1979 2.0L fi Alternator upgrade (55 to 70 amp)
Page: Previous  1, 2
69BahamaYellow
69BahamaYellow is offline
PostPosted: Wed Mar 02, 2016 7:23 pm    Post subject: Alternator light stays on until I rev the motor slightly Reply with quote
I just upgraded my stock 55amp alternator to a Bosch AL108X that has been boosted to 110 Amps. When I start the bus, the alternator light stays on until I rev the motor slightly, and then it goes out and stays out from idle through full throttle operation. I've checked the voltage output and it is 14.1 volts at idle with no accessories running, and 13.86 volts with lights, radio, and heater fan on. The alternator light never stayed on after starting with the stock 55 amp unit. Has anybody else seen this happen?
aeromech
aeromech is offline
PostPosted: Wed Mar 02, 2016 8:20 pm    Post subject: Re: 1979 2.0L fi Alternator upgrade (55 to 70 amp) Reply with quote
Sounds like no problem to me. Question is, why would you need 110 amps?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
69BahamaYellow
PostPosted: Thu Mar 03, 2016 5:58 am    Post subject: Re: 1979 2.0L fi Alternator upgrade (55 to 70 amp) Reply with quote
The extra amps will be for an A/C install, I'm working on. I wanted to post the alternator question here, so it's easily searchable for others with the same problem. There's a ton of good info on this site.
The alternator seems fine to me too, but it's like I have to "wake up" the voltage regulator, when I first start the engine, and the last thing I want is to start off on a long trip, knowing something could fail, with no easy sources of spare parts....
vwwestyman
vwwestyman is offline
PostPosted: Thu Mar 03, 2016 6:32 am    Post subject: Re: 1979 2.0L fi Alternator upgrade (55 to 70 amp) Reply with quote
The "wake it up" thing was common on at least the diesel Rabbit cars and Cabriolets. I had several of each and they were all that way. Also had a Corrado that did it and a Corrado that didn't.
The only time at all it was a "problem" would be if I were to start the car with the intention of idling it for a while (which is very, very rare for me to do), the alternator wasn't charging if I didn't think to blip the throttle after starting.
I say don't worry too much about it.
Dave Cook
1973 Wild Westerner
My Thing
johnsilverlakes
johnsilverlakes is offline
PostPosted: Thu Mar 03, 2016 8:17 pm    Post subject: Re: 1979 2.0L fi Alternator upgrade (55 to 70 amp) Reply with quote
I had that issue with my 70amp alternator. I installed a volt meter to monitor actual charging. It wouldn't charge above 12 volts until the motor was reved. I kept thinking it was a voltage relay. I ran it with that issue for many years. Recently, I pulled the engine to fix some oil leaks. I decided to clean all the electrical connections at the harnesses and eliminate non stock wiring...Long story short. It must have been a faulty connection. Now, no problems with the charging system!
1976 Westfalia
Manual Transmission
Federal Emissions
69BahamaYellow
PostPosted: Mon Mar 07, 2016 6:06 pm    Post subject: Re: 1979 2.0L fi Alternator upgrade (55 to 70 amp) Reply with quote
I double checked all my connections from the alternator to the voltage regulator, and there were no issues. Then I ran across this article about "waking up a Porsche 914 alternator" (essentially the same as a bus). At the very end, it said the alternator warning bulb in your dash needs to be at least 2 watts to give enough current to wake up a Bosch alternator at initial startup. I checked mine, and it was only 1.2 Watts, so I changed it to a 2.3 watt bulb, and that solved the problem. Unbelievable.......
http://www.pelicanparts.com/techarticles/914_alternator_troubleshoot/914_alternator_troubleshoot.htm
aeromech
aeromech is offline
PostPosted: Mon Mar 07, 2016 7:07 pm    Post subject: Re: 1979 2.0L fi Alternator upgrade (55 to 70 amp) Reply with quote
Good find, thanks
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Wasted youth
Wasted youth is offline
PostPosted: Fri Dec 03, 2021 8:45 pm    Post subject: Re: 1979 2.0L fi Alternator upgrade (55 to 70 amp) Reply with quote
Interesting. The red LED indicators for BATT and OXS behave exactly the same way on my 1981 Vanagon. They stay on until you give the accelerator a little goose, just like on my '73 bus.
LEDs are low wattage. Don't know what I'd do to resolve that.
vwwestyman
PostPosted: Fri Dec 03, 2021 9:57 pm    Post subject: Re: 1979 2.0L fi Alternator upgrade (55 to 70 amp) Reply with quote
I had to do the alternator wake up thing on every one of my diesel Rabbits (and I had a few) and I believe also a couple Cabriolets needed the throttle goose too.
Dave Cook
1973 Wild Westerner
My Thing
SGKent Premium Member
SGKent is offline
PostPosted: Fri Dec 03, 2021 11:13 pm    Post subject: Re: 1979 2.0L fi Alternator upgrade (55 to 70 amp) Reply with quote
2016 was the last post before you. Old thread. But if you have LED as the alt warning then it won't work as well to excite the alternator I think. Might ask Telford.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Page: Previous  1, 2
Page 2 of 2
