Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Thu Dec 13, 2012 11:08 pm Post subject: |
i was gonna say have one guy push on the lever, while another kicks from inside with a single steady push (not repeated bangin on the door) _________________ Stuart Zickefoose
206-841-7324
[email protected] |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Thu Dec 13, 2012 11:16 pm Post subject: |
Stuartzickefoose wrote: |
i was gonna say have one guy push on the lever, while another kicks from inside with a single steady push (not repeated bangin on the door) |
Agreed. Also try the steady push on both the front and rear. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Fri Dec 14, 2012 9:15 am Post subject: |
busdaddy wrote: |
while a helper turns the handle down |
Do keep that in mind. I bet using the push and pull method it'll open.
Oh, and I’d love to see pictures in a new thread if you get a chance! _________________ 1976 Westy
1966 Beetle |
Posted: Tue Mar 26, 2013 9:44 pm Post subject: |
just because i fixed another one today, i made this video. just to impress the fact that this is SO easy to remove, you have no excuse to not take the door all the way off to replace the seal. NO excuse.
i struggled only because i did not remove the cover. i highyl recommend removing the cover if you can do so.
but even struggling with it...less than a minute to remove completely.....cmon...no excuse.. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
sunvale1 Samba Member
Joined: October 11, 2010 Posts: 84 Location: Michigan
Posted: Sat Oct 19, 2013 6:00 am Post subject: slider removal |
The side door slider was a great write up, but I need some information like it on how to take out the sliding ROOF without braking it or me or the chain that works it.
Hopefully somebody has a write up on it some place. _________________ I'm from the government, I'm here to help! |
obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 2940 Location: East Northport, NY
Posted: Sat Oct 19, 2013 7:56 am Post subject: |
That's a horse of a different color...
I just checked and the Bentley has a great section on the sunroof. Take a looksie. _________________ Mike
1964 Beetle
2001 Eurovan Camper |
1967250s Samba Member
Posted: Sat Oct 19, 2013 8:05 am Post subject: |
Do a search. There are a couple threads for the roof. |
christine72 Samba Member
Joined: August 31, 2014 Posts: 84 Location: Portland, Oregon
Posted: Sun Dec 28, 2014 10:24 pm Post subject: Daylight through new door seal |
Replaced the sliding door seal (correctly) and have light seeping in along front edge after adjusting the door using the Bentley instructions.
Closes with gaps equal all around. Top, bottom, back flush with the body. But front edge only flush with body near roof and floor. Latches, releases, locks, retainer catches and remote handles release it. BUT that light leak - which equals a water leak right!
Thoughts? _________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
1967 Fastback (my first car); 1971 Square back; Several Jettas '88 -'97
The one I regret not buying:
72 Karmann Ghia, with autostick.
Posted: Sun Dec 28, 2014 10:27 pm Post subject: |
Your seal could be inside out. It's easy to install backwards, but it only seals one way. Could you post a close-up picture of your installations? I can't find any close-ups of both at the moment.
Posted: Sun Dec 28, 2014 10:53 pm Post subject: |
Have exact same problem, but i thought my door may be bent... major air leak for sure. Not water yet though. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
wcfvw69 Samba Purist
Posted: Mon Dec 29, 2014 7:17 am Post subject: Re: Daylight through new door seal |
christine72 wrote: |
Closes with gaps equal all around. Top, bottom, back flush with the body. But front edge only flush with body near roof and floor. Latches, releases, locks, retain catches and remote handles release it. All got BUT that light leak - which equals a water leak right!
BUT, light is coming through along the front at the latch/lock. Door is flush with body at top, bottom and back. But on the front end it's flush with the body near roof and floor, but not in between.
Thoughts? |
Where did you purchase the seal and where was it made? The quality is all over the place for door rubber these days. I bought an engine lid seal from Wolfsburg West for my 70'. It leaves a LOT to be desired and the lid doesn't close correct due to it. I'm currently looking for another seal made by someone else.
As mentioned, post some pics of your seal installation and of the gap in the door when it's closed. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sat Feb 21, 2015 7:23 pm Post subject: |
asiab3 wrote: |
Your seal could be inside out. It's easy to install backwards, but it only seals one way. Could you post a close-up picture of your installations? I can't find any close-ups of both at the moment. |
I'll give pictures another try. I took a dozen or so, but none worked out. _________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
72 Karmann Ghia, with autostick. |
Posted: Sat Feb 21, 2015 7:28 pm Post subject: Re: Daylight through new door seal |
wcfvw69 wrote: |
As mentioned, post some pics of your seal installation and of the gap in the door when it's closed. |
Bought it at Halsey Automotive Parts in Portland Oregon. I asked them if it was made in Germany, and they couldn't say. It was the only one in stock though, and my bus was getting saturated.
At least it's dried out now. But it seems water will ultimately get in.
Not only that, but my door opened as it should, with a spring in it's step and sliding unasisted down the track. Not any more. Catches on the rubber. I'll try to get pictures again. _________________ '74 Bay - ASI camper body w/'72 Bay - undercarriage and a '76 2000cc rebuilt engine
Past VWs
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20275 Location: Sandpoint, ID
Posted: Sun Jan 10, 2016 11:55 am Post subject: Re: Sliding Door Hinge Assy Refresh |
I just finished replacing the swing arm on my sliding door mechanism on my 69 storage shed. This thread was very useful. I took a few photos, and have a few observations.
Here is a photo of an early (69) and a late (not sure of exact year donor) door side housing. (using the Bentley nomenclature)
Early one is on top in this photo...
Early...
later...
_________________ nothing |
Posted: Sun Jan 10, 2016 11:57 am Post subject: Re: Sliding Door Hinge Assy Refresh |
Here are comparison shots of the slider/roller mechanism.
Early...
Later...
Posted: Sun Jan 10, 2016 12:11 pm Post subject: Re: Sliding Door Hinge Assy Refresh |
And here is a shot of the pieced together conglomeration of parts that is now installed and sliding well. Gotta keep the neighborhood cats from pissing on my parts pile.
A few observations... This job was not nearly as difficult as I thought it would be. I am just a backyard mechanic with a decent set of tools, a willingness to try, and a wood heated garage.
I cleaned and lubed things as necessary, but was not concerned with appearances since this bus is used for storage. On a nice bus, I would follow the lead and paint things all pretty and shiny.
Getting the long spring pulled onto its hook was a challenge, but the right combo of screwdriver size and curse words made it fall into place. Beer helped. I also had to replace the operating cam, as the original had cracked in half. Colin's photos showing proper orientation of that cam were very helpful.
Notice the differences in some of the parts in the photos. The early housing is bushed where the swing arm passes through, the later setup just rides directly in the cast housing. Not sure what it better, but the late swingarm does not fit into the early housing. Different shaft/bushing diameters. Good to know when sourcing parts.
The bus on which this door hangs is missing the forward 1/3 of its bottom track due to rust, so I have to hold the door up during the open/close operation. A patch for that is next on the list.
I came very close to screwing some big ass strap hinges to this door and the side of the bus, but I just could not bring myself to screw into the original paint. Call me a softy, but I couldn't do it. _________________ nothing |
Tcash Samba Member
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Fri Mar 04, 2016 9:41 am Post subject: |
chabanais wrote: |
Nice!
You can also buy a new one for $45.
The bearing itself easily pressed out of my roller using the same puller I used to pop the roller off the slider piece.
The bearing number on the shaft says the size/type is FAG 607-RS.
Searching Amazon revealed that bearings of this size (19 OD x 7 id x 6 tall) are available as roller skate bearings. I just ordered a 10-pack for about $10.
We shall see how they do in the long term, but I imagine they'll be pretty good. _________________ Dave Cook
1973 Wild Westerner
My Thing |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Fri Mar 04, 2016 10:33 am Post subject: |
vwwestyman wrote: |
chabanais wrote: |
Nice!
We shall see how they do in the long term, but I imagine they'll be pretty good. |
Same here, I just pressed out the old and installed a new one. Much better now. New bearing was about $8 at the bearing house down the street from work. |
Posted: Fri Mar 04, 2016 2:19 pm Post subject: Re: Sliding Door Hinge Assy Refresh |
Okay new plan...I'm gonna get new bearings now instead of lubing the old ones ....sounds way more effective. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
