virtanen Samba Member
Joined: January 08, 2006 Posts: 1462 Location: Finland
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Tue Nov 23, 2010 7:49 am Post subject: |
Very nice, a much needed part. _________________ John Henry
'57 Deluxe
'56 Single Cab |
murray7010 Samba Member
Joined: September 26, 2008 Posts: 146 Location: Salado, TX
Posted: Tue Nov 23, 2010 7:59 am Post subject: |
i need the outer lower section like that as well...lol _________________ 1951 Deluxe Sunroof Beetle (11C Model)
Follow the resto up to date on Instagram @SplittyMcFiddyJuan
10/2013----->http://www.youtube.com/watch?v=B2dHtL-_80g |
runsplit Samba Member
Joined: September 18, 2005 Posts: 118 Location: REUNION ISLAND
Posted: Tue Nov 23, 2010 9:08 am Post subject: |
Too late. Surely for my next split !!!!!!
Great work Mika. |
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1773 Location: Finland, Jakobstad
KäferKrieger Samba Member
Joined: June 20, 2010 Posts: 331 Location: Pacific Woodpile
Posted: Mon Nov 29, 2010 8:10 am Post subject: |
Hopefully they'll line-up much better than those that Franci sells. _________________ I contend that we thinking people should,
"Round-up all religious humans and put them on one island together.
An island where they can permanently sort out their indifferences & insecurities once and for all." |
beetlekey Samba Member
Posted: Mon Nov 29, 2010 12:34 pm Post subject: Re: Repair panel for ribbed doors, the first sample |
virtanen wrote: |
Under development inner panel for ribbed door, made of 1 mm thickness sheet metal.
Cool
Mika think about a small peace without the corners.
I need the middle part like 30 cm.
Marcus |
Posted: Mon Nov 29, 2010 8:37 pm Post subject: |
Mika-I'll buy a pair of runningboards and 1 door bottom when you are ready.
I'm very happy your bottoms have the sharp corners of earliest ribbed doors.
I almost repaired a '49 door with the bottom from a 53 donor-door, but noticed its corners were rounder than the splits. I will wait for you _________________ I contend that we thinking people should,
oval56 Samba Member
Joined: July 21, 2003 Posts: 1309 Location: oktoberfest maintown
Posted: Tue Nov 30, 2010 12:59 am Post subject: |
fantastic, if they ar ready for sale, let it me know, my heb needs a set left and right _________________ www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com |
oval56 Samba Member
Posted: Tue Nov 30, 2010 1:48 am Post subject: |
virtanen wrote: |
Not yet, but I will inform. I have a plan to make also lower hinge support part and window regulator bracket which are attached the inner panel. |
sounds good.. im my case i'm intersted in the doorpart only to get my doors back to perfect shape...
but on the driversside, the lower hing part could be also interested in my case.....
let me know when you are ready... perfect work for winterseason 2012/2013 _________________ www.oval56.com
www.dbkvw.com |
Posted: Fri Mar 04, 2011 9:14 am Post subject: |
Some progress here, more accurate dimensions, more details. Also with outer repair panel section.
The next step to make hinge support parts and window regulator support piece. Then repair couple of split doors to verify dimensions and make possible changes.
_________________ Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects |
Posted: Fri Mar 04, 2011 9:18 am Post subject: |
Very nice!! Very much needed part for restorations. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Fri Mar 04, 2011 2:41 pm Post subject: |
Amazing. Would the contour of the corners be correct for a '55 oval? I need those bad. I like that your making correct replacement inner/outter skin sets as well. Whats the prices going to be? _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
50Splitman Samba Member
Posted: Fri Mar 04, 2011 6:52 pm Post subject: |
These are perfect!!
When are they going to be available, and what is the price?
Also, are any of the other split sheet metal parts you have listed online ready to buy? I'm interested in the rear body mounts that also have the inner fender well section attached for my 50 standard split.
Thanks! |
Posted: Sat Mar 05, 2011 5:34 am Post subject: |
Great! Please just keep us updated when we can order the door repair pieces, and I'll put in a a single order for a driver's side door set, plus the rear support pieces.
Thanks! |
ZwitterND Samba Member
Joined: September 08, 2005 Posts: 1451 Location: Fargo, ND
Posted: Sat Mar 05, 2011 10:54 am Post subject: |
y'all shore do might fine work! _________________ Bill |
