scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Sun Oct 30, 2016 2:43 pm Post subject: Re: LED lighting upgrades |
Lintbrush, good call sacrificing aftermarket housings for your tail lights. Sounds like you have a standard thermal flasher for your blinkers; when you swap over to LEDs they need an electronic flasher to blink. You can find them at any auto parts store for less than $10. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
lintbrush Samba Member
Joined: October 10, 2013 Posts: 269 Location: Campbell, California
Posted: Sun Oct 30, 2016 3:41 pm Post subject: Re: LED lighting upgrades |
scrivyscriv wrote: |
Lintbrush, good call sacrificing aftermarket housings for your tail lights. Sounds like you have a standard thermal flasher for your blinkers; when you swap over to LEDs they need an electronic flasher to blink. You can find them at any auto parts store for less than $10. |
They blink, just my dash signal light doesn't trigger. Also, no clicking. _________________ 1970 Westfalia Campmobile - SF Bay Area
https://www.instagram.com/campishome/ |
Gregg in the 603 Samba Member
Joined: April 13, 2013 Posts: 404 Location: New Hampshire, USA
Posted: Mon Oct 31, 2016 5:36 pm Post subject: Re: LED lighting upgrades |
Hey there. I bought the wedge-type LED's from superbrightleds.com in a cool blue color for the fuel guage and speedometer, they are awesome!
The only thing left is my tachometer. It is an old VDO unit. I bought it here, works great! Just the bulb is the old style, push down and quarter turn to plug in.
VDO 600 819 Type B Plastic Bulb Socket | 600 804 Type B 11/32" (9mm) Metal Base Bulb
I couldn't read the writing on the bulb, but I bought some close-looking LED bulbs off fleabay that appeared correct.
They plug in and hook up fine, but do not light up so they must be wrong?
Does anyone know the correct LED bulb to buy for this type guage/connection?
Also, while we're at it, the sockets that the wedges plug into, I am missing one on my guage. The small spade connector is present, but the black socket is not. Does Superbright sell these too or someone else?:
Maybe if I could find a new socket, I could make it work with the tachometer. I'll try that, what do you guys think?
Edited Tcash _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
chabanais Samba Member
Posted: Tue Nov 01, 2016 4:14 pm Post subject: Re: LED lighting upgrades |
[quote]Wheat bulbs for dash: [quote]
I used the cool blue wedge bulbs, worked great. I'm talking about the black sockets they plug into. I need another one, anyone know where to get one?
Also, the large push-in and twist style that I show in the picture, didn't work on my old VDO whereas the traditional bulb I have does work. Anyone know the correct LED bulb to buy for this guage? _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
VWSunny72 Samba Member
Posted: Tue Nov 01, 2016 4:30 pm Post subject: Re: LED lighting upgrades |
Here's the link for those in-dash bulb holders from Just Kampers:
http://www.justkampers.com/141-957-397-a-dashboard-bulb-holder-for-vw-t2-1968-1979.html
Separately, i'm awaiting my LED bulbs from Vintage Car LED (3500)...they should come in after work today. _________________ ------------------------
I am owned by a 1972 Westy named Sunny. She has a 1979 2.0L engine w/ dual Weber IDF 40s. |
Posted: Tue Nov 01, 2016 4:59 pm Post subject: Re: LED lighting upgrades |
Thanks a lot Sunny, that helped for sure. I also finally found the part number for the wheat bulb. It is a specific, made by VDO bulb, part number 600-804. So, don't think I'll find an LED replacement. No biggie, I'll buy some of those sockets and replace the light in the tach with the smaller socket/wedge LED.
Thanks again _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
Posted: Tue Nov 01, 2016 5:19 pm Post subject: Re: LED lighting upgrades |
Gregg in the 603 wrote: |
So, don't think I'll find an LED replacement. |
Ugh... the link I posted was an LED replacement... _________________ "I spud therefore I yam." |
Posted: Tue Nov 01, 2016 5:24 pm Post subject: Re: LED lighting upgrades |
Quote: |
Ugh... the link I posted was an LED replacement... |
Will your LED fit the VDO guage with this socket?: http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D113%2D957%2D397%2DPR
It appears to be the standard wedge style you linked to. Am I wrong? _________________ 1979 Mexico Beige Westy auto
Dirty Dover, NH |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Thu Nov 03, 2016 6:48 am Post subject: Re: LED lighting upgrades |
WhirledTraveller wrote: |
Last summer prior to a huge cross-country road trip I put in "V16 Turbo LED H4 Bulbs" from ebay into my hella housings. I'd say it was a worthwhile upgrade although the beam pattern is not ideal I'd say visibility was improved and it's not blinding to oncoming drivers. Although you can see noticeable "gaps" in the garage door pic, I think that's because the bus is parked very close (maybe 15 feet). At larger distances the gaps seem to blend together although some noticeable "lumpiness" remains.
Low:
High:
If that's what your low & high beams are like after the LED "upgrade", I shudder to think what your headlights were like before!
In 1976, I retro-fitted P45t flanged 60/55W H4 quartz-halogen headlamp bulbs into the existing headlamps of my 1973 VW 1600 Type 2 Westfalia Continental, which when properly adjusted using an optical beam-aimer at the MOT testing station, were far superior to those LED lamps and the later upgrade in 1989 with P45t flanged 100/80W H4 quartz-halogen headlamp bulbs were even better.
I strongly suspect that my 55W quartz-halogen low beam, was as good as if not better than your present LED high beam. _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
Posted: Thu Nov 03, 2016 4:44 pm Post subject: Re: LED lighting upgrades |
Nigel, I wish you could comment in every thread.
NASkeet wrote: |
In 1976, I retro-fitted P45t flanged 60/55W H4 quartz-halogen headlamp bulbs into the existing headlamps of my 1973 VW 1600 Type 2 Westfalia Continental, which when properly adjusted using an optical beam-aimer at the MOT testing station, were far superior to those LED lamps and the later upgrade in 1989 with P45t flanged 100/80W H4 quartz-halogen headlamp bulbs were even better. |
Posted: Fri Nov 04, 2016 8:39 am Post subject: Re: LED lighting upgrades |
Here's a topic thread that I shall read in more details when I get time:
PistonHeads » Gassing Station » TVR » Chimaera » LED Headlights
http://www.pistonheads.com/gassing/topic.asp?t=1455474 _________________ Regards.
Nigel A. Skeet
WhirledTraveller Samba Member
Joined: January 09, 2008 Posts: 1399 Location: Cambridge, MA
Posted: Sat Nov 12, 2016 3:26 pm Post subject: Re: LED lighting upgrades |
NASkeet wrote: |
I strongly suspect that my 55W quartz-halogen low beam, was as good as if not better than your present LED high beam. |
Prior to the LED's I had 55W quartz-halogen H4's.
I replaced one at a time and aimed to the same point at a wall. Sorry I don't have the comparison photos. There is no question the LED's are brighter. There's also no question the beam pattern is not as uniform. But they are not blinding to oncoming drivers, the cutoff is in the same place and there is not a lot of spillover upwards (my main concern). I'm aware that the more blue light is partly psychological (perceived as more bright). But, yes, it absolutely lights up the road better than the 55W. I am happy with the conversion and they haven't failed me yet. In the photo's I posted, maybe it's not clear, but the distance covered is quite high, it was taken in the remote desert of Nevada on a clear moonless night and it's lighting up bushes at least a hundred yards away.
I started my bus ownership with sealed beam halogens.... dim.
Converted to Hella H4's... much, much better
Then converted to LED's... a noticeable improvement
I'm not cheerleeding the LED's, just posting my experience. Based on what I've read, other people have had reliability issues with the fan-cooled LED's so they may not be a good investment. But so far they've been fine for me and brighter than the H4's. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Posted: Mon Nov 14, 2016 9:26 am Post subject: Re: LED lighting upgrades |
NASkeet wrote: |
I'm not cheerleeding the LED's, just posting my experience. Based on what I've read, other people have had reliability issues with the fan-cooled LED's so they may not be a good investment. But so far they've been fine for me and brighter than the H4's. |
When you refer to lighting up bushes at > 100 yards, is this for low beam or high beam? I would hope that high beam would illuminate the road and surrounding shrubbery at considerably more than 100 yards; my 60W H4 quartz-halogen bulbs (in Hella non-H4 headlamp units) certainly did and my 7 inch Lucas 20-20 Homofocal auxiliary driving lamps, with 55W H3 quartz-halogen bulbs, would illuminate a white 5-bar gate at about 1/3 of a mile. _________________ Regards.
Nigel A. Skeet
Sawspa Samba Member
Joined: May 12, 2012 Posts: 173 Location: South-East Ohio
Posted: Mon Nov 14, 2016 12:15 pm Post subject: Re: LED lighting upgrades |
- 8" flexible LED strips in a formerly for-parts Westfalia inside camping light (the one that was originally a fluorescent tube bulb)
Can you explain this more. I want to do this but ive never messed with leds. Can i use my factory switch? Since this runs off of my starting battery. Is there a direct replacement bulb for this? Should i try to rewire this to my aux battery? _________________ 1978 Westfalia Campmobile 2.0L oversized ham heads and a stepped up cam, running points and a 76 exhaust "Lefty Loosy" |
Posted: Mon Nov 14, 2016 4:57 pm Post subject: Re: LED lighting upgrades |
LED lights are pretty easy. You can't dim them unless you have a special module, like this:
https://www.amazon.com/Dimming-Controller-Adjustable-Brightness-Zitrades/dp/B007V1B0W8
You can just wire them in like normal. If you want to use one as a turn signal, however, you just need to use a relay designed for LEDs otherwise they will blink super fast.
Which lights are best for certain applications is another discussion. _________________ "I spud therefore I yam." |
Posted: Tue Nov 15, 2016 9:25 am Post subject: Re: LED lighting upgrades |
NASkeet wrote: |
When you refer to lighting up bushes at > 100 yards, is this for low beam or high beam? I would hope that high beam would illuminate the road and surrounding shrubbery at considerably more than 100 yards; my 60W H4 quartz-halogen bulbs (in Hella non-H4 headlamp units) certainly did and my 7 inch Lucas 20-20 Homofocal auxiliary driving lamps, with 55W H3 quartz-halogen bulbs, would illuminate a white 5-bar gate at about 1/3 of a mile. |
This is a bizzare conversation to have. I didn't go out and measure, nor did I aim it a reflective white gate. Pictures only show so much because of variability in exposure, terrain, etc. The only way to compare is side by side, which I have done. I am simply offering my personal observation that the LED light is brighter then the H4 when aimed to the same point and it does a fine job of lighting up the road. I've driven enough cars in my life to know when headlights are doing a proper job and when they aren't. I guess that's all I have to say on the subject. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Posted: Tue Nov 15, 2016 9:38 am Post subject: Re: LED lighting upgrades |
chabanais wrote: |
Which lights are best for certain applications is another discussion. |
I'm thinking about the possibility of using white/orange LEDs, with clear, white turn-signal lamp lenses, as combined orange turn-signals cum white daytime running lights, which seem to be the norm on several ultra-modern cars here.
This would avoid the need to use either separate daytime running lights or 80W quartz-halogen dipped headlamps during the day, when driving in many European & Scandinavian countries, where their use is otherwise obligatory. _________________ Regards.
Nigel A. Skeet
mattlockwood Samba Member
Posted: Sat Aug 19, 2017 2:10 pm Post subject: Re: LED lighting upgrades |
Weird what it does to your license plate....... _________________ 1970 Bay Window Bus.
110 hp 6 cyl Aircooled automatic |
