Brake line flaring
Page: Previous  1, 2
Ajmarqueling
Ajmarqueling is offline
PostPosted: Fri Dec 21, 2018 1:14 pm    Post subject: Re: Brake line flaring Reply with quote
jammor wrote:
I just used The POWERBUILT 9 piece double flaring tool kit from Advance Auto Parts
Kit # 23 model 648610
$36- returnable loaner tool
Used the 3/16ths die (correct word?) on 3/16th teflon coated line (Advance Auto).
Use OIL to help die not "stick". You will use ALOT of torque on the Poly-Armour steel line
Poly-Armour Poly-Armour PVF Steel Brake Line Tubing Coil, 3/16" x 25'
4.0 star rated product | #PAC-325
$21.99-
I broke the first die thing off inside the brake line because Advance also sells a cheaper Flare kit (if you can believe that)-
If I had it to do over I'd just spend the $35 on a line kit-- Didn't want to wait on shipping
Airkewld STEEL BRAKE LINE KIT - 4860
BUT the flares I made work and don't leak!
so is this a double flare kit that you made bubble flares with as the OP stated? Or is this kit a bubble flare kit?
elikus
elikus is offline
PostPosted: Thu Apr 08, 2021 11:07 am    Post subject: Re: Brake line flaring Reply with quote
I'm confused, is it Bubble flare for all Type-1? The Service manual from Bentley, 1966-1969, page 12 of the brakes section indicates that the tubes ends are "double flared", as shown in Fig. 18.
I'm in the process of replacing my lines on my 66, and I'm looking for clarification on this, rather than asking in a new post.
Thanks in advance.
Hotrodvw
Hotrodvw is offline
PostPosted: Thu Apr 08, 2021 1:25 pm    Post subject: Re: Brake line flaring Reply with quote
A double flare is inverted because it's double lapped, not a bubble DIN flare. What will dictate the type of flare to be used is the receiving port. If using OEM style parts on your '66, you'll be using a DIN bubble flare.
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
Page: Previous  1, 2
Page 2 of 2
