Schwing Samba Member
Joined: May 10, 2009 Posts: 2506 Location: Centreville, MD
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Wed Nov 10, 2010 7:14 pm Post subject: |
Most of the engines leak enough oil they can't rust!
I usually paint them during engine build. _________________ Mother Nature is a Mean Evil Bitch! |
Flavio Samba Member
Joined: May 14, 2008 Posts: 414 Location: Madeira Island, Portugal
Posted: Thu Nov 11, 2010 8:44 am Post subject: |
Schwing wrote: |
wow 73 views and 1 reply! drscope you nailed it I was considering painting them with high heat silver/aluminum finish so I might just do that.
Thanks for your help! |
Most silver paints don't hold up well to oil and grease. And a lot of them will simply come off on your hands as you handle the parts.
The push rod tubes aren't really a "show" area, so being pretty usually isn't that important.
I would go with black only because I know most black paints will withstand the oil and that environment better then most silver paints will. _________________ Mother Nature is a Mean Evil Bitch! |
nick696 Samba Member
Posted: Thu Nov 11, 2010 10:23 am Post subject: |
I have painted them black with a heat-resistant paint.
Didn't want them to rust after 1 year you know |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Thu Nov 11, 2010 10:56 am Post subject: |
Keep in mind that you don't need a super high temp paint - They wont be much hotter than your oil. I did a set on one of the cars with silver rustoluem and then a coat of krylon clear to keep the paint from brushing off about 6 months ago and they still look real good. Also there are stainless tubes out there - I have installed 2 sets and like the "windage" style better. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Motorhead55 Samba Member
Joined: August 22, 2007 Posts: 468 Location: California U.S.A.
Posted: Fri Nov 12, 2010 9:52 am Post subject: |
NAPA sells a 500 degree F heat CLEAR. Wash the tubes real good to remove any oils and clear coat them. _________________ 2007 Dodge Cummins Diesel 4x4 6spd stick
1939 WILLYS pickup
1967 Triumph Tiger Cub |
Posted: Fri Nov 12, 2010 10:33 am Post subject: |
Thanks for all the replies guys.
This car will be a driver, not a daily driver but certain things will go through normal wear and tear and thats fine.
That said, I have just put a lot of work into the engine and I wanted to keep it looking good so I appreciate the guidance.
I bought high heat aluminum finish and I plan to do that this weekend, though I must say the clear is a fantastic idea.
I can post pics here when its done for closure, but I'm pretty sure you all have seen a push rod before _________________ Shadetree Westy
http://www.thesamba.com/vw/forum/viewtopic.php?t=657279&highlight=
Single Cab - BBXXVII Long Distance Winner
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Fri Nov 12, 2010 10:36 am Post subject: |
post a pic, I've never had to worry about painting my tubes |
Posted: Fri Nov 12, 2010 4:22 pm Post subject: |
The clear dulls them down quite a bit - but once again, your goal is to prevent rust. _________________ D-Dubya Manx clone - 63 Short pan,1914.
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
billmetric Samba Member
Joined: March 16, 2006 Posts: 1061 Location: Columbus City USA
Posted: Mon Nov 15, 2010 2:13 pm Post subject: |
I installed stainless tubes on the last 1500 I rebuilt unfortunatley 36hps dont have such a thing (yet) its only a matter of time though, in an infinate universe everything will eventually be found to be growing from a plant on another planet somewhere...
but seriously I went thru boxes of used lightly rusted tubes and over half of them were found to have holes in them by the time I got done wire brush derusting them, the stainless ones I bought were very reasonably priced and the only visable difference between them and stock ones is that after 4 years they are still rust free! _________________ There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there... |
Toasty Samba Member
Posted: Sat Apr 10, 2021 5:14 pm Post subject: Re: How do you stop push rod tubes from rusting? |
is there any product you could treat the inside of the push rods with? Some rust preventive? |
Dan22 Samba Member
Joined: August 30, 2019 Posts: 470 Location: Battle Ground, WA
