Posted: Wed Jan 29, 2003 10:20 pm Post subject: HOW DO YOU LOWER YOUR VW |
WELL I HAVE A 1964 DUB I WAS WOUNDERING HOW TO LOWER IT WITH OUT SPENDING TO MUCH MONEY EVERY WERE I GO THEY TELL ME TO PULL THE PINS I KNOW WHAT THAT MEAN BUT I WANT TO KNOW HOW TO DO IT
CAN SOMEONE PLEASE HELP |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Wed Jan 29, 2003 10:33 pm Post subject: HOW DO YOU LOWER YOUR VW |
If you are going to do it, have adjusters installed. Pulling torsions is not good for the car. Turns it into a piece of junk quick trust me (been there done that) also, dropped spindles, not cheap but worth the dough. Adjusters are pretty cheap, its just having someone or yourself weld them in. |
Flyer20200 Samba Member
Posted: Thu Jan 30, 2003 7:55 am Post subject: HOW DO YOU LOWER YOUR VW |
What can you do to lower the back? I know you can put adjusters, and lower spindles, but what happens in the back? |
Posted: Thu Jan 30, 2003 6:16 pm Post subject: HOW DO YOU LOWER YOUR VW |
I just dropped my bug. In the back I went down 2 splines and in the front I welded in beam adjusters (very easy to do if you have the right equipment) also very cheap. I am also adding drop spindles. Good luck with yours. |
orangabug Samba Member
Posted: Thu Jan 30, 2003 8:31 pm Post subject: HOW DO YOU LOWER YOUR VW |
How easy is to raise the rear end after it's been lowered? Is it just the reverse of the lowering process? |
Anti- Samba Member
Posted: Fri Jan 31, 2003 4:51 pm Post subject: HOW DO YOU LOWER YOUR VW |
It's the reverse. Here is a link with great instructions for doing the rear. One inside notch is quite a lot on a swingaxle bug. Think twice about going down more unless the knock-kneed look doesn't bother you.
http://www.vwmagazine.com/tech/oct_tech.html
Good luck, be careful.
Chris
JHC |
