campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Wed Mar 14, 2018 5:06 pm Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
Time to finish off the reduction boxes.
I had collected a full set of NOS reduction box bearings - FAG - all marked "Germany" on the bearings themselves - not sure it matters in the big picture but whatever.
Bearing puller tool.
Backing plates & axle seals.
I decided to leave the shocks factory paint. These are NOS rears dated 3/62.
I also torqued down the reduction box bolts and the rear cradle bolts. |
Posted: Wed Mar 14, 2018 5:13 pm Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
On to the brakes - I picked up these "oversized" shoes from the VW parts museum in Germany 2003 and figured it would be nice to use them on this project.
I have never riveted brake shoes on before so if someone notices an issue they think might be unsafe feel free to post it up. The process seems pretty straight forward - the shoes came with the rivets. The rivets are steel but they are easy to install. I modified an old arbor press and a punch die. Seemed to work fine.
They seem to fit the drums well, which were also turned.
I probably should put on a mask and chamfer the ends before I install them. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Wed Mar 14, 2018 6:56 pm Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
campingbox wrote: |
I have never riveted brake shoes on before so if someone notices an issue they think might be unsafe feel free to post it up. |
Looks totally factory to me even like you arced the shoes to match. |
Posted: Wed Mar 14, 2018 7:16 pm Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
BarryL wrote: |
campingbox wrote: |
The workshop manual says to use oversized shoes when you turn it to the first cut. It seems like they line up pretty nicely with the drums.
New German wheel cylinders:
I knocked them apart and cleaned them out and regreased them.
They went back together a little easier than I'm used to, but I've never used that grease before. Hopefully they seal up nice and last a long time.
One side is done.
29 part # lug bolts.
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Wed Mar 14, 2018 7:28 pm Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
campingbox wrote: |
If this is what i think it is, ATE blue brake paste, then they should be just fine. The VW guys i trusted 30 years ago swore by it. _________________ regards
Uli
obus Samba Member
Joined: March 08, 2001 Posts: 11070 Location: just off Garden State Parkway Exit 81
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Wed Mar 14, 2018 8:31 pm Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
What a sweet Westy!!! Love the curtain fabric and everything else too! Killer work as always! _________________ Brandon |
Posted: Wed Mar 14, 2018 9:19 pm Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
nice |
npbusguy Samba Member
Joined: February 08, 2006 Posts: 1658 Location: Budapest, Hungary
Posted: Thu Mar 15, 2018 12:32 am Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
Looking good Greg, glad to see some progress on this beautiful bus. |
perello Samba Member
Joined: April 15, 2005 Posts: 829 Location: where social security comes for free
Posted: Thu Mar 15, 2018 1:23 am Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
As usual in Greg you are doing a fantastic resto!
Just as a side note, the brake pads you are using do have asbestos. In my bus I also wanted to use rivets and was strongly discouraged to do so as highly unsafe. _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Thu Mar 15, 2018 6:19 am Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
campingbox wrote: |
Are these split case specific lug bolts? _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
derRHDmeister Samba Member
Posted: Thu Mar 15, 2018 6:21 am Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
Okie Adam wrote: |
campingbox wrote: |
Are these split case specific lug bolts? |
#29 signifies barndooor/wolfsburg production line (pre 55) _________________ Ask not what your bus can do for you, but ask what you can do for your bus.
unclespanky wrote: |
Piercy could dip those wheel cylinders between his cheek and gums and spit them out rebuilt. |
Check us out @
Instagram: DeafVolks & BarndoorBuggy |
Posted: Thu Mar 15, 2018 6:25 am Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
derRHDmeister wrote: |
Okie Adam wrote: |
campingbox wrote: |
#29 signifies barndooor/wolfsburg production line (pre 55) |
As soon as I read your response it made perfect sense. I knew I'd heard of 29 part numbers before! _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Posted: Thu Mar 15, 2018 6:39 am Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
perello wrote: |
Just as a side note, the brake pads you are using do have asbestos. In my bus I also wanted to use rivets and was strongly discouraged to do so as highly unsafe. |
Thanks!
Why did your guy feel riveted brake shoes were unsafe?
I would trust 10 mechanical fasteners over any type of glue any day.
I think the advantage of bonded shoes over riveted shoes is that they are faster to install and you can make use of the entire pad thickness before you experience any metal on metal contact.
I've heard that riveted shoes dissipate heat better, wonder if it's true?
I can't count the number of times I've seen where a bonded shoe has failed when I've needed to pull the drum on a bus which has sat out in the woods for a number of years.
I wonder if the old asbestos linings will stop better than the low carb version you can buy today from various parts suppliers? |
Posted: Thu Mar 15, 2018 6:46 am Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
Okie Adam wrote: |
Okie Adam wrote: |
campingbox wrote: |
As soon as I read your response it made perfect sense. I knew I'd heard of 29 part numbers before! |
I'm not sure how late those lug bolts went. I think they might have been fazed out around the end of '55. I don't think they made it to the end of the Wolfsburg run.
There was a very low km (8000 km's?) neon green singlecab found in Canada a few years back which was dated 1/56 and had a full set of 29 lug bolts. Our 1/56 bus had 10 of them on the front too. I've seen a number of similar date buses with the flat lug bolts with only a vw logo on it. Easy item to change, but an 8000 km singlecab painted lime green with matching lime green lug bolts was enough to convince me. |
Posted: Thu Mar 15, 2018 6:57 am Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
campingbox wrote: |
Okie Adam wrote: |
Okie Adam wrote: |
campingbox wrote: |
I'm going to have to look at the lugs I have stashed for my 55 now. I remember them being flat top but I'm not sure if they have the part number on them. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Clara Samba Member
Posted: Thu Mar 15, 2018 7:59 am Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
The 29 part numbers were used through 1953. I think VW started using the 9 digit part numbers for 1954. There are plenty of bd parts that came new with the 9 digit part numbers, a Jan 55 bus would have the later part numbers on almost everything. But everything (original to the bus) on my June 53 has the early 29 style p/n on it.
The 29 p/n lug nuts were installed on new buses somewhat into 1956. Why for over a year later? Had they ordered a huge pile of lug nuts before changing the system?
Did the lug nut manufacturer just not get the memo?
Who knows, that's how it was. Anyhow, in the spirit of David Mayes, early p/n lugs correct for this bus was used.
IIRC, the Feb '56 high roof Acme panel from Alaska also had 29 part number lug nuts. https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
then I think they later in 1956 went to the 211 ... ... p/n ,
then the flat w/o number,
then the dimpled |
Posted: Thu Mar 15, 2018 8:23 am Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
Another great mystery of the VW world and one I will obsess about even though hardly anyone will ever see my lugs!
I just went and looked at my 55 and it has a mismatch collection of lugs on it now. Everything from 29 lugs, VW stamp only lugs, and dimpled HWE lugs. I can't wait to get home and inspect the set I have set aside.
Sorry for the hijack! Now back to the regularly scheduled yellow and tan beauty! _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
velvetgreen Samba Member
Posted: Thu Mar 15, 2018 10:45 am Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
I have a set of those Jurid (cough cough asbestos brakes but have no stell rivets. If you have any spares could you please post up what they look like or some measurements?
Many thanks! |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Thu Mar 15, 2018 11:00 am Post subject: Re: Yellow & Tan '56 Subhatch Westy - 20-147419 |
I would have used some sweet chrome backing plates but otherwise it looks great, Greg! _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
