CaliforniaDad Samba Member
Joined: May 02, 2009 Posts: 76 Location: High Desert California
Posted: Sun Nov 21, 2010 10:13 pm Post subject: Turn signal relay 65 Bug 12+ Volt system |
I just fixed all the wires on my 65 bug and i'm baffled on the EL-13 flasher. I have 3 pins labeled
X=
P=
L=
I figured out 12+ volt goes to (X) Turn signal switch input is (L)
but what does the (P) connect to? Also how can i get my turn signal indicator bulb on the dash to light up when I use the turn signals. _________________ 1965 VW Bug |
glutamodo The Android
Joined: July 13, 2004 Posts: 26309 Location: Douglas, WY
Posted: Sun Nov 21, 2010 10:16 pm Post subject: |
PXL relays are not for VWs. You need to buy a EF-35 instead. That one has the correct 49,49a and 31 terminals.
If you have to use it, connect X to +12V and your L to the turn signal switch and the dash light. Leave the P unhooked.
This is how'd you hook it up if you used a proper grounded relay - the one that VW started using in 1971-2 and used with only a cosmetic change (got smaller) up to the late 90s.
Posted: Sun Nov 21, 2010 10:28 pm Post subject: |
Thank you, But when I hook up the dash light it stays lite and only blinks when you use the turn signals. But stays on constant if the turn signals are not in use _________________ 1965 VW Bug |
gerg a.k.a. 6volt65
Joined: April 25, 2003 Posts: 5454 Location: Monroe, LA
Posted: Sun Nov 21, 2010 10:48 pm Post subject: |
I used a new 2 prong style generic flasher on my '65 and it worked even ungrounded.
Then I hooked the lead from the indicator in the gage to the flasher.
All worked fine. Maybe I got lucky? _________________ Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
Posted: Sun Nov 21, 2010 11:09 pm Post subject: |
hmmmmm......yeah my indicator light just stays on. _________________ 1965 VW Bug |
Posted: Sun Nov 21, 2010 11:32 pm Post subject: |
Well, that should work... The dash light should have no pathway to ground until you move the turn signal lever away from center. Then it grounds through the turn signal bulbs (very low current there) and lights up until the flasher relay warms up and connects the lights to +12V.
X is actually a "PLUS" and L stands for Load, by the way. And there is no load until the turn switch is engaged. (P is for Pilot but that's not the kind of "backwards" wiring that the VW dash light uses)
It's that warm up phase that make me so I don't like those. With a grounded relay they light up right away outside the car as soon as you go to make a turn. With ungrounded relays the work the other way around - and they have to warrrrmmmm upppppppp before they start to flash. And during that time the only light that's lit is the one in the dashboard, not outside. I've seen some that seem to take quite a while for this to happen. So forget signalling a quick lane change. Granted, some are better than others That's what annoyed me - living in a college town with lots of traffic most of the year, and I was taught to always use my signals. Anyway, I got a REAL VW relay and have never looked back. It's not like they are uncommon, most any VW in a junkyard made from 72-98 has one like that. Later ones are shorter but work the same.
-Andy |
gerg a.k.a. 6volt65
Posted: Mon Nov 22, 2010 12:13 am Post subject: |
OK, so that starts to make some sense because I have the warm up thing going on. Maybe 3 seconds or so?
As I was replying before, I started thinking maybe the flasher has continuity through itself until it opens? But if that is the case, then why is my indicator not always on? I have not tested mine, but what does it actually do? If there is a path through it at rest, then I would expect my indicator on the speedo to stay on until it breaks, but that does not happen.
Figured you may know Andy.
I did ground the body, and nothing improved the warm up issue.
Are you saying that one of the three prongs (on the correct style) is actually a ground for within the flasher, and that style has no warm up period?
If so, I am going to get one and wire it to work instantly. The one I had on the car (before tearing it apart) is a square, plastic type that WW sells. I really want a round, aluminum style to fit the holder and look more vintage. That's why I took a chance on a good old fashioned round, 2 prong unit. _________________ Gerg
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
Posted: Mon Nov 22, 2010 12:58 am Post subject: |
gerg wrote: |
Are you saying that one of the three prongs (on the correct style) is actually a ground for within the flasher, and that style has no warm up period?. |
Terminal 31 is a ground (I often run it to one of the speedometer mounting screws) And while yes, there is a slight warm up period, during that period the lights are lit up outside, and the dash arrow is off. I've had this discussion many a time over the years both here and probably on the RMMW site that I frequented before... And during one of those times a couple years ago I went and threw an XL type flasher in my Baja to see just how long of a delay I'd get. It wasn't nearly as long of a delay as I remembered many years before, lol, but it was still a delay - but it was a pretty fast flash-rate too once it got going.
You know, the very first one I got to replace that PXL type, was a Type 2 unit from the late 60s. One that bolted to the body in the original clip hole that my 62 had when I got it. And it had those terminals 49, 49a and 31. And yes, the lights lit up outside first for a second or so then start to flash.
However after a few years of using that NOS unit they started to get a bit erratic. So I got a diferent one in a pile of stuff stripped from a later VW - a blue colored "electronic" flasher that worked very well. But was a bit quiet to hear it clicking away until I went and taped it to the side of my still-in-place type 2 12V flasher so it would resonate though that metal can - that was well over 10 years ago and I still have set up that way! :
Keep in mind that even though there is no "ground" shown on the factory wiring diagrams in the early 60s, those very much WERE grounded relays! That little omission from wiring diagrams led to enough troubleshooting issues that VW put this note in the factory service manual!
gerg a.k.a. 6volt65
Posted: Mon Nov 22, 2010 1:52 am Post subject: |
Interesting - I guess I'll just use the WW unit I have on the shelf since I will have a dash cover on anyway under the hood.
I was hoping for an old style aluminum can type flasher - I'll keep googling I guess
Found this interesting info somehwere:
What do #'s like 86a mean?
Terminal # = function
15 = Switched positive output from battery
30 = Postive output direct from battery (+)**
31 = Direct to battery negative ( - ), ground
31b = Return to battery negative via switch or relay
49 = Positive input for turn signal flasher
49a = Turn signal flasher trigger power to switch (54); marking used after /5
54 = Turn signal switch contact from flasher (49a); marking used on /5
85 = Relay trigger wire, generally for negative/ground winding on electromagnet**
86 = Relay trigger wire, generally for positive winding on electromagnet**
86a = Path to ground via neutral switch with diode (prevents "NEU" from lighting via clutch switch [contact 86] )**
87 = Normally open relay output, generally**
87a = Normally closed relay output
87b = Second normally open relay output on a seperate throw
D+ = Voltage Regulator/Dynamo (Alternator) positive
C or KBL = power to turn signal indicator light in gauge cluster _________________ Gerg
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
Posted: Mon Nov 22, 2010 2:11 am Post subject: |
gerg wrote: |
I was hoping for an old style aluminum can type flasher - I'll keep googling I guess |
Well, a few years ago I got a "mini" metal can type with the mounting threaded stud on top... its part number 211953183A
For a larger one like I had pictured, you might check out this link Gerg:
http://www.thesamba.com/vw/classifieds/detail.php?id=980463
gerg wrote: |
Oh yeah, forgot to answer - but I don't have an answer, must be for some non-VW application there! 8x-letter series weren't seen on VWs til fuel injection models...
-Andy |
Posted: Mon Nov 22, 2010 5:42 am Post subject: |
Okay great information. I'm going to take a run to the local junk yard and see if I can come up with a correct style TS flasher. Thanks!!! _________________ 1965 VW Bug |
Posted: Mon Nov 22, 2010 5:58 am Post subject: |
This one came out of the fuse/relay panel from a mid 90s Jetta I stripped for parts last winter... it's shorter with a different part number, but still has the same 49, 49a and 31 terminals and works the same as the older ones did.
compare this to the specs written on some older aircooled relays:
Posted: Mon Nov 22, 2010 8:11 am Post subject: |
Oh way cool, I'll have a lot better chance finding a mid-90's VW Jetta at the junk yard than I would a BUG. thats for sure. _________________ 1965 VW Bug |
Posted: Tue Nov 23, 2010 8:30 am Post subject: |
No luck yet _________________ 1965 VW Bug |
Posted: Tue Nov 23, 2010 3:00 pm Post subject: |
As mentioned, the XL type relay should have worked, just not the greatest.
Autozone and other chain stores sell Euro-spec relays too - look for a "35" series flasher - EP-35, EF-35 or FL35 - also FC588T.
Posted: Sat Nov 27, 2010 10:49 pm Post subject: |
Great news, I got it working using this relay from a 93 Jetta.
Thank you for all the help.
gerg a.k.a. 6volt65
Posted: Sun Nov 28, 2010 12:27 am Post subject: |
I decided to just use the square flasher I got from WW since i will have a dash cover on under the hood.
Nice work, glad it is working for ya! _________________ Gerg
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
Posted: Sun Nov 28, 2010 8:06 am Post subject: |
gerg wrote: |
I decided to just use the square flasher I got from WW since i will have a dash cover on under the hood. |
Okay. I also remembered later on that there was somone on eBay selling Bosch flahsers in the big 12V Type 2 can for like 10 bucks each (but like that much again for shipping) and had a few of them left.
Quote: |
Nice work, glad it is working for ya! |
ditto!
Andy |
lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Sun Nov 28, 2010 9:10 am Post subject: |
Gerg how is your WW flasher working out for you. I've installed one too but the but the thing I don't like is it Flashes at about 90 MPH, I wish it was a little slower. Also I'd love to stop buy and check out your Beetle one of these days. I'm in N. LV. Whoops I just remembered your off to Colorado to pick up a Convertable. Be Safe |
gerg a.k.a. 6volt65
Posted: Sun Nov 28, 2010 3:52 pm Post subject: |
Car is getting headliner now so I have not tried it.
Will let you know. _________________ Gerg
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
