EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Thu Nov 04, 2010 6:43 am Post subject: |
perrib wrote: |
It looks well braced. Your moving right along on its ressurection. |
Thanks man
05Duramax07, Its just a king/link front end with a rack & pinion steering unit _________________ 1963 Ragtop Bug |
vw_nick Samba Member
Joined: August 21, 2005 Posts: 391 Location: Nashville, TN
Posted: Thu Nov 04, 2010 7:40 am Post subject: |
that's a really neat looking buggy! The only thing I would suggest is to make some modifications to the roll cage - move or add some additional tubes closer to the outsides of the top and then have another tube that goes down to the rear along the same plane - you want all the forces to be able to transmit directly into the next area and the way it's set up now the windshield frame forces go to the center area of the main roll hoop and then not directly to the rear of the chassis, instead there are those little diagional sections down lower. This probably sounds like jibberish but it's difficult to describe. _________________ Nick |
Posted: Thu Nov 04, 2010 10:15 am Post subject: |
Thanks Nick, I will see how I can add in some more support bars. I yanked the front beam and pulled the spindles off. I will be ordering a new link/king pin kit. I already have new bushings to go in the axle tubes.
Does anyone know who sells new boots for the steering racks? They look like the same boots off some Rancho shocks, thx.
Posted: Sat Nov 06, 2010 3:11 pm Post subject: |
Finished blasting it and primed it up today.
perrib Samba Member
Joined: September 14, 2004 Posts: 3402 Location: Chandler, Az
Posted: Sat Nov 06, 2010 5:41 pm Post subject: |
That looks like an automobile rack. A local rebuilder should be able to get you the correct ones. If you take a few close ups someone here may be able to identify it. |
Posted: Sun Nov 07, 2010 8:23 am Post subject: |
perrib wrote: |
Thanks Perrib, I got some new boots for it but I need to know if anyone sells the bearing for this pinion gear? Its a roller/needle bearing. There is no name on this old rack, thanks.
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Nov 07, 2010 9:27 am Post subject: |
Should be a number on the 2 bearing parts. Most bearings are standard size.
I needed bearings for a Vanagon automatic trans pinion shaft. I found that they were the same as the front wheel bearings on a 1 ton Chevy truck. My local parts store had them on the shelf. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Mon Nov 08, 2010 5:31 pm Post subject: |
Thanks Russ, but there were no #'s on these, so what I did was soak them in the parts washer, cleaned them real good and regreased, repainted and put it all back together. It works nice and smooth now. I ordered some new rod ends from Speedway Motors and should get them by the end of the week.
Rack:
Painted Column:
Old wasted rod ends:
New ones on the way:
http://www.speedwaymotors.com/AFCO-Steering-Rod-Ends,41039.html _________________ 1963 Ragtop Bug |
Posted: Thu Nov 11, 2010 2:40 pm Post subject: |
Got just about all my parts blasted and primed.
highdesert Samba Member
Joined: June 04, 2009 Posts: 117 Location: Riverton, Ut
Posted: Thu Nov 11, 2010 3:11 pm Post subject: |
Your project is really coming together, nice work.
And I thought my frame was rough when I first started. |
Posted: Fri Nov 12, 2010 5:14 pm Post subject: |
Thanks, today I laid the trans in so I could put in a front strap. Welded in some studs.
Posted: Mon Nov 15, 2010 4:04 pm Post subject: |
Cleaned up the trans and painted it. The rail is going to be painted hammered silver with blue body panels..just not sure which blue yet.
Posted: Tue Nov 16, 2010 3:58 pm Post subject: |
I moved the battery tray out a little to fit a bigger battery box.
Also ran tubes for clutch and throttlle cables..no hydraulic clutch yet
Posted: Thu Nov 18, 2010 4:26 pm Post subject: |
Put in an Oh Shit bar for passengers:
Added some brake line tabs in rear and front:
Added some light tabs for towing lights:
Started assembling the beam:
Put the front brakes together. The wheel cylinders are rears. Will it have much less stopping power even though the rail is pretty light? thanks
Posted: Fri Nov 19, 2010 5:23 pm Post subject: |
Painted the frame silver today, trying to decide on a color for the body panels...
Buggy Disaster Samba Member
Joined: November 21, 2010 Posts: 297 Location: Kennesaw GA
Posted: Mon Nov 22, 2010 8:43 am Post subject: |
Very nice build.
As for the body panels, I would either paint them black, or a mettalic medium blue. Just my 2cents |
Posted: Tue Nov 23, 2010 3:08 pm Post subject: |
Thanks, actually I am also thinking of a blue color. When Im ready I'll hit the paint supply shop. I've been slowly putting things back together like the shifter, cutting brake, steering rack, fuel tank, etc. _________________ 1963 Ragtop Bug |
thext94 Samba Member
Joined: April 11, 2010 Posts: 1003 Location: Manhattan Beach, CA
Posted: Tue Nov 23, 2010 4:30 pm Post subject: |
some kind of metallic or flat navy blue would look really good with the silver
http://www.resortcabanas.com/paint/navy-blue.jpg
in my opinion at least. the rail is looking really good, i like the attention to detail
Tyler |
Posted: Wed Nov 24, 2010 2:33 pm Post subject: |
Thanks, starting to reassemble. I need to press in new link and king pin bushings. Do you guys usually have someone with a press do it or you do them yourself in a vice?
DirtGhost Samba Member
Joined: September 19, 2007 Posts: 547 Location: Greensboro,NC
