Wanted: Information on Doka Canopy Suppliers
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
canvas guy
canvas guy is offline
PostPosted: Sun Feb 10, 2013 8:16 pm    Post subject: Reply with quote
BenT, yes it's moi, Mr. BZ.
Velcro certainly is an option, although my goal is to make them eventually like OG as possible. No Swedish stuff for moi, except IKEA!
BenT Syncro
BenT Syncro is offline
PostPosted: Sun Feb 10, 2013 11:37 pm    Post subject: Reply with quote
Mr. BZ clearly hasn't been busy w/ a Swede of the female variety. Twisted Evil
I can appreciate making them as OG as possible. Just thought that it would be just as simple to make the canopy OG and keep the oval holes and belt. But keep the buckle off. Wink
BenT
canvas guy
PostPosted: Mon Feb 11, 2013 12:57 pm    Post subject: Reply with quote
I can appreciate making them as OG as possible. Just thought that it would be just as simple to make the canopy OG and keep the oval holes and belt. But keep the buckle off. Wink[/quote]
BenT-Other than the former Mrs. T. Woods, Abba, Uma Thurman, The Swedish Bikini Team, etc., I prefer my females to be heavy duty Germanic stock, like Mrs. BZ!
Buckles, smuckles!
NOS Vanagon Doka Strap Detail
OG Detail after 25 years
91Transporter16"
91Transporter16" is offline
PostPosted: Thu Feb 21, 2013 10:05 am    Post subject: Reply with quote
Here is another rack that I'm working on. My intention for this rack is to be able to place a canoe on top. Several people around here are interested in making more of these.
The rack in not being designed to mount a canvas but it could happen.
The tube material is 6061 Aluminum 2.875" outside dia ans .203"
wall thickness.
With this size tube you can also mount a spare tire on the back. This rack is being made now. I will have it mounted on the DoKa in a few weeks.
I'll take pictures when it's done.
My Nato canopy design is on hold for now. Sad
Last edited by 91Transporter16" on Tue Mar 05, 2013 12:21 pm; edited 1 time in total
BenT Syncro
PostPosted: Thu Feb 21, 2013 6:08 pm    Post subject: Reply with quote
Crying or Very sad
BenT
mmmdiesel
mmmdiesel is offline
PostPosted: Thu Feb 21, 2013 8:02 pm    Post subject: Reply with quote
Bman can you tell me more about this vinyl conditioner that you used? Brand? Supplier? Thanks,
Gregg
1998 T4 Caravelle 2.5 Tdi
2000 Eurovan Multivan 2.8 VR6
1960's Heilite Single Wheel
canvas guy
PostPosted: Fri Mar 01, 2013 2:33 pm    Post subject: Reply with quote
Here are 2 pics of the knock down version of the German style full height hoops, designed to be bolted together after being shipped-all other details as per OG, I believe as I have seen 2 different styles.
The 2nd pic is of the front cab bar that goes in the canopy front to fasten the front flap to the cab w/ hold down connections on the front hoops. We will sell that separately also as the OG version has this piece heat welded into the canopy & it can't be removed w/ o cutting or ungluing flap! Our canopies will have velcro closure to allow piece to be inserted or removed from our canopies.
We will make a solid hoop assembly that will be able to ship by bus & will be less expensive. That hoop will also have a rounded outside corner like 1 OG hoop (syncrodoka's) that I have seen.
YMMV
[img]
[/img]
[img]
BenT Syncro
PostPosted: Fri Mar 01, 2013 2:44 pm    Post subject: Reply with quote
Nice job, Mr. BZ. What about the longitudinal ribs?
Since I sold my German tilt, I can't recall if the corner posts were U-channels or square tubing like my Swedish tilt.
BenT
canvas guy
PostPosted: Fri Mar 01, 2013 3:40 pm    Post subject: Reply with quote
Longitudinal ribs or "bows" are 1" dia galvanized steel tubing, known locally as electrical conduit or EMT available at your local Home Despot, etc. for about 50 cents a LF.
My hoops are made from 12 gauge rolled steel into channels w/ the same dimensions as OG. The corner foot pieces are also 3 sided bents like OG.
See pic of bow lengths for Dokas & SC's. These dimensions are for reference only-use them at your own risk.
[img]
BenT Syncro
PostPosted: Fri Mar 01, 2013 4:43 pm    Post subject: Reply with quote
Interesting mod to the original design. Very creative. Applause Applause
BenT
xavior12
xavior12 is offline
PostPosted: Sat Mar 02, 2013 12:20 am    Post subject: Reply with quote
Wow! Just Wow! I love what you've done to recreate the Tilt top.
Question. Can a Swedish style headache bar be used to secure the sides of the tent behind the cab instead of the vertical channel pieces you use?
When can I send money for my new Tilt Top?!
BenT Syncro
PostPosted: Sat Mar 02, 2013 3:46 am    Post subject: Reply with quote
Don't know if Tom is going to make a Swedish tilt. But to throw my 2 cents in there, my Swedish tilt just goes over the headache rack. The headache racks seem to differ slightly from the once used with with the Vindic canopy in that there are square tubing receivers welded to the ones used with tilts. The tilt that I have does come with two extra "legs" so they can be used without the headache rack. It all appears stock. The only reason I am not 100% sure is because I recently saw a Swedish tilt which had been modified to have an roof rack of sorts. The corner posts were extended through the roof corners and rack attach on top. I don't think this arrangement was stock because it effectively loses water intrusion integrity at those corners. However, they are so well done that the rack looks like it came from the factory that way.
That said, my wish list is to get a tilt canvas for my Swedish tilt which secure like the German canvas instead of having all those giant rubber bands securing the sides and rear flaps.
BenT
canvas guy
PostPosted: Sun Mar 03, 2013 3:33 pm    Post subject: Reply with quote
Still working on final pricing & what it includes, such as canopy w/ or w/o gutter bar, hoops & gutter bar or just hoops, break down or 1 piece hoops, etc.
Stay tuned.
Bent, send moi dimensions of Swedish Bikini Team hoops & we will start planning on making those-should be easier than German, but I agree on the subing the bungees out.
Send cash in small denominations to [email protected] or just Paypal, checks!
BenT Syncro
PostPosted: Sun Mar 03, 2013 5:18 pm    Post subject: Reply with quote
Stay tuned.
Are you going to any VW events in my part of the country? I can loan you a complete tilt including rubberized canvas.
BenT
canvas guy
PostPosted: Sun Mar 03, 2013 7:49 pm    Post subject: Reply with quote
I am coming out to Sacramento in the next month or 2 to pick up a syncro doka from Jeff-if I time the visit right, might make Syncro Fest, if not, then at least I will be in the state.
BenT Syncro
PostPosted: Sun Mar 03, 2013 10:31 pm    Post subject: Reply with quote
Which one are you getting? I saw three there a couple of weeks ago. I know the green 16" is going to Alaska. There was Marsala(?) Red and and white one. Can recall but possibly a blue one there too. I'm 2 hours south west of Jeff. Might get a chance to drop it by there or see you at SF. The thing is I am only likely going to SF for one day. Typically Thursday only.
BenT
comet42
comet42 is offline
PostPosted: Sun Mar 10, 2013 11:56 pm    Post subject: Reply with quote
Following this thread with interest!
If i had unlimited time on my hands, i'd fool around with this:
A bug-based DIY design from the 70s. The back half looks like a Nato shell crossed with a popup camper
More here: http://www.rqriley.com/phx.html
86 Doka (Suby 2.2)
73 Squareback (sold)
79 Bus - Champagne Edition (sold)
BenT Syncro
PostPosted: Mon Mar 11, 2013 12:05 am    Post subject: Reply with quote
The "Phoenix" was based on a VW bus and not a bug.
BenT
Bman
Bman is offline
PostPosted: Mon Mar 11, 2013 8:59 am    Post subject: Reply with quote
Gregg
mmmdiesel, sorry I just saw your post. To restore the shine and condition to the stock tilt I used a product called "Black Again" that I got from my local FLAPS store. I've used it to shine the plastic on my dash, mirrors and rubber seals. Of course I have to apply it at least 2-3X a year to keep the shine. For the tilt it seems to last a few months. I tend to use my tilt only during the summer months May-October (winter here is high winds and rain) and I applied it at least twice during that time it is UV activated. Until I know better I'm satified with this product.
http://www.superiorcarcare.net/blackagain1.html
~Bryan
1990 Burgandy Tintop (Wife's Daily Driver)
1989 Tiico Westfalia "Taj"
1986 Tintop Syncro (Project)
1984 2WD Doka Transporter (Daily Driver)
2WD Doka build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=503578&highlight=
FaceHook:
https://www.facebook.com/pages/VW-T3-DokaSinka/129026087217120?ref=hl
VwDubber
VwDubber is offline
PostPosted: Thu May 30, 2013 1:32 pm    Post subject: Reply with quote
Does anyone make a Doka cover that could just cover the Bed while the Sides are up?
Think they might be called a "Taunna Cover" <= spelling?
Guess it wouldn't be too tuff for a Boat Canvas maker, just thought I'd check to see if one was offered, or packaged?
Page 6 of 7
