salathe Samba Member
Joined: December 12, 2012 Posts: 4 Location: San Diego
Posted: Sun Jun 05, 2022 8:44 am Post subject: Fuel Pump Stays on w/ Ignition in ON position |
Howdy -
Trying to get my 87 Syncro started after a 4 year period of sitting and a second notice from the HOA regarding it being not operable and an eyesore.
What I've done:
1. Drain gas, add new with Sea Foam.
2. Had a faulty ignition switch, adding new one.
3. Bench tested relays, they 'seem' be good.
4. Diagnosed faulty fuel pump, added new one.
It still wont start, so I have more tests to do today, but I noticed that the new fuel pump stays on (10+ seconds) with the ignition in ON. It turns off when the ignition is off.
Any ideas what might be causing this?
TIA |
RawUmber Samba Member
Posted: Sun Jun 05, 2022 9:27 am Post subject: Re: Fuel Pump Stays on w Ignition in ON position |
Given that someone didn't jumper the fuel pump to stay on (bypassing ECU), the pump always being on is likely a problem with the ECU. Normally, Vanagon water cooled ECUs (Digijet, Digifant) start the fuel pump under three circumstances:
The ignition just turned on (ie, the ECU just turned on): ECU turns on fuel pump for ~1s, turns it back off.
Starter engaged: ECU turns fuel pump on as long as starter is engaged
Engine cranking or running (ie, ECU receiving pulses from distributor hall sender): ECU turns fuel pump on.
If the problem was limited to the fuel pump always being on, I would expect it to start. So maybe ECU has other problems or the vehicle does. Trying a known good ECU could help diagnose the problem. |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4024 Location: Redwood City, California
Posted: Sun Jun 05, 2022 7:03 pm Post subject: Re: Fuel Pump Stays on w/ Ignition in ON position |
Is it possible you put the relay in the wrong location? Don't the early ones use 2 separate relays?
Not sure here, just grasping at straws here.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
