theadmiral1000 Samba Member
Joined: September 27, 2007 Posts: 251 Location: Bothell, WA (near Seattle)
Posted: Tue Nov 23, 2010 3:33 pm Post subject: Draining fuel from Kadrons |
Is there a way to do this without pulling the carbs off? _________________ Zach S.
71 Ghia
75 R75/6 |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Tue Nov 23, 2010 3:36 pm Post subject: |
Disconnect the fuel lines and run the engine until its out of gas. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Nov 23, 2010 3:38 pm Post subject: |
The problem is that the carbs have bad gas in them which the engine will not burn. _________________ Zach S.
71 Ghia
75 R75/6 |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Tue Nov 23, 2010 4:31 pm Post subject: |
Take the 6 carb top screws out, remove the top to one side and siphon the gas outta there. Takes about 3 minutes, done it a few times myself. _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
Posted: Tue Nov 23, 2010 4:44 pm Post subject: |
Thanks for the advice. _________________ Zach S.
71 Ghia
75 R75/6 |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Tue Nov 23, 2010 4:48 pm Post subject: |
take them off. if the gas is that old you might want to clean them out anyway? depends what kind of gas was left in there.?and how long?the gas here in cali. turns into a hard white substance which is hard to get out. must be the junk they put in the gas here? since the 90's? i was able to start a 59 bus with a full tank of gas from the 70's? or so. you cant do that today with the crap they give us! it goes bad in one year.! take them off it's not hard. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Tue Nov 23, 2010 6:37 pm Post subject: |
Seriously, unless they have not been on the car real long, I would just pull them - only 2 nuts per carb. Then you can replace fuel lines if needed - can clean them out well, etc. This is one of those situations that the quicker and easier solution is going to bite you in the ass later.
Do it right the first time - pull the carbs, clean the hell out of them and then you know what you are working with. This is my creed and I am still kicking myself in the ass for not "doing what I say" with my wifes 61's front brakes. I ended up pulling them apart 2 times before I bit the bullet and redid everything (which I normally do). _________________ D-Dubya Manx clone - 63 Short pan,1914.
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Thu Nov 25, 2010 7:40 am Post subject: |
Undo the 14 or 15mm brass nut on the side of the float bowls and they will drain... |
grimace007 Samba Member
Joined: August 30, 2006 Posts: 2673 Location: swampville, florida
Posted: Thu Nov 25, 2010 9:09 am Post subject: |
just keep an eye out for the rogue kadron screw that likes to fall out and down the intakes!!!! _________________ Brian
68 sedan
Dallas Air Coolers
perrib wrote: |
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time. |
cr@M wrote: |
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory. |
