Silverghost500 Samba Member
Joined: August 01, 2018 Posts: 1089 Location: Atlanta, GA
Posted: Mon Jun 07, 2021 5:10 pm Post subject: O2 Sensor Removal from Catalytic Converter |
I have a replacement O2 sensor ready, and want to get the one installed out. I've got an O2 socket, but I cannot get it down on the nut of the sensor where it meets the catalytic converter. The metal protective saddle isn't the issue. There's some kind of metal clip on the body of the sensor between where the wires enter the metal housing and the nut, and it doesn't appear to want to come off.
Any suggestions on how to approach removing this one?
_________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A converversion-Road Testing Phase
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Mon Jun 07, 2021 6:52 pm Post subject: Re: O2 Sensor Removal from Catalytic Converter |
1. Get your particulate mask on;
2. Dremel cut off the shield (a nice-to-have-but not necessary item);
3. Dremel cut off the oxygen sensor below the metal clip;
4. Use your socket wrench. _________________ '86 Syncro Westy SVX |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4800 Location: Bemidji, MN
Posted: Mon Jun 07, 2021 7:11 pm Post subject: Re: O2 Sensor Removal from Catalytic Converter |
or cut the shield off and get a rilly big cresent or 6 point closed wrench on it, slid down the disconnected wires. heat it up on the base with MAPP gas (vs propane) and whack the wrench with a 3lb mechanics hammer. _________________ -dan
www.thefixitworkshop.com |
4Gears4Tires Samba Member
Posted: Tue Jun 08, 2021 6:32 am Post subject: Re: O2 Sensor Removal from Catalytic Converter |
That metal shield should pop off with a screwdriver and then your O2 sensor socket should fit. If it's not popping off, cut it off like suggested above.
Knock both of these tabs downward with an open needle nose pliers/screwdriver or something along those lines.
YMMV but I have used this method a few times if the sensor is not budging by hand.
1. Use your O2 sensor socket with a breaker bar
2. Apply PB Blaster and hammer on socket/breaker bar
3. Wrap several runs back and forth of a strong cord to another vehicle around the handle of the breaker bar
4. Drive forward.
_________________ '87 Syncro
Posted: Tue Jun 08, 2021 6:57 am Post subject: Re: O2 Sensor Removal from Catalytic Converter |
Thanks for the suggestions. I'll see if I can get something to try and pop off those metal tabs. If not, out comes the Dremel.
Is this setup OEM with the tabs and the half-saddle shield on the catalytic converter? Most everything that came up on my searches on removing an O2 sensor is the 85 or older where it appears to be easy access on an exhaust manifold. I'm sure it's not an easy out with an area of that many temperature cycles and rust. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Tue Jun 08, 2021 2:36 pm Post subject: Re: O2 Sensor Removal from Catalytic Converter |
@Ahwahnee-That's the socket I have. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
