priss Samba Member
Joined: May 06, 2010 Posts: 348 Location: bradford MA
Posted: Wed Dec 22, 2010 7:01 am Post subject: |
I suppose weber 34 icts would be too small then, on single port heads.
Ugg, i think too much.
Get the engine, make it go, so you can move on to other tasks. Focus priss, FOOCUSSS. |
mightymouse Samba Member
Posted: Tue Dec 21, 2010 11:57 pm Post subject: |
priss wrote: |
Thanks to everyone for their help and concern.
New oil cooler ordered
Full dissasembly under way, inspect and clean everything , re-assemble.
Looking at those thick wall 88s and some dual port heads and 40 dells.
hmm 1800. With heat. It could happen. |
May i suggest 36 dells over the 40s.
40 dells are 2.0L and larger carbs. For a smaller engine 36s would be perfect.
And heat, yes for sure. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
priss Samba Member
Posted: Tue Dec 21, 2010 7:50 pm Post subject: |
i_am_cool_fred Samba Member
Joined: June 26, 2004 Posts: 1743 Location: Benton, AR
Posted: Tue Dec 21, 2010 3:23 pm Post subject: |
wow just read all 4 pages of this thread, the entire time i was thinking bearing failure, it's gotta be bearing failure...then i see the pics of the pistons
dear god how lean was that motor????
it took the motor in my old bus a new owner and a good 50k(total)to do that.
sucks to learn expensive mistakes, believe me i know. one t4 motor later i swear i'll never build another all due to my own ignorance and nothing to do with the motor. hard lessons to learn, but in 5 years (at least with me) you'll look back and say "man what was i thinking" again, i was once in this same boat.
good luck with the new guy and the car. _________________ proud owner of a defunct 1979 sunroof kombi
Brian Denning, as seen on Gearz TV |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Sat Dec 18, 2010 8:08 pm Post subject: Re: glittery oil |
damicotile wrote: |
That much damage and no oil filter.
I wouldn't dare just put on new P&C's and call it a day.
I would split the case, drill and tap all the oil galleys if not already, wire brush the galleys and change all the bearings, assuming the crank isn't damaged or else you'll just be back to doing it all over again.
Am I right or am I right?
I believe you are.... hell I won't use a brand new case, or a used one with out pulling the plugs and scrubing the gallies.... much less one that has had that kind of foreign material pushed throughout the gallies.... _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
BugMan114 Samba Member
Joined: March 22, 2007 Posts: 3744 Location: Ellenwood, GA
Posted: Sat Dec 18, 2010 6:42 pm Post subject: |
X2. there is no way to completely clean out an oil cooler once its been full of metal like that. you MUST replace it. _________________ 1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!! |
Das Dragon Samba Member
Posted: Sat Dec 18, 2010 2:20 pm Post subject: |
I would get a new oil cooler too. Most likely it's full a metal too. _________________ Rest In Peace HamburgerBrad, we will never forget you!
_________________________________________________________
DB3 said:
"Awesome!!!
*********'s constant over-estimation of his own importance never ceases to amaze me."
With *****, "Bullshit Happens"! |
modok Samba Member
Posted: Sat Dec 18, 2010 2:01 pm Post subject: |
Yeah he's right.
Efforts will have to be made to get all that junk out of the oil passages.
I would not go so far to pull ALL the oil galley plugs, but you'll have to get it all cleaned out somehow.
New bearings will be needed too. |
damicotile Samba Member
Joined: September 16, 2004 Posts: 1069 Location: WOODLAND CA.
Posted: Sat Dec 18, 2010 1:54 pm Post subject: Re: glittery oil |
priss wrote: |
so tell me, how screwed am i
tapped for full flow, but havent installed the filter yet, hose connected.
Then let someone setup your timing and carbs for you while you watch. _________________ '73 SB
82x94
W-120 w/ CB light weight lifters
Silicon bronze sleeves
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
A-1 Sidewinder coated
__________________________________ |
modok Samba Member
Posted: Sat Dec 18, 2010 1:40 pm Post subject: |
WOW, that piston is toast.
Something(timing?fuel?cooling?) must have been out of whack to create that kind of damage.
At least pistons are cheap. |
Posted: Sat Dec 18, 2010 12:45 pm Post subject: |
priss wrote: |
Got a call last night. One head off.
#3 piston burned through. #4 blue.
Overheating not covered under warrenty so good choice by me not spending to send it to California. Gary belives i was way too lean, and way to advanced. . |
likely way overadvanced... the engine talks to you, you just gotta listen(Bob Hoover used to "preach" this). your engine should have been *screaming* to you.... _________________
Posted: Sat Dec 18, 2010 12:25 pm Post subject: |
Augiedoggy wrote: |
offrdbus70 wrote: |
Do not Hemi cut the heads! It will ruin them.
MG |
because?... |
Hemi chambers have been proven over and over to have terrible burn character with aircooled heads.
Its a NO NO, but it seems some are still stuck in the 70s and want to do it.
Compression on a STOCK 1600 is 7.5-7.7 to 1
So you cant really mess that up, and dont need dished pistons OR hemi heads to fix it.
Assemble the motor, .050-.060 stock deck, stock 52cc chambers, and you have that compression.
Cant hurt it at all.
But yes timing and jetting can kill any motor. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Augiedoggy Samba Member
Joined: August 25, 2008 Posts: 463 Location: western ny
Posted: Sat Dec 18, 2010 10:44 am Post subject: |
offrdbus70 wrote: |
MG |
because?... _________________ _________________________________________
1970 vw beetle chassied mercedes ssk/gazelle kitcar SOLD
1974 Corvette restorod
1966 Bahama Blue Bug
1964 yellow bug (girlfriends ride) |
offrdbus70 Samba Member
Joined: August 23, 2006 Posts: 512 Location: Pine Valley-SD
Posted: Sat Dec 18, 2010 10:05 am Post subject: |
MG |
spanky324 Samba Member
Joined: September 28, 2006 Posts: 1070 Location: Greeley Pa
Posted: Sat Dec 18, 2010 8:36 am Post subject: |
priss wrote: |
pics worth a grand, at least. Please note, the builder sent me these as progress pics, which is the kind of wonderfull service attention i will happily pay for.
Deck height was so close the piston was almost hitting the valves too. Compression was too high in Garys opinion, not good with todays e10 fuel.
Waiting to see what the 1-2 side shows. Current plan is new 85.5 P&C obviously. Dished bus pistons if available and Hemi cut the heads to reduce compression.
Looking to get a new set of dual webbers and a petronix and a air fuel guage as well. With the way fuel is going it seems a air fuel meter is going to be as important as an oil temp guage. |
How do you tell if you are running lean so i dont have the same problem? |
priss Samba Member
Posted: Sat Dec 18, 2010 8:06 am Post subject: |
Posted: Sat Dec 18, 2010 4:09 am Post subject: |
yes it will be nice to finally know what in the hell happened inside there. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
priss Samba Member
Posted: Fri Dec 17, 2010 12:55 pm Post subject: |
Gary reports The engine is on the stand and being disassembled,
The anticipation is extrordinary........ |
MikeGatch Samba Member
Joined: April 01, 2009 Posts: 445 Location: Valparaiso IN
Posted: Wed Dec 08, 2010 11:27 am Post subject: |
That IS savage. _________________ Daily Driver: 73 STD Beetle.
Road tripper: 82 diesel westy vanagon. (Won't idle work in progress)
Adequately powered road tripper: 73 campmobile.
Bugs with no legs. 1 72 standard and 2 super verts. |
SavageManx Samba Member
Joined: January 16, 2009 Posts: 44 Location: mission viejo,ca
Posted: Wed Dec 08, 2010 9:53 am Post subject: |
Quote: |
Did it all right, still went wrong, such is my life, and it really SUCKS. |
I feel for you man, not to hack your post but I thought i did everything right too
except check the PO's wiring, 2 years of building my first vw and no insurance later
6 g's down the pooper
Keep your head up, and just like everyone else said (Do It Right) |
