Do you like Bentley topic enumeration in the FAQ |
YES. It is better |
90% |
[ 60 ] |
NO. Leave it alone |
9% |
[ 6 ] |
Total Votes : 66 |
r39o Samba Polizei
Posted: Sat Jan 01, 2011 11:38 pm Post subject: FAQ headings |
From time to time I update the Best Threads sticky which is now called the FAQ.
http://www.thesamba.com/vw/forum/viewtopic.php?t=214760&highlight=notice+stickies
The FAQ at the top of this forum is
http://www.thesamba.com/vw/forum/viewtopic.php?t=151300
Below is the new format:
Last update: January 1, 2011
General:
http://www.roadhaus.com/shops.php ( List of repair shops - Off site )
13 Engine:
http://www.thesamba.com/vw/forum/viewtopic.php?t=202174 ( Build a 2.2 )
http://www.thesamba.com/vw/forum/viewtopic.php?t=212108 ( Fresh pistons and engine break in )
http://www.thesamba.com/vw/forum/viewtopic.php?t=215446 ( 2.1 / 2.2 in a 1.9 case - BAD LINK)
http://www.thesamba.com/vw/forum/viewtopic.php?t=254338 ( Pix of wbx build )
http://www.thesamba.com/vw/forum/viewtopic.php?t=261067 ( Timing )
http://www.thesamba.com/vw/forum/viewtopic.php?t=329143 ( Rod bolt failure! )
http://www.thesamba.com/vw/forum/viewtopic.php?t=297697 ( I4 conversion info )
http://www.thesamba.com/vw/forum/viewtopic.php?t=402096 ( Breather hose collapse )
http://www.thesamba.com/vw/forum/viewtopic.php?t=293764 ( EJ25 Suby swap )
http://www.thesamba.com/vw/forum/viewtopic.php?t=383399 ( EJ25 Suby swap )
http://www.thesamba.com/vw/forum/viewtopic.php?t=402326 ( TDI conversion information )
http://www.thesamba.com/vw/forum/viewtopic.php?t=382910 ( SVX install )
http://www.thesamba.com/vw/forum/viewtopic.php?t=406144 ( 5 cylinder TDI install )
http://www.thesamba.com/vw/forum/viewtopic.php?t=214525 ( Suby STI install )
http://autos.groups.yahoo.com/group/subaruvanagon/ ( Subaru conversion help - off site )
http://www.thesamba.com/vw/forum/viewtopic.php?t=237938 ( EJ22 into 1984 Vanagon )
http://www.thesamba.com/vw/forum/viewtopic.php?t=254008 ( SVX into 1987 Vanagon )
http://www.thesamba.com/vw/forum/viewtopic.php?t=252989 ( Never ending engine conversion debate )
http://www.thesamba.com/vw/forum/viewtopic.php?t=271017 ( Suby conversion fault codes )
15 Cylinder Head Drive Train:
http://www.thesamba.com/vw/forum/viewtopic.php?t=387265 ( GoWesty heads )
http://www.thesamba.com/vw/forum/viewtopic.php?t=215330 ( Ratio Rockers for the wbx - BAD LINK )
http://www.thesamba.com/vw/forum/viewtopic.php?t=215330 ( Collapsible Pushrod Tubes for the wbx - BAD LINK )
http://www.thesamba.com/vw/forum/viewtopic.php?t=130551
http://www.thesamba.com/vw/forum/viewtopic.php?t=173913
http://www.thesamba.com/vw/forum/viewtopic.php?t=177485
http://www.thesamba.com/vw/forum/viewtopic.php?t=156838 ( Related )
http://www.bostonengine.com/articles.html ( Outside link to Boston Bod ideas )
http://www.thesamba.com/vw/forum/viewtopic.php?t=269355 ( Oil pump install )
http://www.thesamba.com/vw/forum/viewtopic.php?t=277611 ( Best oil to use )]
http://www.thesamba.com/vw/forum/viewtopic.php?t=331065 ( Bleeding lifters! )
17 Engine Lubrication System:
http://www.thesamba.com/vw/forum/viewtopic.php?t=112741
http://www.thesamba.com/vw/forum/viewtopic.php?t=104966
http://www.thesamba.com/vw/forum/viewtopic.php?t=116835
http://www.thesamba.com/vw/forum/viewtopic.php?t=270400 ( Oil Cooler )
Oil Pressure:
http://www.thesamba.com/vw/forum/viewtopic.php?t=179889 ( Pressure sender pic at end )
http://www.thesamba.com/vw/forum/viewtopic.php?t=135135 ( Idiot light woes )
http://www.thesamba.com/vw/forum/viewtopic.php?t=177567 ( More idiot light )
http://www.thesamba.com/vw/forum/viewtopic.php?t=156838 ( Low oil pressure links )
http://volksweb.relitech.com/21rodbrg.htm ( outside link to oil pressure related rod bearing failures )
http://www.bostonengine.com/articles.html ( outside link to Boston Bod ideas )
http://www.thesamba.com/vw/forum/viewtopic.php?t=251094 ( 2.1 specfic questions )
http://www.thesamba.com/vw/forum/viewtopic.php?t=251094 ( Dynamic oil pressure testing )
http://www.thesamba.com/vw/forum/viewtopic.php?t=251094 ( Another pressure thread )
19 Engine Cooling System:
http://www.thesamba.com/vw/forum/viewtopic.php?t=234192 ( No mess bleeding )
http://www.thesamba.com/vw/forum/viewtopic.php?t=155493 ( Stainless Coolant Pipes )
http://www.thesamba.com/vw/forum/viewtopic.php?t=396063 ( Stainless Coolant Pipes )
http://www.thesamba.com/vw/forum/viewtopic.php?t=375770 ( Alternate cooling hoses )
http://www.thesamba.com/vw/forum/viewtopic.php?t=404793 ( Cooling system flush and bong fill )
Hoses:
http://www.thesamba.com/vw/forum/viewtopic.php?t=152746
http://www.thesamba.com/vw/forum/viewtopic.php?t=278681 ( Blue silicon replacement hose )
http://www.loam.org/vw/Vanagon/VWtoNapaHoses/ ( Late hose chart - off site )
http://www.thesamba.com/vw/forum/viewtopic.php?t=267876 ( Another Napa hose )
Leaks:
http://www.thesamba.com/vw/forum/viewtopic.php?t=214498 ( Subaru stop leak )
http://www.thesamba.com/vw/forum/viewtopic.php?t=254346 ( Suby stop leak test )
20 Fuel Supply:
http://www.thesamba.com/vw/forum/viewtopic.php?t=136963 ( Gas mileage comparisons )
http://www.thesamba.com/vw/forum/viewtopic.php?t=175058 ( Pressure testing )
http://www.thesamba.com/vw/forum/viewtopic.php?t=255442 ( Fuel line clamps )
http://www.thesamba.com/vw/forum/viewtopic.php?t=268250 ( Nice pictures of hoses and clamps )
http://www.thesamba.com/vw/forum/viewtopic.php?t=180967 ( Alternate fuel pump )
http://www.benplace.com/fuel_line.htm ( Replacing hoses - off site )
http://www.thesamba.com/vw/forum/viewtopic.php?t=339728 ( Fuel pump kill switch )
http://www.thesamba.com/vw/forum/viewtopic.php?t=153149 ( ECU chip tuning - Look for links )
http://www.thesamba.com/vw/forum/viewtopic.php?t=247015 ( Vent tube repair )
http://www.thesamba.com/vw/forum/viewtopic.php?t=354632 ( Syncro tank work )
24 Fuel Injection:
http://www.thesamba.com/vw/forum/viewtopic.php?t=403352 ( MAF and FI part interchange )
http://www.thesamba.com/vw/forum/viewtopic.php?t=135489 ( Replacing injector connector )
http://www.thesamba.com/vw/forum/viewtopic.php?t=227137 ( Wiring and connectors )
http://www.thesamba.com/vw/forum/viewtopic.php?p=1796710 ( Generic Bosch O2 Sensor )
Throttle Body TB fixes ( see further down the threads ):
http://www.thesamba.com/vw/forum/viewtopic.php?t=173913 ( JB Weld fix for worn out TB )
http://www.thesamba.com/vw/forum/viewtopic.php?t=175050 ( Throttle switch )
http://www.thesamba.com/vw/forum/viewtopic.php?t=260986 ( Even more... )
26 Exhaust System:
http://www.thesamba.com/vw/forum/viewtopic.php?t=153910 ( Cleaning exhaust piping )
http://www.thesamba.com/vw/forum/viewtopic.php?t=157580 ( Cleaning exhaust piping )
http://www.thesamba.com/vw/forum/viewtopic.php?t=270833 ( Tuned exhaust for the wbx )
http://www.thesamba.com/vw/forum/viewtopic.php?t=362495 ( Fitting an aftermarket stock exhaust )
27 Electrical - Battery, Starter, Alternator:
http://www.thesamba.com/vw/forum/viewtopic.php?t=165075 ( Inexpensive Alternator regulator / brush set )
http://www.thesamba.com/vw/forum/viewtopic.php?t=114923 ( Aux Batery Install )
http://www.geocities.com/harald_nancy/relay.htm ( aux bat - off site )
http://www.thesamba.com/vw/forum/viewtopic.php?t=363115 ( Adjustable regulator )
http://www.thesamba.com/vw/forum/viewtopic.php?t=395944 ( Another Aux battery w/ pix )
http://www.thesamba.com/vw/forum/viewtopic.php?t=312129 ( BIGGEST Aux in stock location )
http://www.thesamba.com/vw/forum/viewtopic.php?t=288114 ( Good Yandina drawing )
http://www.thesamba.com/vw/forum/viewtopic.php?t=404450 ( High output for a Subaru conversion )
30 Clutch Controls:
http://www.thesamba.com/vw/forum/viewtopic.php?t=324004 ( Clutch job questions and hints )
35 Manual Transmission:
http://www.thesamba.com/vw/forum/viewtopic.php?t=143138 ( Transmissions for Dummies )
http://www.thesamba.com/vw/forum/viewtopic.php?t=445663 ( Shift linkage )
38 Automatic transmission:
http://www.thesamba.com/vw/forum/viewtopic.php?t=109725
http://www.thesamba.com/vw/forum/viewtopic.php?t=109594
http://www.thesamba.com/vw/forum/viewtopic.php?t=144461
http://www.thesamba.com/vw/forum/viewtopic.php?t=253381
http://www.thesamba.com/vw/forum/viewtopic.php?t=292913 ( Cooler install )
http://www.thesamba.com/vw/forum/viewtopic.php?t=401180 ( Freshen and upgrade automatic )
http://www.thesamba.com/vw/forum/viewtopic.php?t=320292 ( Intermittant trouble shooting / rebuild )
http://www.thesamba.com/vw/forum/viewtopic.php?t=403488 ( Good hints and parts source URL )
40 Front Wheel Suspension:
http://www.thesamba.com/vw/forum/viewtopic.php?t=153066
http://www.thesamba.com/vw/forum/viewtopic.php?t=272333 ( Squeaky upper control arm bushings )
http://www.thesamba.com/vw/forum/viewtopic.php?t=276274 ( Vest Ball joints )
http://www.thesamba.com/vw/forum/viewtopic.php?t=274976 ( $45 Synrco U joint replacement )
http://www.thesamba.com/vw/forum/viewtopic.php?t=361395 ( more front shocks )
http://www.thesamba.com/vw/forum/viewtopic.php?t=408047 ( Shocks for GW lift springs )
http://www.thesamba.com/vw/forum/viewtopic.php?t=273255 ( GoWesty vs VanCafe springs )
42 Rear Wheel Suspension:
http://www.thesamba.com/vw/forum/viewtopic.php?t=417210 ( 930 CV axle length )
http://www.thesamba.com/vw/forum/viewtopic.php?t=105142 ( Saggy butt )
http://www.thesamba.com/vw/forum/viewtopic.php?t=151963 ( Aftermarket springs )
http://www.thesamba.com/vw/forum/viewtopic.php?t=314082 ( best shocks )
http://www.thesamba.com/vw/forum/viewtopic.php?t=380912 ( 7 steps to a happier back end )
http://www.thesamba.com/vw/forum/viewtopic.php?t=443526 ( Best CV boots )
44 Wheels Tires Wheel Alignment:
Tires and rims 14”
http://www.thesamba.com/vw/forum/viewtopic.php?t=118284 ( Load rating )
http://www.thesamba.com/vw/forum/viewtopic.php?t=124930 ( White walls )
http://www.thesamba.com/vw/forum/viewtopic.php?t=122022 ( Tire comparisons )
http://www.thesamba.com/vw/forum/viewtopic.php?t=130205 ( Tire differences )
Tires and rims Other than 14”
http://www.thesamba.com/vw/forum/viewtopic.php?t=98909 ( 18 inch wheels )
http://www.thesamba.com/vw/forum/viewtopic.php?t=95179 ( 15 inch converstion )
http://www.thesamba.com/vw/forum/viewtopic.php?t=122205 ( Tire differences )
http://www.thesamba.com/vw/forum/viewtopic.php?t=203519 ( What fits? Ultimate thread! )
Tires 15 inch:
http://www.thesamba.com/vw/forum/viewtopic.php?t=242786 ( Spare tire carrier )
Tires 16 inch:
http://www.thesamba.com/vw/forum/viewtopic.php?t=396793 ( HydoEdge bashing....)
http://www.thesamba.com/vw/forum/viewtopic.php?t=400868 ( More )
http://www.thesamba.com/vw/forum/viewtopic.php?t=236917 ( Spare tire mount )
Wheel related:
http://www.thesamba.com/vw/forum/viewtopic.php?t=254020 ( Stock alloy center cap paint )
http://www.thesamba.com/vw/forum/viewtopic.php?t=225816 ( Safe ET )
http://www.thesamba.com/vw/forum/viewtopic.php?t=333547 ( Hi lift jack )
46 Brakes Mechanical Components:
http://www.thesamba.com/vw/forum/viewtopic.php?t=160055 ( GREAT thread on custom disc brakes! )
http://www.thesamba.com/vw/forum/viewtopic.php?t=331312 ( Another BIG brake )
http://www.thesamba.com/vw/forum/viewtopic.php?t=198340 ( Ford brakes )
http://www.thesamba.com/vw/forum/viewtopic.php?t=402990 ( Ford brakes )
http://www.thesamba.com/vw/forum/viewtopic.php?t=242786 ( Upgraded Syncro brakes and 15 in wheels )
http://www.thesamba.com/vw/forum/viewtopic.php?t=248879 ( More Syncro brake upgrading )
http://www.thesamba.com/vw/forum/viewtopic.php?t=401048 ( Porsche brakes )
http://www.thesamba.com/vw/forum/viewtopic.php?t=371557 ( Porsche brakes )
http://www.thesamba.com/vw/forum/viewtopic.php?t=381146 ( Another brake conversion )
http://www.thesamba.com/vw/forum/viewtopic.php?t=216554 ( Rear Disc for 14 inch wheels )
http://www.thesamba.com/vw/forum/viewtopic.php?t=252434 ( Another rear disc setup )
http://www.thesamba.com/vw/forum/viewtopic.php?t=303634 ( Rear disc with Eurovan rotor )
http://www.thesamba.com/vw/forum/viewtopic.php?t=342425 ( Another rear setup )
47 Brake Hyadraulics
http://www.thesamba.com/vw/forum/viewtopic.php?t=401822 ( Bigger brake booster )
http://www.thesamba.com/vw/forum/viewtopic.php?t=237822 ( Caliper rebuild )
http://www.thesamba.com/vw/forum/viewtopic.php?t=404168 ( Power bleeding- Cracks in reservoir )
48 Steering:
http://www.thesamba.com/vw/forum/viewtopic.php?t=259700 ( Power rack rebuild with pix )
http://www.thesamba.com/vw/forum/viewtopic.php?t=296362 ( Steering wheel exchange )
http://www.thesamba.com/vw/forum/viewtopic.php?t=394038 ( Steering wheel exchange )
Steering column "sheer bolts" - don't really sheer:
http://www.thesamba.com/vw/forum/viewtopic.php?t=175672 ( Look at this crash! )
50 BODY
Painting:
http://www.thesamba.com/vw/forum/viewtopic.php?t=217993 ( Door handles, etc... )
http://www.thesamba.com/vw/forum/viewtopic.php?t=204217 ( Ideas )
http://www.thesamba.com/vw/forum/viewtopic.php?t=264769 ( Lots of Pix )
Rust worms:
http://www.thesamba.com/vw/forum/viewtopic.php?t=181392 ( Where you might find rust )
http://www.thesamba.com/vw/forum/viewtopic.php?t=160752 ( Dealing with rust )
http://www.thesamba.com/vw/forum/viewtopic.php?t=388521 ( Replacing side panel sheet metal )
57 Body Front Doors:
http://www.thesamba.com/vw/forum/viewtopic.php?t=261047 ( Keyless locking locks )
http://www.thesamba.com/vw/forum/viewtopic.php?t=406728 ( Power windows rebuild )
http://www.thesamba.com/vw/forum/viewtopic.php?t=419907 ( Door handle disassembly )
http://www.thesamba.com/vw/forum/viewtopic.php?t=352626 ( Yet another interior hatch release )
58 Body Rear doors:
http://www.thesamba.com/vw/forum/viewtopic.php?t=350008 ( Sliding door bearings )
http://www.thesamba.com/vw/forum/viewtopic.php?t=402052 ( $3 V bearing fix )
http://www.thesamba.com/vw/forum/viewtopic.php?t=228788 ( Early sliding door handle fix )
64 Glass, Window Regulators:
Front Window Windshield Leaks / Dash Removal (Also see Heaters, above!):
http://www.thesamba.com/vw/forum/viewtopic.php?t=190059
http://www.thesamba.com/vw/forum/viewtopic.php?t=190059 ( Dash removal )
Windows:
http://www.thesamba.com/vw/forum/viewtopic.php?t=239291 ( Slider rattle fix with pix )
http://www.thesamba.com/vw/forum/viewtopic.php?t=247018 ( Adding more vented windows )
66 Body Accessories Exterior:
http://www.thesamba.com/vw/forum/viewtopic.php?t=161648 ( Outside mirror repair )
68 Seat Belt System:
http://www.thesamba.com/vw/forum/viewtopic.php?t=188800 ( Rear seat belt )
http://www.thesamba.com/vw/forum/viewtopic.php?t=244354 ( More rear belts )
70 Trim Interior:
(More related items with the heaters below,,,)
72 Body Seats:
http://www.thesamba.com/vw/forum/viewtopic.php?t=292539 ( Lumbar support )
http://www.thesamba.com/vw/forum/viewtopic.php?t=316117 ( Replacement install )
http://www.thesamba.com/vw/forum/viewtopic.php?t=257868 ( Installing Recaros )
http://www.thesamba.com/vw/forum/viewtopic.php?t=444294 ( Installing Eurovan seats w/ pix )
http://www.thesamba.com/vw/forum/viewtopic.php?t=338291 ( Installing Eurovan seats w/ pix )
http://www.thesamba.com/vw/forum/viewtopic.php?t=393280 ( Heated seats )
http://www.thesamba.com/vw/forum/viewtopic.php?t=267239 ( Seat rebuilding, cleaning and heaters )
75 Interior Panels, Roof:
http://www.thesamba.com/vw/forum/viewtopic.php?t=166505 ( Pop Top cleaning )
http://www.thesamba.com/vw/forum/viewtopic.php?t=158370 ( Pop Top cleaning )
http://ace.imageg.net/graphics/product_images/pACE-1189903reg.jpg ( Squirt bottle cleaner )
http://www.thesamba.com/vw/forum/viewtopic.php?t=117615 ( Pop Top Cleaning )
http://www.thesamba.com/vw/forum/viewtopic.php?t=144389 ( Repair - verbose )
http://www.thesamba.com/vw/forum/viewtopic.php?t=241396 ( Replacement - pix - movie )
http://www.thesamba.com/vw/forum/viewtopic.php?t=310345 ( replacement )
76 Cabinets, Water Tank, Refrigerator:
Storage:
http://www.thesamba.com/vw/forum/viewtopic.php?t=195642 ( Hidden Westy storage space )
http://www.thesamba.com/vw/forum/viewtopic.php?t=318998 ( Table mod )
http://www.thesamba.com/vw/forum/viewtopic.php?t=418326 ( Closet door mod )
http://www.thesamba.com/vw/forum/viewtopic.php?t=405894 ( Stainless luggage hold downs )
http://www.thesamba.com/vw/forum/viewtopic.php?t=397722 ( More storage )
http://www.thesamba.com/vw/forum/viewtopic.php?t=370855 ( storage mods )
Water Tank:
http://www.thesamba.com/vw/forum/viewtopic.php?t=184969 ( Water Tank Key )
http://www.thesamba.com/vw/forum/viewtopic.php?t=261167 ( More key madness )
http://www.thesamba.com/vw/forum/viewtopic.php?t=412565 ( Cheap DIY grey water tank )
Westy plumbing:
http://www.thesamba.com/vw/forum/viewtopic.php?t=120652 ( Fixes )
http://www.thesamba.com/vw/forum/viewtopic.php?t=193326 ( Leaks )
Westy Sink:
http://www.thesamba.com/vw/forum/viewtopic.php?t=242401 ( Replacement parts )
http://www.thesamba.com/vw/forum/viewtopic.php?t=339512 ( Drain valve )
http://www.thesamba.com/vw/forum/viewtopic.php?t=370855 ( Sink drain )
Refrigerator / Reefer Madness:
http://www.thesamba.com/vw/forum/viewtopic.php?t=177258 ( R&R with pix and fan install )
http://www.thesamba.com/vw/forum/viewtopic.php?t=137603 ( Driving with prooane on )
http://www.thesamba.com/vw/forum/viewtopic.php?t=175254 ( Temperatures )
http://www.thesamba.com/vw/forum/viewtopic.php?t=174386 ( Ligting fix )
http://www.thesamba.com/vw/forum/viewtopic.php?t=175365 ( Repair shop tip )
http://www.thesamba.com/vw/forum/viewtopic.php?t=155434 ( More tips and links )
http://www.thesamba.com/vw/forum/viewtopic.php?t=84363 ( Has service manual link )
http://www.thesamba.com/vw/forum/viewtopic.php?t=189586 ( Ignitor mod )
http://www.thesamba.com/vw/forum/viewtopic.php?t=267049 ( Door mod )
http://www.thesamba.com/vw/forum/viewtopic.php?t=319847 ( Different frigs )
http://www.thesamba.com/vw/forum/viewtopic.php?t=359831 ( Replacement projects )
http://www.thesamba.com/vw/forum/viewtopic.php?t=175254 ( Another refrigarator thread )
http://www.thesamba.com/vw/forum/viewtopic.php?t=367141 ( Truck frig install )
Propane Tank:
http://www.thesamba.com/vw/forum/viewtopic.php?t=120610 ( Inspection / certify )
http://www.thesamba.com/vw/forum/viewtopic.php?t=100384 ( Removal )
http://www.thesamba.com/vw/forum/viewtopic.php?t=84362 ( Leak / Regulator info )
http://www.thesamba.com/vw/forum/viewtopic.php?t=194491 ( Repaint )
http://www.thesamba.com/vw/forum/viewtopic.php?t=204063 ( Adapting to run on propane bottles )
http://www.thesamba.com/vw/forum/viewtopic.php?t=166046 ( Adaptng with more links to pix )
http://www.thesamba.com/vw/forum/viewtopic.php?t=244556 ( Adapting a one pound bottle )
http://www.thesamba.com/vw/forum/viewtopic.php?t=179909 ( Leaks - verbose )
http://www.thesamba.com/vw/forum/viewtopic.php?t=262077 ( Valves revisted )
http://www.thesamba.com/vw/forum/viewtopic.php?t=353952
80 Heater Ventilation:
http://www.thesamba.com/vw/forum/viewtopic.php?t=194648 ( Nice pix of EVIL rear heater repair )
http://www.thesamba.com/vw/forum/viewtopic.php?t=125554 ( More EVIL rear heater )
http://www.thesamba.com/vw/forum/viewtopic.php?t=148377 ( Verbose rear heater repair )
http://www.knology.net/~vw/vanagon/dash ( Front heater - off site )
http://www.vanagonauts.com/[80.10---80.16]-Heater-Blower-R&-R118.htm ( Off site )
http://www.thesamba.com/vw/forum/viewtopic.php?t=211360 ( "Quick" flap repair )
http://www.thesamba.com/vw/forum/viewtopic.php?t=155324 ( Propex install in back cabinetry )
http://www.thesamba.com/vw/forum/viewtopic.php?t=265457 ( Front heater with movies! )
http://www.thesamba.com/vw/forum/viewtopic.php?t=277861 ( Cable mod )
http://www.thesamba.com/vw/forum/viewtopic.php?t=280285 ( Blower motor rebuild with pix )
http://www.thesamba.com/vw/forum/viewtopic.php?t=280629 ( Box conversion early and late with pictures )
http://www.thesamba.com/vw/forum/viewtopic.php?t=329618 ( More front heater )
http://www.thesamba.com/vw/forum/viewtopic.php?t=220677 ( Propex install with pix )
http://www.thesamba.com/vw/forum/viewtopic.php?t=350367 ( More Propex pix )
http://www.thesamba.com/vw/forum/viewtopic.php?t=386923 ( Heater fan lubrication - Mullendore fix)
http://www.thesamba.com/vw/forum/viewtopic.php?t=395661 ( Fan lube - Mullendore Port )
http://www.thesamba.com/vw/forum/viewtopic.php?t=313093 ( Atwood Furnace )
http://www.thesamba.com/vw/forum/viewtopic.php?t=418934 ( Another Propex install )
http://www.thesamba.com/vw/forum/viewtopic.php?t=237271 ( Hot foot syndrome )
http://www.thesamba.com/vw/forum/viewtopic.php?t=385553 ( Replacement front heater core )
http://www.thesamba.com/vw/forum/viewtopic.php?t=438042 ( $50 "perfect" heater core )
http://www.thesamba.com/vw/forum/viewtopic.php?t=385553 ( $50 heater core search )
87 Air Conditioner:
http://www.thesamba.com/vw/forum/viewtopic.php?t=292488 ( Redtek )
90 Electrical System, Instruments, Radio:
Speedometer:
http://www.twistedlimbpaper.com/brian/vanagon/Odometer.htm ( Odometer fix - off site )
http://www.thesamba.com/vw/forum/viewtopic.php?t=292298 ( Another Odometer fix - with pix )
Aux Instruments / Extra Gauges / Tach:
http://www.thesamba.com/vw/forum/viewtopic.php?t=193593 ( Lots of pix )
http://www.thesamba.com/vw/forum/viewtopic.php?t=210987 ( Blue lighting )
http://www.thesamba.com/vw/forum/viewtopic.php?t=197904 ( Tach face )
http://www.thesamba.com/vw/forum/viewtopic.php?t=197904 ( Tach install )
Coolant Temperature Gauge:
http://www.thesamba.com/vw/forum/viewtopic.php?t=184096 ( Testing flashy thingie - LED )
http://www.thesamba.com/vw/forum/viewtopic.php?t=195839 ( Coolant pressure gauge ideas )
http://www.thesamba.com/vw/forum/viewtopic.php?t=168239 ( Repair - verbose )
Audio and speaker upgrades:
http://www.basementmediaproductions.com/vanagon/vanagon.htm ( Offsite )
http://www.thesamba.com/vw/forum/viewtopic.php?t=168674
http://www.thesamba.com/vw/forum/viewtopic.php?t=256415 ( 6 inch door speakers )
http://www.thesamba.com/vw/forum/viewtopic.php?t=270721 ( Interior pix )
Cigar / Cigarette lighter socket:
http://www.thesamba.com/vw/forum/viewtopic.php?t=151026 ( Detailed pix )
http://www.thesamba.com/vw/forum/viewtopic.php?t=201330
92 Electrical System - Windshield Washer and Wiper:
http://www.thesamba.com/vw/forum/viewtopic.php?t=393970 ( 3 way nozzles )
http://www.thesamba.com/vw/forum/viewtopic.php?t=383000 ( Variable wipers )
94 Electrical System - Lights:
http://www.thesamba.com/vw/forum/viewtopic.php?t=214519 ( HI - lo beam relays )
http://users.qadas.com/~kanas/Vehicles/Syncro/South_African_Grille_Procedure.html ( SA grill - off site )
http://home.jps.net/~zezoff/vanagonheadlight.html ( Home brew SA - off site ) (BAD LINK)
http://www.thesamba.com/vw/forum/viewtopic.php?t=185350 ( Tail lamp uprade with pix )
http://forums.nasioc.com/forums/showthread.php?t=954736 ( Head light bulbs - off site - thx Dogpilot )
http://www.thesamba.com/vw/forum/viewtopic.php?t=331043 ( More tail lamp modding )
http://www.thesamba.com/vw/forum/viewtopic.php?t=358179 ( Headlamp relay with pix - late vanagon )
http://www.thesamba.com/vw/forum/viewtopic.php?t=274814 ( Ugraded square headlamps for cheap with pix )
Inverters:
http://www.thesamba.com/vw/forum/viewtopic.php?t=159091
http://www.thesamba.com/vw/forum/viewtopic.php?t=179788
http://www.thesamba.com/vw/forum/viewtopic.php?t=257635 ( Wiring up a Westy )
Interior Lighting:
http://www.thesamba.com/vw/forum/viewtopic.php?t=216335 ( Interior lighting project )
http://www.thesamba.com/vw/forum/viewtopic.php?t=267794 ( Cold cathode tube swap )
Insulation / Sound Deadening:
http://www.thesamba.com/vw/forum/viewtopic.php?t=112637
http://www.thesamba.com/vw/forum/viewtopic.php?t=140472
http://www.thesamba.com/vw/forum/viewtopic.php?t=143577
http://www.thesamba.com/vw/forum/viewtopic.php?t=198673
http://www.thesamba.com/vw/forum/viewtopic.php?t=197811 ( Nice pix )
http://www.thesamba.com/vw/forum/viewtopic.php?t=162330 ( Engine lid )
http://www.thesamba.com/vw/forum/viewtopic.php?t=254839 ( Sound Measurements )
http://www.thesamba.com/vw/forum/viewtopic.php?t=309709 ( Transmission tunnel )
http://www.thesamba.com/vw/forum/viewtopic.php?t=381226 ( UHMW Tape )
http://www.thesamba.com/vw/forum/viewtopic.php?t=413959 ( Engine hatch foam )
Smells:
http://www.thesamba.com/vw/forum/viewtopic.php?t=319550
Discussion:
http://www.thesamba.com/vw/forum/viewtopic.php?t=138670 ( Westy Vs. Weekender debate )
http://www.thesamba.com/vw/forum/viewtopic.php?t=254335 ( Riviera vs. Westy debate )
Modified Vans:
http://www.thesamba.com/vw/forum/viewtopic.php?t=257076
http://www.thesamba.com/vw/forum/viewtopic.php?t=261490 ( V6 TDI )
http://www.thesamba.com/vw/forum/viewtopic.php?t=261042
http://www.thesamba.com/vw/forum/viewtopic.php?t=403009 ( Trailer made from a Vanagon )
http://www.thesamba.com/vw/forum/viewtopic.php?t=364878 ( Westy conversion )
http://www.thesamba.com/vw/forum/viewtopic.php?t=349105 ( Converting a 2WD into a Syncro )
http://www.thesamba.com/vw/forum/viewtopic.php?t=412486 ( Mid engine conversion ) _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Posted: Sun Jan 02, 2011 8:17 am Post subject: |
Thanks, Walt! That is a lot of work and I want you to know that it is very much appreciated. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Sun Jan 02, 2011 8:31 am Post subject: |
Wowzer, this is great! I have not looked at this in some time. Thanks for maintaining this; as a fellow web gnome I know this a lot of work.
My only suggestion is to have a short text description after every link, to more easily find useful threads; although I understand that not all threads lend themselves to easy descriptions.
Hippo Gnu Deer,
CJ _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
Zeitgeist 13 Samba Member
Posted: Sun Jan 02, 2011 8:35 am Post subject: Just curious... |
Does this forum software allow you to embed links behind text? I see that some signatures can do this, but I can't figure out how to do it within posts. These lists would be a lot cleaner if the reader just had to read a subject line and then click on it. Most other fora allow this feature.
From a general usability perspective, I like the way this is organized. As I've mentioned before, I think the conversion subjects/topics should be broken out and organized into their own separate categories. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Jan 02, 2011 8:42 am Post subject: |
LOVE it! Haven't been there for a while, but it's really great. Thanks for your work on this!
Yes, I've seen links behind text on Samba but I'm not enough of a guru to know what to do. That would be a WHOLE 'nother project.
Yeah, descriptions on EVERY link would be even more helpful - perhaps include a nugget of the original topic, ie: "floppy mirror syndrome" makes it easier to find, rather than "mirror repair".
My $.02...thanks again! _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
foodeater Samba Member
Joined: July 13, 2007 Posts: 1318 Location: Newburgh, NY
Posted: Sun Jan 02, 2011 3:11 pm Post subject: |
Nice! _________________ 89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9798 Location: Mt Lemmon, AZ
Posted: Sun Jan 02, 2011 3:26 pm Post subject: Re: Just curious... |
Zeitgeist 13 wrote: |
Does this forum software allow you to embed links behind text?... |
Let's see if it does: Harbor Freight
Okay, that worked.
You do the url tag with your link but then insert an equals sign after the "url", and put the text after the forward slash at the end of the link and finishing with a url 'close tag'.
Can't figure out how to show an example that doesn't cause it to happen. |
Posted: Sun Jan 02, 2011 3:40 pm Post subject: Re: Just curious... |
Ahwahnee wrote: |
Okay, that worked. Here is the text used in that example:
"Harbor Freight" [/url] |
So it looks like you have to manually add the "=" and "]" tag bracket around the hyperlink, but it's doable. Way harder that it should be...
Thanks!
O2 Monitor _________________ Casey--
y u rune klassik? |
r39o Samba Polizei
Posted: Sun Jan 02, 2011 10:12 pm Post subject: Embeeded URLs |
OK. I do NOT have "THAT" much time to embedded "all" those URLs. Somebody else can have fun with it. I would guess creating an editor macro or some script might do it. Show me what you envision. We'll see how it looks. OK?
Thanks,
Walt... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
kamzcab86 Samba Moderator
ursaworks Samba Member
Joined: December 03, 2010 Posts: 127 Location: Chicago, IL, USA
Posted: Wed Jan 12, 2011 2:42 pm Post subject: |
truly we are not worthy
thank you _________________ 1987 2WD GL Automatic
Westfalia full camper
Vanistain engine |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Wed Jan 12, 2011 3:05 pm Post subject: |
Much appreciated by less mechanical like me. Thank You.
Any chance on "Other Vanagon Models" and "Eurovans"? Probably not enough input to list all separately but some groupings? Would help the people looking for info on Vanagons that are not Westy nor Syncros. Just a thought. TY Zee _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
Camp&Ride Samba Member
Posted: Wed Jan 12, 2011 3:38 pm Post subject: |
excellent organization method. So much info on Samba, its great to get at what you're looking for in short order! _________________ 2WD 86 Westy
Zetec Inside |
akyrie Samba Member
Joined: March 24, 2010 Posts: 519 Location: Driftless, Wisco
JunkYarDog Samba Member
Joined: March 11, 2007 Posts: 676 Location: New Mexico
Posted: Wed Jan 12, 2011 9:16 pm Post subject: |
The fact is with the simplicity of that, you would be more likely to refer one to perform a FAQ search as opposed to searching the entire forum. _________________ I have never owned a VW I didn't like, but there have been a few Fords and Chevy's.
85' GL Sunroof
68' Beetle sedan
72' Chevy C10 (LWB Step)
(67' Volvo 122S pending) |
Posted: Thu Jan 13, 2011 1:01 am Post subject: |
Links converted to titles (also dead links removed; new links added; "missing" titles are no longer missing; etc.). "r39o": To get the code for your nifty sticky, reply to my post with the quote button. (or PM me and I'll email the Word doc).
General:
Replace your fuel lines!
13 Engine:
Stigma attached to WBX?
Building a 2.2
Pics of a WBX build
2.1 rebuild
Timing
Rod bolt failure!
Conversions:
I4 conversion info
EJ22 Subaru swap into 1984 Vanagon
EJ25 Subaru swap
EJ25 Subaru swap – pt. 2
SVX install
Subaru STI install
AAZ into 1988 Vanagon
GoWesty heads
Ratio rockers for the WBX
Ratio rockers for the WBX – pt. 2
Collapsible Pushrod Tubes for the WBX
Collapsible Pushrod Tubes for the WBX – pt. 2
Noisy valves/lifters
Noisy valves/lifters – pt. 2
Noisy valves/lifters – pt. 3
Adjusting hydraulic lifters
Bleeding lifters!
Best oil & filter to use
Best oil brand & weight to use
Best oil to use; synthetic discussion
Oil pump install
Best oil to use
External oil cooler – air-cooled engines
External oil cooler – WBX
Oil Pressure:
Pressure sender photo (at end of thread)
Idiot light woes
Idiot light woes – pt. 2
Oil pressure-related rod bearing failures
2.1-specific oil pressure questions
No mess system bleeding
The Libby Bong
Stainless Coolant Pipes – pt. 1
Stainless Coolant Pipes – pt. 2
Stainless Coolant Pipes – pt. 3
Hoses:
Blue silicone replacement hose
VW to NAPA hose conversion chart
NAPA hoses for early Vanagons
NAPA hose replacement for 1.9L
Leaks:
Subaru stop leak
Subaru coolant conditioner warning
20 Fuel Supply:
Replacing fuel lines Gas mileage comparisons
Pressure testing
Fuel line clamps
Alternate fuel pump
Vent tube repair
Syncro fuel tank work
24 Fuel Injection:
Throttle Body (TB) fixes:
JB Weld fix – pt. 2
Throttle switch
26 Exhaust System:
Inexpensive alternator regulator / brush set
High output alternator for a Subaru conversion
Aux battery install
Aux battery install – bad link
Another aux battery w/ pix
Biggest aux battery in stock location
Good Yandina wiring diagram
30 Clutch Controls:
Shift linkage
Is an A/T good for a Westy?
Should I be afraid of an A/T?
Campground rebuild
A/T cooler install
Freshen and upgrade an A/T
Intermittent shifting troubleshooting & rebuild
Whiteline anti-sway bars
Vest ball joints
$45 Syncro U-joint replacement
More travel from front shocks
Shocks for GoWesty lift springs
GoWesty vs. Van-Cafe springs
930 CV axle length
Saggy rear end
Aftermarket springs
Best shocks
Best CV boots
44 Wheels, Tires, & Wheel Alignment:
Tires & wheels – 14”:
Whitewalls
Tires & wheels – 15":
Installing Audi brakes & wheels on a Syncro
Modifying spare tire carrier for 215/75R15 BFG
15 inch wheel conversion
BRM discussion
Tires & wheels – 16":
HydoEdge vs. Yokohama & BFG....
Tires for 16x7 wheels
16" in spare tire mount (dead photos)
Tires and wheels – 17" and larger:
18 inch wheels
Tires – general:
Load ratings
HydroEdge vs. Vanco; load ratings
Tire differences
Wheels – general:
What fits? Ultimate thread! – pt. 2
Safe ET (offset)
Hi-lift jack
Custom disc brakes – Great thread!
DIY big brake kits
Using Ford brakes
Using Ford brakes – pt. 2
Installing Porsche brakes
Porsche brakes – pt. 2
2WD brake conversion
Rear disc conversion for 14" wheels
Rear disc conversion for 15" wheels
Rear disc conversion with EuroVan rotors
47 Brake Hydraulics
Caliper rebuild
Power bleeding; cracks in reservoir
48 Steering:
Steering wheel exchange – pt. 2
Look at this crash!
50 Body
Painting:
Ideas
Rust worms:
Dealing with rust
57 Body – Front Doors:
Keyless door lock installation
Power window motor rebuild
Interior rear hatch release/latch
58 Body – Rear doors:
Sliding door horizontal roller bearings
$3 sliding door vertical roller bearing fix
64 Glass (Windows), Window Regulators:
Windshield sealant
Removing windshield and repairing rust
Removing/installing front door glass
Power window stuck down
Adding power windows & locks
Replacing manual window regulator
Rebuilding power window regulators
Replacing power regulators with manual regulators
Replacing power regulators with manual – pt. 2
Slider window rattle fix with pics
Adding opening rear side windows
Window insulating blankets/curtains
66 Body Accessories – Exterior:
Curing Floppy Mirror Syndrome
Adding a shower – pt. 1
Adding a shower – pt. 2
Installing 3-point rear seat belts
Adding 3rd rear lap seat belt & GoWesty shoulder belts to a Westy
70 Trim – Interior:
Dash removal
Show me your interiors!
72 Body – Seats:
Installing lumbar support
Installing Porsche seats
Installing Recaros
Installing Eurovan seats into Vanagon w/ pix
Installing Eurovan seats w/ pix – pt. 2
Installing heated seat inserts
75 Interior Panels – Roof:
Removing mildew/mold from pop top
Removing mildew/mold from pop top – pt. 2
Removing mildew/mold/dirt from pop top – pt. 3
Repairing the tent canvas & screen
Replacing the tent - pix - movie
Replacing the tent – pt. 2
76 Westfalia Camper – Cabinets, Water Tank, Refrigerator:
Storage:
How to pack to reduce clutter
Making a support sleeve for the rear table
Modifying rear table for closet access
Adding fridge door to rear closet
Stainless luggage tie-downs
Storage container for luggage rack
Modifying firewall for storage
Water Tank:
Water tank key
Water tank key – pt. 2
Westy plumbing:
Fixes
Leaks
Westy Sink:
Replacement parts
Adding a valve to drain line
Rerouting sink drain
Cheap DIY gray water tank
Driving with propane on
Temperatures
Ligting fix
Repair shop tip
More tips and links
General discussion
Dometic PDF Service Manual
Ignitor mod
Door mod
Door mod & cooling fans
Coleman & Sunfrost refrigerators
TruckFridge installation
Propane Tank:
Inspection/Certification
Removal
Leaks / Regulator info
Leaks – pt. 2
Valves revisited
Repainting
Adapting to run on BBQ tank w/ photos
Adapting to run on one pound bottle
Installing an Extend-A-Stay fitting
80 Heating & Ventilation:
Curing Hot Foot Syndrome
"Quick" vent flap repair
Cable mod
Replacing front heater core – with movies!
$50 "perfect" heater core search
$50 heater core – pt. 2
Front heater assembly
Front blower motor rebuild with pics
Replacing front blower motor
Lubricating heater fan – Mullendore fix
Lubricating heater fan – Mullendore fix pt. 2
Rebuilding the front heater box with pictures
Pictures of EVIL rear heater repair
Propex heater install with pics
More Propex heater pics
Installing Atwood furnace
87 Air Conditioner:
Converting your A/C system to Redtek
Speedometer/Odometer:
Odometer fix
Another odometer fix with pics
The Gauge Thread
Gauge faces & tach install
Testing the warning light & level sensor
Repair - verbose
Sound insulation & audio install
Speaker recommendations
6-inch door speakers
Replacing the lighter
Green lighter bezel
2-way nozzles
3-way nozzles
Variable intermittent wipers
Exterior Lighting:
Adding headlight relays
Adding headlight relays – late Vanagon
Installing H4 headlight bulbs for cheap – late Vanagon
South African grille & light installation
Adding bulbs to the tail lights
Adding bulbs to the tail lights – pt. 2
Everything you need to know about headlight bulbs - thx Dogpilot
Party lights
Installing LEDs (includes a link to PDF bulb conversion table)
Inverters:
Installing an inverter
What size inverter?
Wiring up a Westy
Interior Lighting:
Indiglo cluster lighting
Cruise control indicator light
Flexible LED lighting
Sound deadening – pt. 1
Sound deadening – pt. 2
Sound deadening – pt. 3
Sound deadening – pt. 4
Insulation & flooring pics
Sound measurements
Transmission tunnel
UHMW Tape
Re-insulating engine lid
Re-insulating engine lid – pt. 2
Smells:
Getting rid of "smelly van"
Discussion:
Westy vs. Weekender debate
Never-ending engine conversion debate
Modified Vans:
V6 TDI
Rebuilding of a German Army Syncro
Westy conversion
Mid-engine conversion _________________ ~Kamz
2016 Golf GTI S
Posted: Thu Jan 13, 2011 5:28 am Post subject: |
awESSSOOOme _________________ I have never owned a VW I didn't like, but there have been a few Fords and Chevy's.
85' GL Sunroof
68' Beetle sedan
indytriple Samba Member
Joined: April 27, 2009 Posts: 710 Location: Brownsburg, Indiana
Posted: Thu Jan 13, 2011 6:53 am Post subject: |
Thanks for the hard work, gentlemen. This is a nice improvement. _________________ "See The Glass As Already Broken."
87 Vanagon Westy Auto Bostig
www.bluegrassbicyclecompany.com |
akyrie Samba Member
Posted: Thu Jan 13, 2011 7:03 am Post subject: |
Thanks you, I appreciate your work. |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10077 Location: Abiquiu, NM, USA
Posted: Thu Jan 13, 2011 8:15 am Post subject: |
Very very nice, thanks to everyone for the work on this. Now we can tell tem to "search the FAQ". I love it!
Really smart to categorise with the Bentley headings, too. I believe those are the actual VW work group numbers as well. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
