mwilliamshs Samba Member
Joined: November 02, 2014 Posts: 5 Location: Arkansas
Posted: Mon Feb 15, 2016 12:47 pm Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? |
http://www.eezi-awn.co.za/eeziawn/awnings.html
The Series 2000 look familiar? SAME AWNING.
It's my belief Eezi Awn is just a reciprocal of the A&E brand.
http://www.expeditionportal.com/forum/attachment.p...mp;thumb=1
Here's a pic of the Eezi Awn logo that's on the plastic end caps of their awning. It's basically identical to the A&E logo on my stock caps. Looks like they just flipped the mold plate.
Posted: Wed Feb 17, 2016 9:23 am Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? |
Ordered gutter mounting kit from Eezi Awn in Australia, cheaper than dometic even with shipping halfway around the globe. Also ordered new pvc end caps (all 4) and caps plus gutter kit was still cheaper than just brackets from Dometic/Adventure RV/etc. The foot-holding body-mounted brackets are not used/made/available from Eezi Awn.
Anybody got a close-up pic of the Dometic foot brackets?
EDIT: found some
Might just whip up some of these and install with VHB instead of drilling holes
BUT I'd use these spring-loaded, internal retainers instead of that clumsy pin-and-clip that I can imagine leading to paint scratches galore
uncommonvw Samba Member
Joined: July 12, 2004 Posts: 230 Location: Jordan, ON Canada
Posted: Mon Sep 12, 2016 7:53 am Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? |
I just picked one of these up on the weekend for my Whitestar. I found it while looking at cheap tent trailers.
Looks to need a good cleaning and the latches are rusty. I was happy to pay $100 CDN for it. I'll make my own gutter mounts to attach it to the van. Thanks for the links to find the latches. $20 a pair is fine by me. |
sake Samba Member
Posted: Thu Jun 14, 2018 1:49 pm Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? |
Bought an Eezi Awn 2000, does anyone know where to buy mounting brackets + pressure clamps? (Europe preferred). |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1174 Location: PNW - its a dry rain.
kamzcab86 Samba Moderator
Posted: Tue Aug 20, 2019 4:01 pm Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? |
For those buying an old Trans-Awn or a new Eezi-Awn, you can use Fiamma mounting brackets:
I ditched the small 30-year-old Dometic brackets a couple weeks ago and installed the beefier Fiamma brackets (ARB brackets would probably work as well, but RMW didn't have any in stock when I was browsing). The original case holes were re-used, but an additional hole was added for each bracket. The awning is now sturdier and sits higher eliminating this problem: https://www.thesamba.com/vw/forum/viewtopic.php?t=706841 . Added bonus: The accessory track on the case can now be used for... accessories!
If you go this route: You'll be using only two brackets. Adding a third at the C-pillar will be impossible without making modifications. There's a lengthwise curve to the vans, which makes it difficult to utilize a third/center bracket without adding a ton of torque/outward force to the front bracket and, thus, damaging the gutter (I hypothesize that that's the reason for the minor gutter damage on my van since the awning was mounted using 3 Dometic brackets). _________________ ~Kamz
2016 Golf GTI S
"I fear the day that technology will surpass our human interaction; the world will have a generation of idiots." ~Albert Einstein |
ambrose_d Samba Member
Joined: April 12, 2006 Posts: 12 Location: Portland, OR
Posted: Fri Jul 03, 2020 1:25 pm Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? |
Any luck with these? Or anyone else come up with a solution for the bottom bracket? |
chojinchef Samba Member
Joined: February 17, 2011 Posts: 1539 Location: Central Massachusetts
Posted: Tue Dec 08, 2020 2:52 pm Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? |
Anyone have a set of end caps for the trans awn kicking about?
Just need to borrow for some reverse engineering to create some repro availability.
Thank you
LP _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
Love My Westy Samba Member
Posted: Tue Dec 08, 2020 9:09 pm Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? |
chojinchef wrote: |
Thank you
LP |
They are available from Eqipt Expeditions in Salt Lake City. They are the Eezi Awn importers:
https://www.equipt1.com/collections/awnings |
Posted: Wed Dec 09, 2020 5:05 am Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? |
Well that makes that repair easy. Thank you.
Love My Westy wrote: |
chojinchef wrote: |
Thank you
LP |
