1978 Champagne first bus
Page: Previous  1, 2, 3 ... 43, 44, 45, 46, 47  Next
secretsubmariner
Champagne Wrangler
secretsubmariner is offline
PostPosted: Wed Jun 29, 2016 10:03 am    Post subject: Re: 1978 Champagne first bus Reply with quote
Stuartzickefoose wrote:
Chisel carefully into one side of the switches hold in screw in the losses direction. Creates a new slot plus loosens it.
Wow, I'm sorry Stuart, but I'm having trouble putting your string of words into a coherent statement Laughing
-Tony
1978 Champagne Edition II (Mar)
1978 Champagne Edition II (Feb - sold)
1978 Champagne Edition II (Jan - sold)
1978 Westfalia Auto Deluxe (sold)
78Kombi wrote:
dude but im a nigerian prince
Tcash
Tcash is online now
PostPosted: Wed Jun 29, 2016 10:12 am    Post subject: Re: 1978 Champagne first bus Reply with quote
How tight should the wiper arms be on the body?
Just tight enough to squash the seal slightly. You do not want to over tighten them and squeeze the seal out.
I've been having trouble getting the headlight switch out.
Try soaking it for a few day with rust penetrant.
A small hole saw will cut the nut off.
Good luck
Tcash
secretsubmariner
Champagne Wrangler
PostPosted: Wed Jun 29, 2016 11:23 am    Post subject: Re: 1978 Champagne first bus Reply with quote
Thanks T. I'll probably back the nuts off a turn or two.
-Tony
secretsubmariner
Champagne Wrangler
PostPosted: Wed Jul 06, 2016 6:09 am    Post subject: Re: 1978 Champagne first bus Reply with quote
I reassembled the dash last night.
I also started pulling the headliner out. With the ever-so-slight windshield leak saturating the unfurled corners where the visors mount, the rust and white colored powdery drip marks all over my dash just weren't happening anymore. F that in the A. I don't care if it looks like shit for a while. I'll probably put some sound deadener down and do a tin top westy style ceiling later on.
I'm beginning to think that maybe I shouldn't have reassembled it completely...if something doesn't work it's gonna mostly have to come back apart.
Confession: I took a dremel to the escutcheon I buggered on the headlight switch. I fucked up. I sliced my dash Crying or Very sad That bastard had to die, though. It wouldn't come off with penetrating oil, the tool specially made for it wouldn't work, hammering the son of a bitch wouldn't work, it wouldn't twist or turn to loosen. So I went commando and I paid for it. Yesterday was a particularly bad day of working on the bus. Hopefully today is better.
What's coming tonight (other than your mom):
"If it doesn't rain today, maybe I can take the interior out to remove the headliner."
"Where THE F*CK are the windshield wiper nuts I acquired?"
-Tony
vwwestyman
vwwestyman is offline
PostPosted: Wed Jul 06, 2016 6:44 am    Post subject: Re: 1978 Champagne first bus Reply with quote
I don't know how bad your cut is, but I used one of those Permatex Vinyl and Leather repair kits to fix the hole I made in my dash pad while trying to fix the mounting stud.
It is very hard to tell unless you're looking for it. I don't think anyone but me would ever notice it.
Dave Cook
I'm gonna punch vwwestyman then shake his hand when I meet him.
notchboy wrote:
Ill just punch you in the face. Wink
1973 Wild Westerner
My Thing
secretsubmariner
Champagne Wrangler
PostPosted: Wed Jul 06, 2016 6:48 am    Post subject: Re: 1978 Champagne first bus Reply with quote
Laughing
You have given me hope. Thanks.
-Tony
secretsubmariner
Champagne Wrangler
PostPosted: Fri Jul 08, 2016 4:50 pm    Post subject: SecretSubby's Super Secret Fuel Doors! Reply with quote
Now that I guess I'm done with wiring up front (for now) [until something ELSE pops up and doesn't work anymore], it's time to finally peek behind my firewall.
I want 0 gas vapors in the bus. F that in the A.
From page 5:
secretsubmariner wrote:
I'll let you draw your own conclusions from these
There are metal straps that are bolted to the body, and bolted somewhere behind the tank. But they've been cut/broken.
and again
it's like that on both straps
Well, the B.S. straps are still donezo. I shoulda had Stu use his neanderthal-ish strength to help me loosen those bolts, he's gotta a thicker skin than I do Laughing So I PB'laster'd them and I'm gonna see how they're doing this weekend. Here's the tank today:
Right-o!
I popped off my pie plate ECU cover thing for the very. first. time. ever. and found that some bozo scrawled something on my ECU at some point! Never in my bus'ses's'es history have I ever had any real clues about its past or anything, save for a library card I found in the glove box. I don't know how to remove the ECU, so I left it for now, will attempt to remove along with the tank, at least to get a picture of it. Razz
Also, many of you have seen your Previous Owner's cut handy and grotesque fuel sender access doors. But how many of you have been graciously gifted with FUEL FILLER NECK DOORS?!
SWEET!^^ It does not really help AT ALL!
Here's the condition of my filler neck on the outside.
Upon taking a closer look, someone has repaired this, maybe more than once, with RTV. It will have to go.
And, I though this was funny, I went to remove the battery ground, and wound up with a perfectly misaligned bolt (plus bonus dremel battle scar!)
This was only a prep-day, lots of spiders, and dog pee on the tires is starting to stink in the humid Oklahoma summer.
It's like Bala says, try to do something every day to stay motivated Wink
-Tony
Stuartzickefoose
Samba Post Whore
Stuartzickefoose is offline
PostPosted: Sat Jul 09, 2016 10:37 am    Post subject: Re: 1978 Champagne first bus Reply with quote
The ECU is two 10mm screws top and bottom where the plug is and then yank hard, as its clipped in snugly. Tipping it top or bottom gets it out of the clip sometimes too.
Stuart Zickefoose
Synergy Solutions
Self Employed Mechanic (Aircooled or watercooled, certified and trained on just about anything with 4 wheels) give me a call if you need some work done!
1980 Westy~Corkey
206-841-7324
[email protected]
secretsubmariner
Champagne Wrangler
PostPosted: Mon Aug 01, 2016 7:01 am    Post subject: Re: 1978 Champagne first bus Reply with quote
Stu came by, 2400+ miles on Maisy. Holy cow Shocked
Buses + murals = The Buccaneer, Tulsa's oldest bar.
So good to see an old friend!
-Tony
secretsubmariner
Champagne Wrangler
PostPosted: Wed Apr 05, 2017 5:50 am    Post subject: Re: 1978 Champagne first bus Reply with quote
-Tony
Xevin Premium Member
Xevin is offline
PostPosted: Wed Apr 05, 2017 6:24 am    Post subject: Re: 1978 Champagne first bus Reply with quote
Welcome to The Samba Wink
Keep on Busin'
Clatter wrote:
sunnydog wrote:
(This probably is Xevin's new signature line quote: Sunnydog said:"just the tip...")
Abscate wrote:
I dont hate anyone on the Samba - except for Xevin - who brought me cold coffee in the morning.
[email protected] wrote:
secretsubmariner
Champagne Wrangler
PostPosted: Mon May 08, 2017 8:00 am    Post subject: Re: 1978 Champagne first bus Reply with quote
had to wait for the cam gear to show up.
-Tony
riverside66
riverside66 is offline
PostPosted: Tue May 09, 2017 8:30 am    Post subject: Re: 1978 Champagne first bus Reply with quote
Seriously one of my favorite build threads. Awesome work man, keep it up! It's truly inspiring (and helpful too)!
1979 Transporter - "Wheatbread" https://www.thesamba.com/vw/forum/viewtopic.php?t=624582
Not a coincidence that the 4 on a keyboard is also the $ key.
secretsubmariner
Champagne Wrangler
PostPosted: Thu May 25, 2017 8:37 am    Post subject: Re: 1978 Champagne first bus Reply with quote
Oh thanks bud! I kinda started to feel like a homeless person muttering to myself, so I decided to be less of a talker, more of a do-er.
1. I moved. Took a while to get settled.
2. Stuart AND Robbie (of Bay Forum fame) visited me this year [at different times]
3. My engine rebuild is probably halfway done.
4. Preparation for roof insulation, followed by some slightly custom wiring is happening now.
Test fitting my Reflectix fit
Can't put it all the way back together until I'm done
Rust conversion still holding up very nicely.
Small pinhole in front floor board:
General Pornography:
More engine shit today after work. Got my greasy Tom Wilson book ready.
-Tony
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Thu May 25, 2017 8:40 am    Post subject: Re: 1978 Champagne first bus Reply with quote
"General Pornography."
New band name.
Engine pics. Needed.
Robbie.
www.airschooled.com
Three rules of troubleshooting:
1. Do the easiest thing first.
2. Don't rely on the guy before you. He was not able to fix the problem.
3. 90% of problems are between the driver's seat and the steering wheel.
secretsubmariner
Champagne Wrangler
PostPosted: Thu May 25, 2017 12:47 pm    Post subject: Re: 1978 Champagne first bus Reply with quote
Thanks Robbie, LOL
I will have *something* to update tonight.
-Tony
secretsubmariner
Champagne Wrangler
PostPosted: Wed May 31, 2017 11:23 am    Post subject: Re: 1978 Champagne first bus Reply with quote
Following Wilson, I checked, cleaned, and lubed my oil pump, and installed it. I also properly torqued the case fasteners all the way around, and installed piston rings on the all pistons. Lost my piston ring compression tool in a move somewhere, so I stopped there for the day. The only pics from that day:
-Tony
Kirk
Kirk is offline
PostPosted: Wed Jun 07, 2017 2:07 pm    Post subject: Re: 1978 Champagne first bus Reply with quote
Tony still kicking ass with the hoss kicked bus. Glad to see progress.
Bear
Super
Hobbes
Oppenheim
View user's profile Send private message Visit poster's website Yahoo Messenger Instagram Gallery Classifieds Feedback
secretsubmariner
Champagne Wrangler
PostPosted: Fri Jul 14, 2017 1:03 pm    Post subject: Re: 1978 Champagne first bus Reply with quote
Gettin' down to BIZNUTZ
Endplay is fucky so we're taking to a guy on Tuesday
-Tony
secretsubmariner
Champagne Wrangler
PostPosted: Wed Jul 19, 2017 7:42 am    Post subject: More on endplay Reply with quote
The pistons are in the cylinders. Before putting them on, we tried to set the endplay. Installed the shims I removed when we busted it apart, I got the flywheel locking tool on, torqued the bolts to 80 ft. lbs. The dial indicator showed our motion from 0 to about 12 thousandths if we pried the flywheel away from the case. Then it would spring back to about 3...not staying where we budged it to, and not returning to zero either.
Reading the red Wilson book, I knew I needed a different assortment of shims. Fortunately, my friend Adam recently picked up a huge stack of them during a wild VW parts uncovering in Kansas a while back. UNFORTUNATELY, NONE were small enough to give me endplay within spec.
So, we called it a day and scheduled an appointment with Mike, a semi-retired professional ACVW mechanic who served our area for about 30 years at reputable shops. Good friend of my friend. (Connections, people)
His garage is AIR CONDITIONED. So that was nice. After mic'ing a bunch of type 4 shims, practically every single one, we realized that none of us had any shims that would be the right size.
This led me down the rabbit hole, something I refer to as a
TYPE 4 UNOBTAINIUM RUN
Where one has to run around trying to find those weird little type 4 parts.
A phone call to RennSport Tulsa led me to the right shims (hopefully). It'll be 5 days and they're a whopping $12 each. So that's neat.
Once this is addressed and my endplay is within spec, its just installing P+C's, heads, then we're really gonna be soaring.
Soon, my long-lost tribe of weirdos. Soon.
-Tony
Page 44 of 47
