Firebuggy Samba Member
Joined: November 16, 2010 Posts: 122 Location: Black's Corners, Ontario Canada
Posted: Sun Sep 09, 2018 8:38 am Post subject: Re: Firebuggy's buggy. |
Another thing throwing me off is that everything I read says that too lean and the car pops/backfires out the exhaust. I am wondering if too rich does the same? That is why I changed from 50's back to 55 idles as I figured I was lean, but it made it worse. Is it at all possible I need 47's or 45's? That seems way to small for the size of my engine, but I don't know?! I can't imagine running 60's as the plugs are black, I have already replaced them once, and the smell of fuel in the exhaust is overwhelming.. _________________ 2110 build for buggy
The cost of building an engine yourself is like converting to metric..."Double it and add thirty!" |
joescoolcustoms Samba Member
Posted: Sun Sep 09, 2018 8:57 am Post subject: Re: Firebuggy's buggy. |
What is the rpm of the cam? (What cam is in it)
Popping through carbs is sign of being lean. Popping in exhaust is sign of rich. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Sun Sep 09, 2018 9:08 am Post subject: Re: Firebuggy's buggy. |
W120 cam.
I have only ever heard it once pop through the carb and that was with a mixture screw turned all the way in. _________________ 2110 build for buggy
Posted: Sun Sep 09, 2018 9:31 am Post subject: Re: Firebuggy's buggy. |
Start stepping back on main jets Not drastic, just by 5 lower at a time.
Cam is not too big. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
62kellison Samba Member
Posted: Sun Sep 09, 2018 2:23 pm Post subject: Re: Firebuggy's buggy. |
I think joe has sound advice to try.your issues were my issues.CB performance has a sale on idle jets.i think they r at 3.95 each.thats the cheapest I found them.unless someone knows a better place.they r out of .45,s right now.been hoping some come in soon.i been waiting to see a post that u finally got it running smooth!!..mine drove me nuts.i been getting away with new plugs every week or so,after that they get to carbond up and I start popping thru exhaust and blowing clouds of smoke.just like yours. good luck Sean |
Posted: Sun Sep 09, 2018 3:04 pm Post subject: Re: Firebuggy's buggy. |
45's it is. I'll get some ordered.
Thanks for the help. _________________ 2110 build for buggy
Posted: Thu Jul 18, 2019 2:55 pm Post subject: Re: Firebuggy's buggy. |
Just an update...got the buggy running smooth finally this spring. It was the idle jets causing all the grief. Turns out 50's are too lean and 55's are too rich. I ordered 52.5's from Aircooled and boom...smooth idle, smooth acceleration. No more backfiring or smell of gas. So for anyone out there bouncing between the idle jets in increments of 5, try increments of 2.5 and it may work out for you. _________________ 2110 build for buggy
Posted: Thu Jul 18, 2019 5:00 pm Post subject: Re: Firebuggy's buggy. |
awesome!!!...good to hear!!….I bet u were so relieved... |
Posted: Fri Jul 19, 2019 8:08 am Post subject: Re: Firebuggy's buggy. |
It was great. Put the jets in, set them 1.5 turns out, turned the key, instant perfect idle and throttle response. Of course, I fine tuned them after that. Put on over 200 miles so far. Just taking it easy to see if there are any other lingering gremlins hiding out.
I should mention, I went back to the following as well...
F11 Tubes, 210 air, 135 mains, 32 venturis and 2 1/4" velocity stacks. _________________ 2110 build for buggy
Posted: Fri Jul 19, 2019 9:43 am Post subject: Re: Firebuggy's buggy. |
were those 44 idfs?...I am running 175 air, F11,s, 36 venturis, 135 mains and 55 idle jet.I am at around 800 feet above sea level...I am going to check the color of my plugs soon.i just went to the 55 idle because I had hot looking plugs.. |
Posted: Sat Jul 20, 2019 7:27 am Post subject: Re: Firebuggy's buggy. |
40 Idf's. _________________ 2110 build for buggy
Posted: Thu Jul 25, 2019 6:42 pm Post subject: Re: Firebuggy's buggy. |
Nice pic from the car show tonight.
hillmotorsports Samba Member
Joined: December 27, 2014 Posts: 432 Location: Morrisburg, Ontario, Canada
Posted: Fri Jul 26, 2019 5:44 am Post subject: Re: Firebuggy's buggy. |
_________________ Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!) |
