Aynthm Samba Member
Joined: July 07, 2010 Posts: 1315 Location: Beaverton, Oregon
Posted: Fri Dec 03, 2010 12:52 am Post subject: Defrost Assembly Made Easy |
I've read what has been posted about this subject. Here is how I made mine. This is for those with the center defrost vent. Mine is a '66
8' piece of DWV Pipe Need 2@ 1' each 1.5" (ID)
7' length of Pool Hose 2@ 12" and 2 @ 2.5' 1.25" (ID) (you need to custom measure)
1' Clear vinyl hose 1" (ID)
You'll have 6' of the DWV pipe left over for use on something else.
When cutting the Pool hose for the center, I had to make the passenger side longer to fit up and over the glove box. The driver's side was shorter.
Measure these hoses first so you don't end up wasting material, it's $3.27 a foot.
Make sure you clean out any debris in the channel and put the white pipe down there. Put the "Y" adapter on and fit the hoses. Take your time and get it right the first time. I use the 1" clear hose as an adapter for the center vent so I would not need 3 different sizes of hose. I used just one size hose for the vents and the pipe for the bottom of the channel. Everything fit perfectly. This will outlast the fiber/alum hoses I hope.
The total cost was $28. No shipping charges, got the hoses at Home Depot.
Good luck.I just made this edit The "Y" fit loosley in the white pipe so I superglued a small piece of innertube onto the bottom of the "Y" that will make it fit snugly into the white pipe and not wiggle at all. I only used the rubber around 1/2 of the circumference of the "Y" because if I used it entirely around...It would not fit in. Some alum tape might be good to put around all connections when final assenbly is complete to seal out any leaks. ..[/b][color=red]
anthracitedub Samba Member
Posted: Fri Dec 03, 2010 7:55 am Post subject: |
| Let us know how well these materials hold up to the heat…namely where they connect to the heater channels. Looks like a pretty clean set up, but I'm just concerned about the heat melting the materials….probably be alright, but over extended driving periods things get pretty warm. My 62 has the original ducts but uses a 71 DP engine, with the larger, fan it has more output….it actually cracked the windshield on the inside from the defroster. When I noticed the crack, I put my hand on it and the glass was very hot. So now, with a new windshield, I have to be mindful of how long I keep the heat on…sometimes I'll stuff a rag in the vent (driverside) to stop the heat….my car gets uncomfortably hot. I thinks its funny how much people spend on heater boost systems, hack in fans and all that jazz…when really you just have to address the stock setup and make sure your seals are good. Carpet and padding also are big bonuses for holding the heat in the car. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16813 Location: State College, PA
Posted: Sat Dec 04, 2010 12:50 pm Post subject: |
| Quote: |
| Let us know how well these materials hold up to the heat…namely where they connect to the heater channels. Looks like a pretty clean set up, but I'm just concerned about the heat melting the materials |
X2 _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
fluxcap Samba Member
Joined: February 07, 2006 Posts: 1969 Location: Newnan GA
Posted: Sat Dec 04, 2010 2:24 pm Post subject: |
I've actually been using that same blue/black hose and pvc method on my car for about 2.5 years now. I have aftermarket heater channels (not very good ones) and the outlet pipe at the bottom of the a-pillar is resting pretty much right against the inside of the a-pillar. There was no way I could ever have gotten the paper hose over the heater channel outlet pipe.
I found pvc pipe that fit super snug into the outlet pipe. I tapped a small screw into it about 1.5 inches that rests on the outlet pipe. This keeps the pvc from ever falling all the way into the heater channel and bottoming out thus cutting off the warm air flow. I then ran the blue/black hose over the pvc and up to the outlet connection at the window.
The blue/black hose was labeled as being for a hottub so I figured it would handle hotter temperatures. Used it through two full winters so far and it has worked great. Had it out a few months ago while working with my wire harness, and it was still in the same shape as when I installed it. Looks to have held up to the heat just fine. _________________ Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black." |
Aynthm Samba Member
Posted: Sat Dec 04, 2010 2:28 pm Post subject: |
| Good to hear that it'll hold up. My car is months away from being ready. I just saw that flexible hose and wow, just what I was looking for. Thanks. |
Duude Samba Member
Joined: October 17, 2010 Posts: 9 Location: Olympia, WA
Posted: Mon Dec 06, 2010 10:00 pm Post subject: Thanks for the defroster info |
| Thanks for the info. This is great! I have been looking for a solution for years and this makes great sense. The price is right and it seems simple enough. I added one of the heater assist kits under the rear seat and it cooks me out and it will be awesome to have the windows clear too. |
Aynthm Samba Member
Posted: Tue Dec 07, 2010 1:43 am Post subject: |
| I made an edit to the original post adding the rubber on the bottom of the "Y" to make a tighter seal. |
johnanddes Satellite Wrangler
Joined: October 17, 2004 Posts: 692 Location: Orcutt CA
Posted: Wed Dec 22, 2010 3:45 pm Post subject: |
Just a question, is the PVC pipe necessary? I bought the pool hose and I am ready to connect it to my heater channel (which isnt too bad) and I was wondering if the PVC is even needed or is it just because you guys have a vent in the middle (my car is a 64 bug). Thanks. Great write up though _________________ John
1969 documented numbers matching bug
1968 F250
Keepin the ISS from colliding with space junk |
Aynthm Samba Member
Posted: Thu Dec 23, 2010 3:57 am Post subject: |
| I needed the PVC (white) pipe to put down the holes on each side because my old hoses were crumpled. The hard pipe covers the heater channel and fits tight. That is what I connect the "Y" to. I guess you could just use the blue hose if you could find a way to stretch it over the heater channel pipe. I can't get my hand down there and I can barely see down there. That's why I take the white pipe and work it down there easy. I don't know if a '64 has the "Y" part. Just do what you have to do. I can't wait to put mine back together and drive it. I am pulling the dash apart now and labeling all the wires. Then....well....much more to do. I just got my new silver/beige steering wheel and silver/beige turn signal switch is on the way. I still need to go many more miles. |
Posted: Thu Dec 23, 2010 4:41 pm Post subject: |
Mine doesnt have the Y pipe option (although the big Bentley does explain how to install one ). Ill just install the tube itself and see how it goes. Surprisingly enough, thanks to some twisting, I can fit my arm down there and hopefully stuff it on. I may clamp it just to make sure its on though, havent decided yet. _________________ John
1968 F250
Posted: Fri Dec 24, 2010 11:33 am Post subject: |
For all of you out there that do not have the Y piping, I have just finished installing the pool hose (worked like a champ) and it tested good. What I did was I had to cut lines into the bottom of the pool hose (once you cut it to size, I left a little extra just in case my method didnt work and I had to go buy more). Here is how I did it:
1. Cut to length
2. Cut 8 lines (6 spirals high (blue spirals))
3. Cut 2 small sections out (So it looked like a top of a castle like this:
__
[_] [_]
4. I then duct taped the end together so it formed a smaller circle
5. Shoved it into the heater channel
6. Connected it to the top and wrapped up _________________ John
1968 F250
Aynthm Samba Member
Posted: Fri Dec 24, 2010 5:27 pm Post subject: |
Nice job! |
Posted: Fri Dec 24, 2010 9:52 pm Post subject: |
Thanks Aynthm, Ill keep you posted on when I do the other side. The real test comes on Monday when I get up for work at 3 AM! _________________ John
1968 F250
beneharris Samba Member
Joined: September 18, 2010 Posts: 58 Location: Portland
Posted: Mon Dec 27, 2010 2:53 pm Post subject: |
| thanks for this thread guys, ill be doing this here in the next day or so. i'll let you know how it works for me too |
scubaaron Samba Member
Posted: Sat Oct 15, 2011 10:30 am Post subject: |
| Thank you for this thread, the pvc pipe idea got me rolling in the right direction. Its tough to fit my arm down into the infernal abyss to connect to the heater channel let alone get a hose on and clamp it! Juts in time for old man winter... |
Aynthm Samba Member
Posted: Sat Oct 15, 2011 12:41 pm Post subject: |
| scubaaron wrote: |
I took an old computer fan and put it in a box, used a toggle switch and the box is in the trunk, hooked to the center defrost vent. Need extra air on windshield? Flip the toggle, fan comes on and helps blow a little air on the window. Very quiet and cheap little booster.
youngnstudly Samba Member
Joined: October 21, 2005 Posts: 836 Location: Whine Country (SF Bay area)
Posted: Sat Oct 15, 2011 1:41 pm Post subject: |
I did the same thing years back with the CPU cooling fan, but I don't have the center defrost vent in my 63' so I used the factory speaker grille location instead. My setup has an old emergency flasher switch located in the factory spot for that switch on 66' and up cars. It helps quite a bit when running, but the part I like is the fact that it doesn't draw defrost air when the motor is off, so I still get full defrost. The stock system can work great, but I like to get heat (and defrost) sooner on really cold (icy/rainy) mornings so I messed around with these ideas. I use the stock flexible tubing to connect the defrost and heater channels though as it is cheap, proven, and not too difficult to install. Aynthm's tubing is fine too and easier to buy.
The bilge motor I installed years ago too. I'd go 3" on the next one though. I wrap everything (even factory tubes under the rear seat) with Heating insulation so that any metal that is part of the heating duct is insulated. Obviously the carpet over the heater channels does a good job of insulating so you don't need anything more there.
Andy _________________ Vintage Volkswagens: When you're not swearing by them, you're swearing at them |
Bassdude404 Samba Member
Joined: September 04, 2011 Posts: 234 Location: Rolling Prairie Indiana
Posted: Sun Sep 09, 2012 8:24 am Post subject: Re: Defrost Assembly Made Easy |
| Aynthm wrote: |
Good luck.I just made this edit The "Y" fit loosley in the white pipe so I superglued a small piece of innertube onto the bottom of the "Y" that will make it fit snugly into the white pipe and not wiggle at all. I only used the rubber around 1/2 of the circumference of the "Y" because if I used it entirely around...It would not fit in. Some alum tape might be good to put around all connections when final assenbly is complete to seal out any leaks. ..[/b][color=red] |
First off, yes I know this is a 2 year old thread, but it came up when I used the "search" and is relevant to my car...Just installed heater boxes yesterday along with new exhaust system...Took the car for a drive yesterday evening and got heat at the floor vents, but nothing from the defrost vents...I haven't dug into the hoses in the front yet, as it was late when we got back home...I'm wondering if you have pics of this setup installed in the car, as I'm not quite visualizing it in pieces like you have pictured...I do admit to not even looking that closely at the hoses that are in place from the factory though..Like I said, just now have the heat exchangers installed and tried it out...Also wondering how much resistance there should be with the left (black knob) lever??...It operates MUCH easier than the right side one, so I suspect a possible busted cable, and doing a quick visual, not sure how to go about changing that out with a new one, or where the heck it even goes in the car.... _________________ My motorcycle has a radiator, but my car doesn't..... |
Posted: Sun Sep 09, 2012 12:19 pm Post subject: |
Ok took a good look at my own car, and the front defrost hoses are all intact and in good shape...Went into town and apparently have the cables for the heat exchangers adjusted incorrectly as I have heat all the time...But operating the left lever doesn't change any of the routing of air in the car...Got back home and I can see the cable being moved (black lever), towards the rear of the car, and can hear something, but have no clue what it's attached to under the rear seat area....I have to replace the throwout bearing next weekend, and doing the clutch and pressure plate while I have the engine out of the car..While I have it that far apart, would like to at least check and see that everything with the heater controls is hooked up correctly...Anybody got a picture, or schematic they can steer me too??...
Thanks for any help guys and gals... _________________ My motorcycle has a radiator, but my car doesn't..... |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11212 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Mon Sep 10, 2012 6:57 am Post subject: |
The right lever controls heat/fan volume, the left lever controls, the footwell and defrost when the front ankle burners are shut.
The right side cable routes to the heat exchangers at the engine.
The left side cable routes to the "Y" tubes and control flaps under the rear seat.
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
