to get too large and you loose port energy and then power takes a dip.
Christian is correct. There is only so much meat to work with in an unwelded head. I will exploit it best possible.
Blackline guys. Good top see you around here. Some of your race stuff have been very inspiring. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Wed Aug 04, 2021 1:21 am Post subject: Re: Tell what you think of this idea. |
You can call them Alfa Romeo valves but I took them out of a stock Honda Goldwing head that had never been apart, the valve on the right came out of a 36hp head.
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
98 Ford E150
DEATH TO CHINGERS!
