Deano's 63 Double Cab
Schwing
Schwing is offline
PostPosted: Sun Mar 15, 2015 4:54 pm    Post subject: Reply with quote
Wow thats easily the shiniest treasure chest floor and interior cab I have ever seen. Did you use panel adhesive for the load bed floor or was that welded?
Shadetree Westy
http://www.thesamba.com/vw/forum/viewtopic.php?t=657279&highlight=
Single Cab - lets finish this thing!
ConcreteAce
ConcreteAce is offline
PostPosted: Sun Mar 15, 2015 6:35 pm    Post subject: Reply with quote
welded
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'68 Turbo Diesel Baja
'64 Ghia Vert
'61 Baja Build
Schwing
Schwing is offline
PostPosted: Mon Mar 16, 2015 5:21 am    Post subject: Reply with quote
Beautiful work, thanks for the quick reply. When I saw you spraying dove blue on the frame I thought maybe you used adhesive. I guess you just cleaned off the paint after that to prep for welding. I plan to do the same.
Shadetree Westy
Erik G
Erik G is offline
PostPosted: Mon Mar 16, 2015 1:23 pm    Post subject: Reply with quote
can't wait to see it in person
ConcreteAce
PostPosted: Sun Mar 22, 2015 6:13 pm    Post subject: Reply with quote
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
EDragnDean Premium Member
EDragnDean is offline
PostPosted: Sun Mar 22, 2015 6:32 pm    Post subject: Reply with quote
Thanks for the photos Ethan!
63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image - SOLD
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
70 BusClick to view image
ConcreteAce
PostPosted: Sun Mar 29, 2015 5:38 pm    Post subject: Reply with quote
Second round of clear Very Happy
I left before I could get finished shots of the doors. I did get some shots of the main body ready for buffing
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
PostPosted: Sun Mar 29, 2015 7:02 pm    Post subject: Reply with quote
Thanks Ethan.
ConcreteAce
PostPosted: Sun Mar 29, 2015 7:41 pm    Post subject: Reply with quote
Man those doors look smooth!
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
PostPosted: Sun Apr 26, 2015 6:29 pm    Post subject: Reply with quote
Red Fau Veh
Red Fau Veh is offline
PostPosted: Mon Apr 27, 2015 8:18 am    Post subject: Reply with quote
That's sweet looking. Cool
1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote:
Swivel Seat panels are for people with no friends Crying or Very sad
Schwing
Schwing is offline
PostPosted: Mon Apr 27, 2015 8:38 am    Post subject: Reply with quote
Incredible bodywork! What paint gun and brand paint are you using? Is that Dupont?
Shadetree Westy
PostPosted: Mon Apr 27, 2015 9:35 am    Post subject: Reply with quote
PPG. I will need to get the specifics from the shop.
Schwing
Schwing is offline
PostPosted: Mon Apr 27, 2015 9:36 am    Post subject: Reply with quote
Thank you very much I appreciate that.
Shadetree Westy
PostPosted: Mon Apr 27, 2015 10:38 am    Post subject: Reply with quote
PPG Shop Line for base, and PPG Concept 2021 clear.
IMHO the clear makes a big difference. Like the what motor oil is the best question, when you start asking which paint, you will get a different answer from every person you ask.
Personally, I am not a painter, I let the shop choose the materials, opted for a better clear, and let them get it done. Same with the Single Stage vs Base/Clear argument. I found a good shop and let the pro decide.
In the end, the paint work and quality is better than on our 2013 GTI! Very Happy
Schwing
Schwing is offline
PostPosted: Mon Apr 27, 2015 10:42 am    Post subject: Reply with quote
Thanks. I was just curious what they specifically used. I do my own paint and I prefer single stage having done both. I was just curious what brand. I used PPG Concept on my oval and it turned out great, but I used a cheaper gun. I'll be painting my truck this fall and was just curious.
Thanks again.
Shadetree Westy
ConcreteAce
PostPosted: Sun May 03, 2015 9:54 pm    Post subject: Reply with quote
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
ConcreteAce
PostPosted: Tue May 26, 2015 11:21 pm    Post subject: Reply with quote
coming along nicely!
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
PostPosted: Sun May 31, 2015 7:07 pm    Post subject: Reply with quote
Tucked back in my garage and working on assembly...
Started on the pedestal and rear seat, mostly so I could move them inside the cab and make more room in the garage. Of course, to close up the fuel tank, I had to run the main wiring harness... etc, etc, etc.
Fuel tank installed, fuel tank covers reinstalled, added felt per OG (thanks for the solder burn tip Bullibill), rear seat installed (rubber seat stops, floor plugs, soooo many details....!)
PostPosted: Mon Jun 01, 2015 5:56 am    Post subject: Reply with quote
* New wiring harness installed, and 90% complete (had to extend the fuel tank sender wire as the fuel tank is in a different location than a bus...).
-headlights
-turn signals
-speedo
-fuel gauge
-switches
-Wiper assembly/motor
-Neiman steering lock
-etc, etc, etc,
Need to install tail lights, battery cables, and battery. Then I can test the connections.
I used a Wolfsburg West wiring harness, really pleased with the quality, I will post a separate thread with my thoughts.
Broke the tab on my emergency flasher relay, if you have one for sale, please PM me.
Page 5 of 8
