211 201 157A NLA? Whats the best work around?
levi20AE
levi20AE is offline
PostPosted: Sun Jan 02, 2011 11:42 pm    Post subject: 211 201 157A NLA? Whats the best work around? Reply with quote
The elbow for the vent to the fuel filler neck on my '73 needs to be replaced. I stole the photo from another site because the part number is actually visible.
It is part number 22 in the diagram below, pay no attention to the image of the elbow pictured because it is incorrect.
I have searched a bit on google looking for a 1/2" silicone elbow that would do the job but no luck thus far. Has anyone come up with a suitable solution?
View user's profile Send private message Instagram Classifieds Feedback
Amskeptic
Amskeptic is offline
PostPosted: Sun Jan 02, 2011 11:48 pm    Post subject: Re: 211 201 157A NLA? Whats the best work around? Reply with quote
levi20AE wrote:
The elbow for the vent to the fuel filler neck on my '73 needs to be replaced. Has anyone come up with a suitable solution?
Cut back the steel/copper line a bit and muscle on the biggest local FLAPS fuel hose you can muster up, like 3/8" 7/16" even?
Look for small rubber oil line with correct nominal I.D. ?
Colin
www.itinerant-air-cooled.com
nodrenim
nodrenim is offline
PostPosted: Mon Jan 03, 2011 5:21 am    Post subject: Reply with quote
I had to replace the one on my 72 a short time ago. I used a pvc plumbing elbow.I had to wrap the metal pipe with plastic electrical tape to enlarge it to fit inside the pvc elbow, then used pvc cement to bond it together, worked out rather well. Good Luck!
SGKent Premium Member
SGKent is offline
PostPosted: Mon Jan 03, 2011 7:33 am    Post subject: Reply with quote
your image comes from or shall we say matches that of VWHeritage.com in the UK. Their online system shows the part available. Did they tell you the part was NLA?
Also http://en.serial-kombi.com/centre-fuel-elbow-72-N3343.html shows one for sale on their website.
Last year I had the same part without an A for sale but it looks totally different.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Wildthings
Wildthings is offline
PostPosted: Mon Jan 03, 2011 10:23 am    Post subject: Reply with quote
Not sure the diameter of the elbow you need, but I would guess that there is a turbo oil return line elbow out there somewhere that will fit and far outlast the original VW part. Probably some vent line elbows off of other rigs that would work as well.
busdaddy
busdaddy is offline
PostPosted: Mon Jan 03, 2011 10:43 am    Post subject: Reply with quote
The PCV line from an 84 Honda Accord has donated 2 or 3 of those for my buses so far and still has a couple of bends left in it, I'm sure other cars have similar fuel proof hoses with molded bends.
Слава Україні!
Tcash
Tcash is offline
PostPosted: Sun May 08, 2016 4:05 pm    Post subject: 211 201 157 A Elbow Breather line Reply with quote
211 201 157 A use Audi 321 611 939 E (321611939E)
ECS Tuning
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/vacuum-hose/321611939e/
#11 thanks to jerseylooker
Tcash
Abscate
Abscate is offline
PostPosted: Sun May 08, 2016 4:21 pm    Post subject: Re: 211 201 157A NLA? Whats the best work around? Reply with quote
Buy FLAPS hose too long and put in a loop to fit. Will also eliminate strain.
.ssS!
barefootwestie
barefootwestie is offline
PostPosted: Fri Aug 18, 2017 6:51 am    Post subject: Re: 211 201 157A NLA? Whats the best work around? Reply with quote
Any updates on a possible replacement for 211201157A?
My Bus Restoration Blog
https://myvolkswagenbus.com/
1973 Westfalia
"Getting better....one repair at a time."
Other VW's owned through the years, in no particular order:
'67 Beetle,
'67 Ghia Hardtop,
'72 Ghia Convertible,
'72 Westfalia
jtauxe Premium Member
jtauxe is offline
PostPosted: Fri Aug 18, 2017 7:02 am    Post subject: Re: 211 201 157A NLA? Whats the best work around? Reply with quote
https://www.coolairvw.co.uk/Item/Shop_by_Vehicle~B...Elbow.html
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
barefootwestie
PostPosted: Fri Aug 18, 2017 7:36 am    Post subject: Re: 211 201 157A NLA? Whats the best work around? Reply with quote
Not exactly the same with the same 90 degree turn but may have to resort to it. Thanks.
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia
barefootwestie
PostPosted: Fri Aug 18, 2017 7:41 am    Post subject: Re: 211 201 157A NLA? Whats the best work around? Reply with quote
Wonder if this would work for us:
https://www.carbuildersolutions.com/de/gates-extra-service-12mm-id-90deg-rubber-hose-bend
1973 Westfalia
'67 Beetle,
'67 Ghia Hardtop,
'72 Westfalia
SGKent is offline
PostPosted: Fri Aug 18, 2017 9:01 am    Post subject: Re: 211 201 157A NLA? Whats the best work around? Reply with quote
the link I still posted years ago still works and they still have them.
ToolBox
ToolBox is offline
PostPosted: Fri Aug 18, 2017 9:03 am    Post subject: Re: 211 201 157A NLA? Whats the best work around? Reply with quote
Just run a longer piece of fuel hose from the filler neck to the tank eliminating the elbow, hard line and shorter flex line. Or bend an appropriate 90 in stainless and use 2 short pieces of hose.
lightice
lightice is offline
PostPosted: Fri Aug 18, 2017 9:55 am    Post subject: Re: 211 201 157A NLA? Whats the best work around? Reply with quote
Tcash gave the replacement audi part number.
321611939E
Use that to search various stockists, should be able to get one.
rastomas
rastomas is offline
PostPosted: Fri Aug 18, 2017 10:06 am    Post subject: Re: 211 201 157A NLA? Whats the best work around? Reply with quote
11mm ID. I would put a loop in if you can't find the molded part.
"It's not 'You are what you eat', it's 'You are what you don't SHIT". Wavy Gravy.
'74 Westy
CarlosZ
CarlosZ is offline
PostPosted: Fri Aug 18, 2017 5:29 pm    Post subject: Re: 211 201 157A NLA? Whats the best work around? Reply with quote
Prior to removal and cleaning, my fuel vent was capped off and fill ups were slow and agonizing. I used one long piece of fuel hose and connected the vent straight to the other end along the fuel filler tube. I'm under the assumption there is enough room between the firewall and vent tube for the hose to make the 90 degree towards the filler neck. The fuel hose I used was rather pliable and didn't kink when bent by hand. There might be a slight kink, but I can't tell once the firewall is up. All I can say is that fill ups are now a breeze.
Terminatez
Terminatez is offline
PostPosted: Mon Oct 02, 2017 5:04 pm    Post subject: Re: 211 201 157A NLA? Whats the best work around? Reply with quote
Such a challenge to find this elbow in 2017. Most of what thesamba has found to replace this isn't available anymore. d'oh!
Looping a hose around seems to be the current option, but even finding 11mm ID fuel hose isn't as easy here. Guess it'll have to be PCV hose.
Now is it 11mm ID for the elbow part and then 12mm ID hose for the pipe to filler connection? Or is it all at 11mm?
I can't find the 211201157A p# online anymore. Brick wall Brick wall Brick wall
I'm blind and saw the rest of the post tcash posted and found the one on ecstuning
I found these elbows, now sure if they work for this application.
http://www.justkampers.com/321-611-939-e-centre-fuel-elbow-vw-t2-bay-1967-1972.html
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D113%2D201%2D179%2DA
1972 Westfalia P30 hardtop Campmobile [On-going Restoration]
aeromech wrote:
I don't think I've ever seen an engine in worse shape.
raygreenwood
raygreenwood is offline
PostPosted: Mon Oct 02, 2017 5:15 pm    Post subject: Re: 211 201 157A NLA? Whats the best work around? Reply with quote
Or...get a length of hose and push a properly sized stainless coil spring inside of it so it,does not kink. Ray
Terminatez
PostPosted: Mon Oct 02, 2017 5:18 pm    Post subject: Re: 211 201 157A NLA? Whats the best work around? Reply with quote
Yea, that's what I was thinking too. Going to be calling some FLAPS this weekend to see if they carry something that will fit.
