Brian_e Samba Member
Joined: July 28, 2009 Posts: 3284 Location: Rapid City, SD
Posted: Tue Dec 07, 2010 12:28 pm Post subject: One piece windows back to stock ??'s |
I just purchased a unfinished 1970 project. Everything on the car is exactly what I want except the one piece windows the PO has partially installed. The car was a body off, powder coated pan, everything new, nice done paint. I don't have any instructions or info about the window kit. I have read all of the horror stories on here about them. Just wondering if it is at all possible to switch back or make them right. I have a few questions.
-What pieces are cut off the stock door when installing the one piece kit?? I searched the gallery, but couldn't find any.
-Is there any way to tell what brand I have so I can maybe get instructions??
-The seals around the top of the door frame are screwed in place. This seems to work well, but is it correct?? The lower seals at the front of the door by the mirror don't fit at all. Does something need to be done here??
I also have a '70 parts car I can use to switch back if possible. If the cutting has been done inside the door, I don't mind welding it back on, as long as it isn't too close to the new paint.
I don't mind the way the one piece looks. The car has been de-chromed, and I want the cal-look. I would leave them if I can make sure they are installed correctly and not a pain in the ass for a daily driver.
Any help would be appreciated.
Brian |
beetlenut Samba Member
Posted: Tue Dec 07, 2010 12:44 pm Post subject: |
If the PO wasn't a total hack, he hopefully left in the metal tabs in the window opening. When installing the one piece kits, you have the option to cut those tabs off, or just bend them down out of the way. They should be located by where the vertical part of the vent window frame sits in the window opening. As far as the screws holding in the seals at the top of the door frame, there are suppose to be some clips that fit on the backside of the seal that keep it in place in the window frame. The lower seals by the mirror are IMO what's wrong with all these kits. They don't follow the contour of the window opening and let in water and dirt. The only way around that is to make a series of cuts to the lower part of the seals and scrapers, through the metal strip inside the rubber, and bend those parts of the seals and scrapers to the same contour as the curve of the window. Then you have to use some sealant or silicone to hold that part of the seal and scraper to the inside of the window opening. Some business could make some money if they came up with some seals and scrapers for one piece windows that incorporated that curve! _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
werksberg Samba Member
Joined: February 08, 2005 Posts: 2151 Location: Prescott Valley, AZ
Posted: Tue Dec 07, 2010 12:45 pm Post subject: |
Easily to just use other non cut doors.... _________________ Werksberg Products....Products that work!
Follow my new products on my Facebook Werks Berg
Click the below ADs link for products & feedback.
Search "werksberg" on Photobucket for products photos & Please remember to buy "American made products!" |
Posted: Tue Dec 07, 2010 1:47 pm Post subject: |
beetlenut1 wrote: |
If the PO wasn't a total hack, he hopefully left in the metal tabs in the window opening. When installing the one piece kits, you have the option to cut those tabs off, or just bend them down out of the way. They should be located by where the vertical part of the vent window frame sits in the window opening. As far as the screws holding in the seals at the top of the door frame, there are suppose to be some clips that fit on the backside of the seal that keep it in place in the window frame. The lower seals by the mirror are IMO what's wrong with all these kits. They don't follow the contour of the window opening and let in water and dirt. The only way around that is to make a series of cuts to the lower part of the seals and scrapers, through the metal strip inside the rubber, and bend those parts of the seals and scrapers to the same contour as the curve of the window. Then you have to use some sealant or silicone to hold that part of the seal and scraper to the inside of the window opening. Some business could make some money if they came up with some seals and scrapers for one piece windows that incorporated that curve! |
Thank you for the excellent description. I will do some more digging and see what I have to work with. If I could get them to seal up good I wouldn't mind keeping them. |
Posted: Tue Dec 07, 2010 1:48 pm Post subject: |
werksberg wrote: |
Easily to just use other non cut doors.... |
The car was just painted inside and out, and the parts car doors a rough. |
bartman Samba Member
Joined: February 22, 2004 Posts: 767 Location: palatka, fl
Posted: Tue Dec 07, 2010 1:50 pm Post subject: |
If the proper 2-point-lift regulator is used they work ok
My baja came with one-piece windows with single-point regulators and it was miserable.
all the usual shit, palming the glass on rollup, etc.
A guy gave me a set of doors with the 2-point regulators which I put in my doors. fixed it
the only drawback is that the 2-point reg loops behind the factory speaker cutout, limiting depth to less than an inch
Can't remember the exact year range for the regulator. Mid 60s
Ah, here's a link i found to a nice 1-piece article. Very nice window rubber install: http://members.shaw.ca/sharkeysgarage/scaffold.html |
joecoolman16 Samba Member
Joined: September 16, 2010 Posts: 25 Location: eatonville
Posted: Tue Dec 07, 2010 9:39 pm Post subject: |
i got the one pice and i hate em my drivers side is fine but the other side eats the frunt of seal and makes me want to put a bullet in my head |
flierbob Samba Member
Joined: August 21, 2008 Posts: 538 Location: Silverdale WA
Posted: Tue Dec 07, 2010 10:11 pm Post subject: |
The vent windows direct air into the car on hot days, without air conditioning the air is good.
On my car the po had tried to install one piece windows and they were a mess.
It is easy to install the wing windows.
good luck,
Bob |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Tue Dec 07, 2010 11:51 pm Post subject: |
Depends what sort of climate you're in.
Inland aus where there is zero percent humidity smokers windows are horrible, all they did in mine was direct hot air like a hair drier onto me but here on the coast its very refreshing
To the people saying swap the doors.....WTF
Its piss easy to change from one piece back to stock, I've done it on two cars now
The only mod thats done to the doors to fit 1 piece windows is removing the check rod and cutting the tab between the outter and inner skins
whilst that tab does contribute to a small amount of door strength its not critical.
All I did was bolt the stock hardware back in, you wouldn't know any different _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Wed Dec 08, 2010 10:42 am Post subject: |
werksberg wrote: |
that's exactly what I would do! |
George Evans Samba Member
Joined: November 18, 2005 Posts: 632 Location: Flowery Branch , Ga
Posted: Wed Dec 08, 2010 2:10 pm Post subject: |
Could a missing set of tabs not just be pop riveted back in lace? If the OP finds them missing.. |
Posted: Thu Dec 09, 2010 5:34 pm Post subject: |
68IHscout wrote: |
werksberg wrote: |
Brian_e wrote: |
werksberg wrote: |
The car was just painted inside and out, and the parts car doors are rough. |
Derek Cobb Annoying
Posted: Thu Dec 09, 2010 5:45 pm Post subject: |
You don't need the tabs. Just bolt the original vent window parts back in. Done. |
69 Jim Samba Member
Joined: September 27, 2004 Posts: 6264 Location: Chickengeorge's Neighbor
Posted: Thu Dec 09, 2010 6:20 pm Post subject: |
Joel wrote: |
I have to agree. |
Fe2O3 Samba Member
Posted: Fri Dec 10, 2010 2:36 pm Post subject: |
Joel wrote: |
All I did was bolt the stock hardware back in, you wouldn't know any different |
Agree, just bolt the stock stuff back in place. The little tab is negligible, IMO. |
Posted: Fri Dec 10, 2010 6:00 pm Post subject: |
I looked under the half installed seal, and the tabs seem to be cut off with a pair of wire cutters or something. I think I will abort the one piece kit and stick the stock stuff back in without the tabs.
Thanks everyone for the help.
Brian |
Posted: Sat Dec 11, 2010 12:51 pm Post subject: |
so what are the tabs for? |
