1967 Bus Question Can someone decipher the tag for me?
gospelpreacher
gospelpreacher is offline
PostPosted: Sun Nov 28, 2010 1:40 pm    Post subject: 1967 Bus Question Can someone decipher the tag for me? Reply with quote
These are the numbers from the tag. Someone told me that it may be a deluxe because it has the clock in the dash.
Your help is appreciated.....
08N
425 081 114 130 139
UV 2512 381370 7054011
hazetguy
hazetguy is offline
PostPosted: Sun Nov 28, 2010 1:53 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/archives/info/id.php
and
http://www.thesamba.com/vw/archives/info/mcodest2.php
Your crystal ball ain't so crystal clear
Parts and mechanical restoration services available. I restore and rebuild fuel pumps, distributors, spindles, etc.
Check my ads or send a PM.
srfndoc
srfndoc is offline
PostPosted: Sun Nov 28, 2010 2:06 pm    Post subject: Reply with quote
http://www.vw-mplate.com/mcode_draw_mplate.php?id=5310
Evan's Spreadsheet for Bus RPM, based on gearing & tire size (ODS Format)
"The world is in no hurry for another painted bus."
-Maurice
gospelpreacher
PostPosted: Sun Nov 28, 2010 3:26 pm    Post subject: question Reply with quote
Should this bus have the deluxe trim?
Adam
Adam is offline
PostPosted: Sun Nov 28, 2010 3:34 pm    Post subject: Reply with quote
Hmm... says it has 6 pop out windows, Deluxe without sunroof and roof windows. Is it a 13 window deluxe? I would say yes it should have deluxe trim.
Split 66'
Split 66' is offline
PostPosted: Sun Nov 28, 2010 3:36 pm    Post subject: Reply with quote
Yes, you should have the beltline trim.
Your Bus:
1967 Deluxe 13 Window
Born November 8, 1967
Walkthru - Split Front Seat, 2/3 short middle seat
Arrived originally in Boston
Velvet Green/Pearl White - Interior Mesh Platinum/Platinum Silver
What your interior looked like originally (showing full middle seat though, not short):
EDIT: Your bus says it was made in November of '67 but you are missing the rear reverse lights, interesting:
"OG = Original German" -- TheSamba.com dictionary
gospelpreacher
PostPosted: Sun Nov 28, 2010 4:19 pm    Post subject: no reverse lights Reply with quote
[quote="Split 66'"]Yes, you should have the beltline trim.
I'm wondering why it doesn't either. The engine compartment still has some of the original green paint....?????
Split 66'
PostPosted: Sun Nov 28, 2010 4:25 pm    Post subject: Reply with quote
It looks like when they did your McPaint job, they filled the holes for the rear emblem and the beltline trim too, is that the case?
If you look inside your engine compartment, does it look like it ever had the rectangular reverse lights over the tail lights? Is the OG green paint untouched back there?
VolksFire
VolksFire is offline
PostPosted: Sun Nov 28, 2010 6:32 pm    Post subject: Reply with quote
The bus was not built November 67. It was built November 8, 1966 (early 67 model) and does not have reverse lights because early 67's didnt have them (mostly, there are some exceptions).
The other info provided is correct, and yes, your trim and rear script holes have been filled. Also, the rear bumper is incorrect, I'm sure you're aware.
Jahnai Pearson - VW Restoration Technician
60 Double Door Panel
63 Double Cab
63 Single Cab
67 SO42 Westfalia
73 Thing
76 Kombi
82 Westfalia Deluxe
82 Rabbit L
84 Jetta Diesel
95 Golf III
gospelpreacher
PostPosted: Sun Nov 28, 2010 7:08 pm    Post subject: Reply with quote
I wasnt' aware of the bumper being wrong. I'm very new to the vw bus hobby. I've only been involved for about a month and a half. I've owned 4 busses so far.
I did see by doing the research that you are correct in saying that it is an early 67 model. As far as the holes for the vw emblem. There are 4 holes there, it's just hard to tell in the grainy pic. The emblem is inside the truck, but it looks like someone stepped on it a time or two.
I guess I need to go look at some bumpers so I can see what I need to buy. I can take that one off for now.
I can't wait to start stripping the paint from this bus! I do want to paint it back original. I'm hoping to find the original holes for the deluxe trim as well...
I appreciate everyone's help here on the Samba. Great Site and great people!
tasb Premium Member
The Distributor Distributor
tasb is offline
PostPosted: Sun Nov 28, 2010 7:38 pm    Post subject: Reply with quote
Leave the bumper on until you find a replacement. You may also be able to trade bumpers the one you have now belongs on an earlier bus. Do a search in the classifeids under "rear hatch script" for split bus and you will find a selection to choose from.
Roads Scholar & distributor restorations
1956 oval third owner 36 hp- slow drag Champion 2012, 2014, 2015, 2017
1957 Kombi low mileage 36 hp governor equiped M 178 Slow Drag Winner 2014, 2015, 2018
1960 sunroof beetle owned since 1991 36 hp
1965 hrdtop Deluxe Microbus owned since 1990 M 620 factory 12 v 1500cc
VolksFire
PostPosted: Sun Nov 28, 2010 8:22 pm    Post subject: Reply with quote
x2. Leave the bumper for now til you find a replacement. What you have on the rear is a 59-65 Slash (or slant) end bumper. What you should have is a 66-67 diamond (or point) end bumper (also seen on late 65's). It has ends that are like your front bumper, pointed vs. slant. In general, rear bumpers are more pricey than fronts. And although the pointed 66-67 bumpers are 2 year only, they are actually easier to come by and slightly cheaper than the 59-65 slant bumper which you have. I'm sure someone that has the incorrect 66-67 rear on their bus would be more than glad to trade for your slant rear.
One more thing, to be specific, you need a deluxe version of the 66-67 bumper that has the trim, like your front one. This will be a bit trickier to find. You'll get by with a non-deluxe one, but if you want to be 100% correct, you need to have the trim. The rear you have right now is not a deluxe version either. Its just a blade, missing the overriders.
63 Double Cab
63 Single Cab
67 SO42 Westfalia
73 Thing
76 Kombi
82 Westfalia Deluxe
82 Rabbit L
84 Jetta Diesel
95 Golf III
brettsvw
brettsvw is offline
PostPosted: Mon Nov 29, 2010 11:18 am    Post subject: Reply with quote
If you like the the slash bumpers over the pointy, I would keep the slash bolted on.
Bumpers can always be changed. Slash bumpers flow with the wheel arches.
My 59 kombi build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=635003&highlight=
My buggy build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=558601&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
