dameeser Samba Member
Posted: Wed Dec 01, 2010 7:16 pm Post subject: Vanagon front seat stuck on the track. |
So my driver seat is stuck. Won't move but an inch in either direction. I'm wondering if there is something stuck in the track that is preventing me from moving the seat.
OR
my frustration that led to a manic episode where I was sitting on the seat, furiously jerking the seat back and forth somehow bent the track.
Any Ideas on how I can fix this. The tracks seem to be welded to the frame.
OH, it's an 89 Vanagon Carat |
Steelhead Samba Member
Joined: February 25, 2007 Posts: 1791 Location: Kentfield, CA
Posted: Wed Dec 01, 2010 7:30 pm Post subject: |
try having one person sit on it and pull the handle up and one person sit behind (remove jumpseat, put coolers or something in front of bench - for leverage) and push the bottom of the seat with your feet. If its just stuck, it will slide. If the lever isn't actually working, you will know it. _________________ '77 Bay Window / '89 Caratsburg (aka. the Stormtrooper) |
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Wed Dec 01, 2010 11:02 pm Post subject: |
I recently had one of the small bolts that holds the seat to the rail come loose and jamb into the bottom rail, resulting in a completely locked up seat. Take a flashlight and look into the rails to see if you wound up with the same issue. I used a thin piece of steel strapping to lift up the bolt long enough to slide it forwrd and remove the seat and then replaced it with a new fastener. I also took the opportunity to put some locktite on all of the bolts that hold the rail to the seat while I had it out. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
GMByers Samba Member
Joined: December 07, 2008 Posts: 642 Location: Retired in NW PA
Posted: Wed Dec 01, 2010 11:59 pm Post subject: |
What they said plus I generously sprayed the tracks with penetrating oil. I took the seat completely off then cleaned all of the dirt, dust, and junk out of the tracks. _________________ And then there were two...downsized to 83 Doka &
74 Thing. |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3414 Location: OR & CA (Oregon/California)
Posted: Thu Dec 02, 2010 10:46 am Post subject: |
I have the same issue with my seat. It slides forward easily but very difficult to move it back, every time. I put some grease and oil on the rail but it doesn't help. Anytime I move the seat forward I have to get help from my son to move it back. He sits on the seat, pull the lever and push hard on his legs while I grab the seat from the back and pull...
no solution found yet..
Volksaholic Samba Member
Joined: December 26, 2005 Posts: 1771 Location: Salt Lake City, Utah, USA
Posted: Thu Dec 02, 2010 11:05 am Post subject: |
Luckily I've got my driver's seat working well, but the passenger seat sticks like that and I've yet to find a solution. I've cleaned both sides and replaced the plastic "rails," and I've tried both paste wax and grease to lube them up. The passenger seat doesn't generally need to move except when I need to get to the battery, but it frustrates the hell out of me that I can't get it working more smoothly. Conceptually is pretty simple, so I don't know why it's so problematic.
Paul _________________ 1988 Wolfsburg Edition, 2001 Subaru EJ251 |
kamzcab86 Samba Moderator
Posted: Thu Dec 02, 2010 12:22 pm Post subject: |
Volksaholic wrote: |
...and replaced the plastic "rails," |
Ironically, my passenger seat slid back and forth just dandy, aside from a slight wobble, until I replaced those plastic guide pieces. Put the new guide pieces in, added some lube and the seat now barely moves. Next time that seat is removed those guide pieces are coming out! _________________ ~Kamz
2016 Golf GTI S
BushChicken Samba Member
Joined: March 11, 2010 Posts: 250 Location: California
Posted: Thu Dec 02, 2010 1:09 pm Post subject: |
kamzcab86 wrote: |
Ironically, my passenger seat slid back and forth just dandy, aside from a slight wobble, until I replaced those plastic guide pieces. Put the new guide pieces in, added some lube and the seat now barely moves. Next time that seat is removed those guide pieces are coming out! |
I'm sure someone will correct me if I am wrong, but, I thought there was only supposed to be one of those plastic guide pieces per seat, on the outboard rail.
Perhaps this is contributing to the difficulty? |
Posted: Thu Dec 02, 2010 2:57 pm Post subject: |
BushChicken wrote: |
kamzcab86 wrote: |
I'll have to check that out... I put it back the way I found it, I think. But then it's been a couple years since I did it AND they didn't work properly before that.
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Thu Dec 02, 2010 4:21 pm Post subject: |
Sometimes the plastic pieces wear, bunch up and jam, or the seat gets cocked on the rails. I removed the plastic pieces and slathered some grease on the rails. Don't move the seats much, but they work fine now.
Aloha
tp |
indytriple Samba Member
Joined: April 27, 2009 Posts: 710 Location: Brownsburg, Indiana
Posted: Thu Dec 02, 2010 8:27 pm Post subject: |
kamzcab86 wrote: |
I researched this a while ago, and that's what I found as well. Only one per seat, outboard. _________________ "See The Glass As Already Broken."
87 Vanagon Westy Auto Bostig
www.bluegrassbicyclecompany.com |
Posted: Thu Dec 02, 2010 9:15 pm Post subject: |
Well, the seat originally had two pieces, both being broken, which is why the seat wobbled. I bought the guide pieces from VC and their description says: "These are the factory bushings that slide between the seat and the rail to prevent seat from rocking and rattling. Will fit all Vanagon's 1980-1991 - there are 2 per seat (4 per vehicle) price listed is for each. " I'll have to double-check ETKA and see what the official VW count per seat is, but as far as I know, it's two per seat. The new ones are simply adding to the thickness between the rails (they are slightly thicker than the old, worn, broken ones I pulled out) and, therefore, cause resistance when trying to slide the seat. The driver's side, without any guide pieces and fresh grease, slides beautifully and doesn't even wobble much. _________________ ~Kamz
2016 Golf GTI S
Posted: Fri Dec 03, 2010 2:16 pm Post subject: |
Just to follow up: I took a look in ETKA and it states 1 guide piece per seat and shows it on the outer rail; you guys might be right! So, I'll remove one of the guide pieces in the near future and see what happens. _________________ ~Kamz
2016 Golf GTI S
