Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 986 Location: Bath, England
Posted: Thu Oct 29, 2020 4:23 pm Post subject: Re: Cable brake information |
This is the earlier open type, and I certainly have them on my 47. When they changed to the enclosed bolt hole I don't know. |
sinclair Samba Member
Joined: July 01, 2004 Posts: 398 Location: New Forest UK
Posted: Fri Oct 30, 2020 2:28 am Post subject: Re: Cable brake information |
Thanks Martin. I’ll see what Garwood says when I get an hour free. |
VEE DUB BOYS Samba Member
Joined: August 30, 2011 Posts: 146 Location: Greenville, SC
Posted: Mon Aug 29, 2022 8:22 pm Post subject: Re: Cable brake information |
I’m working on Heb 428. We went back with a cable brake chassis. The original
Chassis was swapped in the August 1961 Foreign Car Guide (I believe). This
Thread is super informative. |
mk-Zero Samba Member
Joined: July 20, 2005 Posts: 350 Location: Orange, CA
Posted: Wed Sep 21, 2022 5:52 pm Post subject: Re: Cable brake information |
Thanks Nancy and all who contributed to this thread. Super useful! I just picked up a 52 standard and at some point I'm sure I'll need to adjust the cable brakes or do some kind of service on them. For now, they work okay. _________________ Vintage Classic Specialist, Orange, CA
www.VCSresto.com
[email protected]
1952 VW Standard beetle
1955 VW Type 1, 231 hp daily driver
1956 VW Karmann Convertible Okrasa |
bloomsburyVW Samba Member
Posted: Sun Apr 09, 2023 3:13 pm Post subject: Re: Cable brake information |
Great thread. Read through it all -- maybe 5 times
1952 standard (not zwitter)
Question: What if the handbrake activates the brake lights, but just pressing the brake pedal does not activate the brake lights. Of course, pressing the brake pedal does stop the car).
Seems very odd, but that's what's happening at the moment (recently purchased).
Thanks |
Two Glove Boxes Samba Member
Posted: Mon Apr 10, 2023 12:47 pm Post subject: Re: Cable brake information |
bloomsburyVW wrote: |
Thanks |
It sounds like a ground issue as long as the wiring on the sending unit is wired correct. _________________ 1951 Split Standard Hoffman Build
Two Glove Boxes
DLK |
Posted: Mon Apr 10, 2023 3:10 pm Post subject: Re: Cable brake information |
Sorry, what is the "sending unit" to which you refer?
The brake light does work when the handbrake is engaged, just not when you push down the brake pedal.
Thanks |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Mon Apr 10, 2023 4:22 pm Post subject: Re: Cable brake information |
Two Glove Boxes wrote: |
It sounds like a ground issue as long as the wiring on the sending unit is wired correct. |
It's a mechanical connection so don't think it's a ground likely.
How about sharing a picture of the front where the cables gather and the switch is. Take the cover off so we can see what you have. |
Posted: Tue Apr 11, 2023 11:46 am Post subject: Re: Cable brake information |
nlorntson wrote: |
Yes, but I was referring to the brake switch that has power to it and connects to the end of the e-brake rod?
Two Glove Boxes
DLK |
Posted: Wed Apr 12, 2023 2:16 pm Post subject: Re: Cable brake information |
nlorntson wrote: |
It sounds like the switch works enough to light up the brake light so I'm not sure wiring is problematic:
Quote: |
The brake light does work when the handbrake is engaged, just not when you push down the brake pedal. |
I'm guessing an adjustment or how the setup is installed is the problem. |
nedfaux Samba Member
Joined: January 03, 2011 Posts: 7 Location: kettering
Posted: Wed Aug 02, 2023 11:00 am Post subject: Re: Cable brake information |
Great post. Lots of very helpful information.
I’m currently rebuilding this system on an early ‘49 standard.
After reading this post I’m pretty sure I have all the components needed.
My question is regarding what’s inside the tunnel…
* The main C section that connects to the brake pedal, does this have a cradle it sits in or does it just rest on the frame head / where it connects to the pedal and floats?
*The hand brake rod, Again does this just float connected at either end or does it pass through some sort of cradle or mount further down the tunnel?
I hope this makes sense, it’s hard to explain when you can’t see what’s happening inside. I put a light in there but struggled to see far enough.
Thank you. _________________ Www.hayburner.co.uk |
nshaddox Samba Member
Joined: January 18, 2005 Posts: 612 Location: Hammatramma, MI
Posted: Wed Aug 02, 2023 5:33 pm Post subject: Re: Cable brake information |
I had to open the tunnel on my 52 Zwitter 11A car. You can search my gallery for pictures. There are some braces internally in the tunnel for sure, but I doubt they would be different for cable brake vs hydraulic brake based on what I saw in there. That said, there are probably more knowledgable folks than me on here so let’s see what other information people have to offer up.
TRS63 Samba Member
Joined: December 17, 2017 Posts: 999 Location: Stuttgart - Germany
