guitarman63mm Samba Member
Joined: September 03, 2008 Posts: 797 Location: Asheville, NC
Posted: Sun Nov 06, 2011 8:18 pm Post subject: |
RatCamper wrote: |
SGKent wrote: |
Quote: |
But then I'm also a freak who has limited ability to see IR light sources.
interesting. I have seen x-ray flashes on occasion but never looked to see if IR was different. I know from tests that my eyes see green as a different wave length than others do. It is not color-blind as I can see it, however my eyes peak at different green frequencies than the average person.
Do you see it as IR light at night, say a car hood glowing from heat or only when it jumps up into the lower red bands? |
Well, You know how those IR light sources for security cameras etc. are meant to be all stealthy and invisible so people don't realise they are being watched? I only recently found out I'm not supposed to be able to see the IR illumination. It's sort of a weird red that I can't focus on.
I'm not sure if it's related but even though lights like halogen and fluoros are bright, but I feel like there's something missing when I use them in the house. Like it's bright enough but still dark. Same for car headlights.
I just put it down to being put together wrong somehow because a decent EM field causes a dull aching, and being anywhere near ionizing radiation feels like someone is jamming pins into me. I guess that's useful in a nuclear war but under normal circumstances it just means I'm scared of ever needing to have a scan that uses radioactive dye.
Oh I can also see the pulses from remote controls. Usually the ones without the filter on them so probably near IR. |
I don't know about the red, near-IR LEDs. I can see those too, but that's because they are near-IR, and in the visible wavelength obviously. Is that what you're talking about?
Also, people saying LEDs are not as bright - it's just flat out not true, and quite honestly, I don't know why this it's still going around. Given that incandescents have a luminous efficacy of around 13-18 lm/watt, and LEDs get, at the very minimum, 60 lm/w when you initially turn them on (usually at least 80 lm/w though), I think everyone is simply picking the wrong style of light and reflector. On raw light output, the LED will put out more light, but as for a drop-in, it doesn't work too well compared to an omnidirectional source like incandescents. To get a decent spot with such a shallow reflector space, you need a small die, ala an emitter like an SST-90, and a good, smooth parabolic reflector instead of those today that are optimized for a specific beam pattern out an incandescent.
I'm personally going to hopefully move everything over to LED to keep my generator's load low, so I can run other cool stuff at night as well. |
greenbus pilot Samba Member
Joined: March 14, 2008 Posts: 1285 Location: Wisconsin: Rustbelt, USA baby!!
Posted: Sun Nov 06, 2011 9:40 pm Post subject: Re: Trucklite headlights |
a_and_b1228 wrote: |
I have been running the Trucklite LED headlights on my 79 Bus and its had been a huge improvement at night. The cost is pretty high upfront but it decreased the load on my electrical system significantly. I will post pics if anyone wants to see them. |
Awesome. I first saw them on military vehicles at work, so I turned em on- very nice light. I'm sold- where and how much? I saw Truckliite's website, but found no way to order. Saw them in an off road magazine, I believe they were around 200 bones for the pair.
I would like to learn more. _________________ Sent from a white van down the street. |
MadMax78 Samba Member
Joined: May 26, 2007 Posts: 511 Location: The Netherlands
Posted: Mon Nov 07, 2011 3:22 am Post subject: Re: Trucklite headlights |
I'd love to see some pictures. Will they just drop right in, or did you have to modify or fabricate something to make them fit?
greenbus pilot wrote: |
I would like to learn more. |
They are pretty expensive, $500 for a pair.
http://www.levineautoparts.com/ledheadlight.html _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply , Busted Bus, Aircooled Technology & DIYAutoTune
2008: Amsterdam - Beijing - Olympics -- 17.500km
2010: Amsterdam - Cape Town - FIFA World Cup -- 26.000km
2014: New York - Rio de Janeiro - FIFA World Cup -- 27.000km
http://www.oranjetrophy.nl
Camper Special Club Member |
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3305 Location: Australia
Posted: Mon Nov 07, 2011 5:11 am Post subject: Re: Trucklite headlights |
MadMax78 wrote: |
that is a lot of headlamp bulbs. Perhaps if they drop in price to be $100-$150 each then they would be competitive with replacement assemblies.
No matter what I couldn't use them though. Those integrated parking light bulbs really do make substitution a PITA. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
Posted: Mon Nov 07, 2011 5:50 am Post subject: |
I think itīs better to compare the price to a proper HID setup.
Compared to HID, this is much more reliable, easier to install and has comparable light output. _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
Mathieu2k4 Samba Member
Posted: Fri Nov 18, 2011 6:50 am Post subject: |
does somebody have a picture of it on a bay windows? |
kuleinc Samba Member
Joined: August 10, 2007 Posts: 1604 Location: East Bay Area, California
MaddMatt Samba Member
Joined: April 25, 2009 Posts: 269 Location: tucson arizona
Posted: Fri Nov 18, 2011 9:52 am Post subject: |
I used a flexible 10 inch led strip from pep boys. Ran it along the inside of the gauge housing and wired it to the light switch. No more squinting at night for me. _________________ It will make it. Trust me.
Owned: 71 Superbeetle, 72 Superbeetle, 63 Baja (on 69 pan) 74 baja, 74 Karmann Ghia
Own: 71 Deluxe Bus |
Krautski Samba Member
Posted: Fri Nov 18, 2011 10:46 am Post subject: |
Do you wear sunglasses at night now? _________________ BUS FOR SALE
Quote: |
I stopped reading after volksaru and busaru |
Posted: Fri Nov 18, 2011 11:28 am Post subject: |
Krautski wrote: |
Do you wear sunglasses at night now? |
its about as bright as a new car's gauge display, my cellphone camera makes it look a bit blinding. _________________ It will make it. Trust me.
a_and_b1228 Samba Member
Posted: Tue Dec 27, 2011 10:20 am Post subject: Here are the headlight pics. |
[/img]
They put off a lot more light than a sealed or H4 bulb and use much less power. I was burning fuses with the H4 and now dont have that problem. |
odecom5 Samba Member
Posted: Tue Dec 27, 2011 11:00 am Post subject: Re: Here are the headlight pics. |
[/img]
Looks sweet. Can you post a pic with the lights on, and the field of view at night, maybe? Thanks! |
chabanais Samba Member
sofakingcool Samba Member
Joined: November 13, 2007 Posts: 405 Location: Lexington, SC
Posted: Tue Dec 27, 2011 6:32 pm Post subject: |
We can get them at NAPA.. had a guy just come back from a tour saying they used them on there military vehicles and he wanted me to look them up and I remember they were available in the area.. kinda pricey tho and wish I remember the part number. I know if you give the trucklite people a call they will give you a part number. I may get them but only bc I get a discount. |
Posted: Tue Dec 27, 2011 8:07 pm Post subject: |
The military has used that brand on 100,000+ vehicles and that was from 2009.
Would they mount into the buckets OK? _________________ "I spud therefore I yam." |
Posted: Wed Dec 28, 2011 8:19 am Post subject: |
The ones the dude had me look up were 7in round i believe.. isnt that the correct size? |
Posted: Wed Dec 28, 2011 10:52 am Post subject: |
I will get a night shot next to my beetle tonight. I bought them off ebay but here is the article from trucklite. I had no issues with mounting they fit into the original place with no issues. Did a little cut and re end the wire to fit the h-4 socket. It was easy and a huge improvement. Oh and the trucklite part number is 27250C
trucklite |
Posted: Wed Dec 28, 2011 12:56 pm Post subject: |
yeah that sounds right.. call up any napa and give them that part number and they should be able to look it up. |
pitbug Samba Member
Joined: May 10, 2010 Posts: 549 Location: San Angelo, Tejas
Posted: Wed Dec 28, 2011 12:59 pm Post subject: |
Damn it!! I ordered enough dash LEDs for my bus, ghia & ragtop, I set aside until a warm day Well the warm days are here (60f) and I can't remember where I put those damn lights!!!! I have parts bins for each car....not in any of them.... I bet my wife "put them away" for me.... _________________ 71' Bus "Sunshine"
68 Eriba Puck!! |
