crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Fri Oct 29, 2010 10:22 am Post subject: Windshield glass dimensions |
Anyone have the dimensions for the front window glass? Mines cracked and needs to be replaced.
I'm not interested in purchasing a template, just hoping someone has the exact measurements. Thanks. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Semper_Dad Samba Member
Posted: Fri Oct 29, 2010 10:35 am Post subject: |
Are you planning to replace it yourself? Can't you use your exisiting one? That's of course whether you can get it out of the frame in one piece. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
uberautowerks Samba Member
Joined: October 17, 2005 Posts: 1600 Location: Longmont Co
Posted: Fri Oct 29, 2010 10:50 am Post subject: |
I'm with Sember... take your existing glass to a glass shop.
I learned the hard way...
Because of the shape exact measurement are difficult. You need more than just width and height. You'll need the angles at the corners and the lower left to upper right measurement etc... _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black) |
Posted: Fri Oct 29, 2010 11:28 am Post subject: |
This car is my daily driver
Is it not a rectangular piece of glass? _________________ Your Vanagon sucks, Stop waving at me.
Posted: Fri Oct 29, 2010 2:01 pm Post subject: |
Not a rectangle.
It is however a trapezoid.
You should be able to find a glass shop that will cut it while you wait.
If perhaps you make an appointment.
Pull it the night before, drop it at the glass shop in the AM, pick it up a couple hours later.
Bamn!!! You're done. _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
Fun 181 Zu Geil!
Joined: October 20, 2006 Posts: 1003 Location: Connecticut
Posted: Fri Oct 29, 2010 6:18 pm Post subject: |
Search and ye shall find. Folks had some questions about windshields just last week. This post helped them out. I believe it includes dimensions, but the trapezoid shape wasn't mentioned...
http://www.thesamba.com/vw/forum/viewtopic.php?t=245181 _________________
Ian Epperson wrote: |
Holy poop, that's full of awesome! |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Sat Oct 30, 2010 10:29 am Post subject: |
15 3/8, 50 1/2, 54 _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
FreakCitySF Samba Member
Joined: June 08, 2004 Posts: 642 Location: San Francisco
Posted: Sat Oct 30, 2010 3:17 pm Post subject: |
I just used measurements and the local glass shop cut a piece for $85. Cost another $75 to have them install it.
It's a bit akward but if you plan your moves you can do great. Helps to have a helper.
I think the edges are beveled. And the corners are rounded. |
kubelmann Samba Member
Posted: Sat Oct 30, 2010 5:29 pm Post subject: |
I just put a windshield in a 74 I working on for a guy. I went to the glass shop with a windshield pattern and he cut and beveled edges and rounded the corners while I waited for $110. He told me it would have been $125 but he happened to have a flat piece of green tint auto glass the correct size on hand. So that saved $15. If the 4 screws come out of the frame properly swapping a Thing windshield is a breeze. But then, I am working on a barn find with 32K original miles on it. |
sdwalter Samba Member
Posted: Mon Nov 01, 2010 12:15 pm Post subject: VW Thing Windshield Drawing |
I created a drawing for the windshield using the dimensions that Mike posted above. I uploaded a jpeg of the drawing to the gallery and will email the PDF to be included in the technical section.
man130 Samba Member
Joined: August 25, 2008 Posts: 406 Location: long island , ny.
Posted: Mon Nov 01, 2010 1:22 pm Post subject: |
Thats a very nice drawing with the pdf and all ,but I bet it would be of little help when you bring it to a local glass shop. I've worked in the glass bussiness for 25 years ,while there are some great people working in the bussiness, they did not end up there because NASA was alittle slow. If those sizes are correct and you dont have the old piece to give them as a templete.Just tell them to take a piece and cut it down to 15 3/8" height then cut from a square end 2 3/4" on top and 1" on bottom to give correct angle. then procede to measure 50 1/2 from the top (2 3/4 cut side) and measure 54" from the bottom (1" cut side) and you'll have the right piece.Reason for cutting 2 3/4 to 1" and not 1 3/4 " to 0" is it hard to cut the laminated glass to a strip that small . |
Posted: Mon Nov 01, 2010 3:23 pm Post subject: |
The corners of the windshield are rounded and the edges are chamfered to give clearance relief for the rubber edge seal between the glass and inner edges of the metal frame that contains the windshield. I have had a good number of perfect Thing windshields made using a windshield pattern (or your old windshield) with chamfer data. |
Posted: Tue Nov 02, 2010 8:31 am Post subject: |
If anyone is willing to share the chamfer data and the radius for the corners, I will update the drawing. |
man130 Samba Member
Posted: Tue Nov 02, 2010 10:02 am Post subject: |
the beveled edge you speak of is just running a belt sander around the edge to take off the shape edge (it cacks easier from the sharp egde as to a smooth edge) and the radius would be done with the belt sander also refered to as a dimes edge (same radius of a dime) see ya |
Posted: Wed Nov 03, 2010 5:08 pm Post subject: |
Thank everyone for the information. I have updated the drawing of the windshield by adding a note to chamfer the edges and round the corners to allow the seal to fit. Everett was kind enough to post it to the technical area of the site under the miscellaneous section. I have posted a link to the drawing below.
http://www.thesamba.com/vw/archives/info/Thing_Windshield.pdf
If anyone has further updates or information for the windshield, let me know and I will update the drawing again.
Scott |
