Miklo ¡Chale!
Joined: August 27, 2008 Posts: 2058 Location: Antelope Valley, Ca
Posted: Fri Jan 07, 2011 11:30 am Post subject: Auto-stick singleport carb and wiring harness question. |
A friend of mine has a single port engine and an autostick trans.
The carbs throttle shaft is leaking pretty bad so she needs a new carb. What carb can she use?
I think I remember Auto-stick carbs having an extra vaccum port?
Anyone know what can be used and where she might be able to get one?
Another question.
Its a '69 and also needs a new complete wiring harness.
Being an Autostick do they make those harnesses anymore? If so where can we get one?
Any help would be great, thanks. _________________ ✠Miklo✠
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote: |
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche... |
Bookwus Samba Member
Joined: August 30, 2003 Posts: 1786 Location: City of Roses
Posted: Fri Jan 07, 2011 12:47 pm Post subject: |
Hiya Doug,
First off know this............. AutoStick carburetors are different that their manual transmission brothers. Yes, they do have an extra vacuum port among other changes. However, a standard (for example) 30PICT3 can be converted for use on an AutoStick by a a talented and careful tech. Probably much better to buy an AS specific 30PICT3 from kiefernet right here at the Samba.
There are no AutoStick specific wiring harneses of which I am aware. But a common approach is to buy a 69 standard wiring harness and then simply add in the AS portion of the harness that one might need. _________________ Mike
1970 AS Bug
1970 Bus - The Ruptured Duck
Have an AutoStick? Check out www.auto-stick.com |
Miklo ¡Chale!
Posted: Fri Jan 07, 2011 12:48 pm Post subject: |
Cool, much appreciated!!! _________________ ✠Miklo✠
'55 Type1 "Ozma"
