wolfej1 Samba Member
Joined: August 15, 2005 Posts: 679 Location: North Royalton, Ohio
Posted: Mon Nov 22, 2010 10:38 am Post subject: Part Number |
82 westy......
Anyone have the number of the rubber piece that connects the hoses from the Deceleration Air valve and the Brake Servo to the Intake manifold? It is a rubber "tee" so to speak.
I was hoping to get a direct replacement as opposed to rigging something up.
Thanks KF
On another note, anyone ever had a problem with brake fluid getting sucked into the intake manifold? _________________ 1982 Westy
2004 KDX200
2008 Kawasaki KLR 650
1979 Yamaha DT 175
1995 Toyota 4Runner |
nod7 Samba Member
Posted: Mon Nov 22, 2010 10:46 am Post subject: |
If I can't find a part number, I go here; http://www.vagcat.com/epc/cat/vw/T2/1987/65/
I had to create a login for the forum to use the catalog (there's a link at the top) and then click back to the catalog (when your in the forum there's a link to the catalog at the top)
Once I get the part number, I do a google search for that number and it usually comes up some place. Hard to get ones often end up coming from websites based in Germany.
I saw lats of O-Rings & Gaskets etc when I was browsing http://www.airheadparts.com/ yesterday
Hope this was helpful
-nod7 |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17014 Location: Retired South Florida
Posted: Mon Nov 22, 2010 11:49 am Post subject: |
I believe the part number you are looking for is 022 133 083 D. I can't be sure though. Yes, I have seen brake fluid in the intake before, but it is not a common failure. The master cylinder will weap enough fluid out the back of it to eventually fill the booster to the point where it can draw brake fluid into the engine. If this is the case, the booster may have some other problems. You at least need to pull the master cylinder back from the booster and clean the brake fluid out. Brake fluid is water soluable, so you might want to rinse the booster with water. Either way, it is a mess. Bummer. _________________ ☮️ |
