djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2176 Location: Graz, Austria, Europe
Posted: Fri Dec 03, 2010 2:36 pm Post subject: Transmission nose cone / shifter cover |
Please help !
In search for a proper nose cone for my 54 I came across this. to my knowledge this should be a BD nose ?! How come the parts nr. 21.09.9 ??
and not a 29....
and why is the cogwheel VW badge on the shifter lever?
I've read quite some threads about trannie swapping even in early split bugs but didn't get wise really. Can I use this nose ( if it is an early non synchro BD nose) on a pre59beetle straight axle split case trans (in my panel)? _________________ Hotrods, Fords, Veedubs and Triumph Twins !
62 Dickholmer, custom color Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
EverettB Administrator
Joined: April 11, 2000 Posts: 69824 Location: Phoenix Metro
Posted: Sat Dec 04, 2010 9:08 am Post subject: |
Thanx, Everett.mine could be split bug then. exactly is missing the 2 outer ribs and the later vent opening, has 2 holes instead.
I was refering the 21. code to type 2, but it obviously is the part code !
( as seen on yours, has the 29.21.09.)
That's why there's the cogwheel on the shift lever. early split bug probably. Though this came from a pile of BD specific trannie parts.
I will have to check if this will fit the 54-59 bug trannie and my bus . Will post efforts here.
regards Guenter _________________ Hotrods, Fords, Veedubs and Triumph Twins !
Trevor P Samba Member
Joined: January 21, 2004 Posts: 863 Location: Saskatoon, SK, Canada
Posted: Sat Dec 04, 2010 11:44 am Post subject: |
My 53 has the same nose cone as does Ken's 53. That particular nose cone seems to be from early BD transaxles. Not sure about my hockey stick as I have never inspected it.
See the post about halfway down on this thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...;start=100 _________________ 53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy |
52panelvan Samba Member
Posted: Sat Dec 04, 2010 11:58 am Post subject: |
Yes that's a non syncromesh bardnoor one (probably split bug too)
Everett's picture is a syncromesh gearbox one
I don't know if it will fit a pre 59 bug gearbox though sorry _________________ Austrian Kohlruss Deluxe
January 1954, 20-072397
The Kohlruss Barndoor Restoration - https://www.facebook.com/groups/641684399225180/
Instagram - rustykohlruss |
frikendelicious Samba Member
Joined: February 29, 2008 Posts: 63 Location: holland
Posted: Sat Dec 04, 2010 1:00 pm Post subject: |
hi Gunter,
Im pretty sure you can use that nose on an early bug box. That is exactly what Im planning and I test fitted my non-synchro nose cone on an early splitcase bug trans that was empty... it fits and everything looked good, but as the case was empty Im not 100% sure..
jeroen |
Crashbox Samba Member
Joined: February 11, 2010 Posts: 41 Location: Germany
Posted: Sat Dec 04, 2010 1:46 pm Post subject: |
Like 52panelvan said, what you have is a non-synchromesh nose cone (type 1 up to September '52, type 2 up to March '53). It won't fit on a synchromesh splitcase gearbox which requires a deeper recess in the nose cone for the lower ball bearing.
Non-synchromesh:
Synchromesh:
To mount a pre '59 beetle splitcase gearbox in your barndoor bus you'll need an April '53 to May '59 bus nose cone (part number 211 301 205 A). _________________ '50 Type 11C
'52 Type 21A
'62 Type 111
'71 Type 23-517, SO 72/3 |
Posted: Sun Dec 05, 2010 5:56 am Post subject: |
Thanx to everybody for the great info !!! the drawings from crashbox point out extremely nice ! I will have to check if my splitbug/early BD nose can be machined down to accept the lower bearing. first I will have to dig up one of my synchro split case bug trannies under a foot of snow or so
@ Trevor P: I knew I had seen info already but couldn't find the above mentioned thread. I will have to study this a bit more. Man, I sure got a lot to learn about that BD stuff. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
palmgreen57 Samba Member
Posted: Fri Oct 15, 2021 12:37 pm Post subject: Re: transmission nose cone / shifter cover |
Hello
I update this thread, I have a 53 dlx, the transmission was changed by a later type in the 60's, the only thing I'm supposing they kept is the nose cone with ref 21.09.1 ( see my picture)
I'm now rebuilding a correct 53 with original cases and nose cone.
From what I have read there I'd have the 29.21.09. 1 ref nose cone with top cylinder breather, but when I check my 53 workshop manual I can see nose cone without cylinder breather but with 2 holes...
I also compared to my all original matching March 53 oval, the nose cone is with cylinder breather but 1 rib... 🤔
I'm lost...
My question is what was factory fitted mid 53?
Thank you for your help
Yan
Posted: Fri Oct 15, 2021 12:41 pm Post subject: Re: transmission nose cone / shifter cover |
My 53 workshop pictures:
Posted: Fri Oct 15, 2021 12:46 pm Post subject: Re: transmission nose cone / shifter cover |
My March 53 bug nose cone :
The nose cone with 2 breath holes I suppose original from my 53 bus
Last edited by palmgreen57 on Fri Oct 15, 2021 12:56 pm; edited 2 times in total |
Posted: Fri Oct 15, 2021 12:49 pm Post subject: Re: transmission nose cone / shifter cover |
And the 2 breathers design : 2 holes / cylinder breather
Posted: Wed Oct 20, 2021 10:13 am Post subject: Re: transmission nose cone / shifter cover |
Hello,
Someone can help?
Thanks |
Werk34Parts Samba Member
