joshgold10 Samba Member
Joined: February 26, 2010 Posts: 222 Location: Foster City CA
Posted: Fri Dec 10, 2010 5:00 pm Post subject: Distributor Models |
Is there a list somewhere of what models Dizzys work with what year bus? I have a 72' 1.7
Thanks! |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4532 Location: Arizona Highways
chabanais Samba Member
Posted: Fri Dec 10, 2010 5:30 pm Post subject: |
Interesting I have a 71 and have used a 009 for 12 years and it's not listed as working for a 71. _________________ "I spud therefore I yam." |
SGKent Samba Member
Posted: Fri Dec 10, 2010 5:34 pm Post subject: |
chabanais wrote: |
Interesting I have a 71 and have used a 009 for 12 years and it's not listed as working for a 71. |
don't go there. This arguement will go two days before it dies. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76761 Location: Sneaking up behind you
Posted: Fri Dec 10, 2010 5:37 pm Post subject: |
chabanais wrote: |
Just because it fit doesn't mean it work well. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Dec 10, 2010 5:48 pm Post subject: |
Thanks for the link! Looked there but not the right area.
So really what is the difference in models if the dizzy will fit? |
Glenn Mr. 010
Posted: Fri Dec 10, 2010 5:51 pm Post subject: |
joshgold10 wrote: |
Different total advance, different curves. There's vacuum only, mechanical only, vacuum/mechanical, single vacuum, dual with advance and retard. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Dec 10, 2010 5:55 pm Post subject: |
So...then it would be interesting to see a cross reference of what will work in what bus years and what diff timing you need to compensate for the diff in dizzys? Or maybe some cannot be swapped at all? I ask this because I have a few I keep as spares are diff models and just purchased a use one on samba pulled from a 1.8 with a petronix. |
Posted: Fri Dec 10, 2010 5:56 pm Post subject: |
Mine werks real good.
Glenn wrote: |
chabanais wrote: |
Just because it fit doesn't mean it work well. |
Glenn Mr. 010
Posted: Fri Dec 10, 2010 6:02 pm Post subject: |
A 71 originally had a 1600 Type 1 engine. Personally i'd want a vacuum advance distributor in a heavy Bus to give it a bit more advance when it's under load.
Good is a relative term if you have no reference. There is better.
While this is a totally different vehicle, it's from someone who thought his vehicle "werks real good", until he tried something better.
Quote: |
I bought a rebuilt BR9 distributor from you 2 weeks ago for my 57 Speedster to replace the VW transporter distributor that it has had for over 20 years. I wouldn't have changed distributors if it weren't for the oil leakage problem I was having. I felt my car ran great. It idled well, seemed smooth at high speed and had no bad characteristics. That is until I put in your distributor. Apparently what I thought was great wasn't even good. First of all my car runs 30 degrees cooler at high speeds. It revs faster, it runs faster. It runs significantly better in every way. And this is in a car that by consensus was considered a great running car. If I was told there would be this much difference I would not in any way believe it. Not considering how well the car ran before.
Member #1009
#BlueSquare |
Posted: Fri Dec 10, 2010 6:06 pm Post subject: |
I had a SVDA on their before and it ran okay for 3 years. I'm happy with my 009 but I wonder if it decreases fuel economy. I'm not married to it and have to use it or anything. 95% of the time it's just me in the Bus with nothing but the seats seems to do fine. Maybe the dual carbs and 1776 are why? _________________ "I spud therefore I yam." |
SGKent Samba Member
Desertbusman Samba Member
Posted: Fri Dec 10, 2010 9:28 pm Post subject: |
chabanais wrote: |
I'm happy with my 009 but I wonder if it decreases fuel economy. I'm not married to it and have to use it or anything. 95% of the time it's just me in the Bus with nothing but the seats seems to do fine. Maybe the dual carbs and 1776 are why? |
I'll put my bus with baby Webers and an 009 up against other setups for the gas mileage. I'd tell what my trip mileage is again but SG would need his meds. Right Steve? _________________ 71 Superbug
71 Westy |
SGKent Samba Member
Posted: Fri Dec 10, 2010 9:33 pm Post subject: |
Desertbusman wrote: |
chabanais wrote: |
I'll put my bus with baby Webers and an 009 up against other setups for the gas mileage. I'd tell what my trip mileage is again but SG would need his meds. Right Steve? |
lalalalalalalalal talk to the hand Mike _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
bigbore Samba Member
Joined: December 19, 2003 Posts: 3296 Location: Wasilla Alaska
Posted: Sat Dec 11, 2010 12:13 am Post subject: |
here we go again Iam going to get my stick. _________________ where its cold and snowy |
Bleyseng Samba Member
Posted: Sat Dec 11, 2010 3:15 am Post subject: |
chabanais wrote: |
yeah, but to get that mileage you go 45 mph on the freeway! _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Sat Dec 11, 2010 10:13 am Post subject: |
Nope, around 60 _________________ 71 Superbug
71 Westy |
Posted: Sat Dec 11, 2010 12:51 pm Post subject: |
Getting away from original question. So unusual!
Is there a cross ref. what dizzys will work in what engines/years with or without modifications? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Dec 11, 2010 1:49 pm Post subject: |
joshgold10 wrote: |
No, because each one is curved for a specific combination of engine, gearing and vehicle weight they don't interchange. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Type3Baja Samba Member
Joined: February 07, 2005 Posts: 25 Location: Seattle, Wa
Posted: Sat Dec 11, 2010 9:00 pm Post subject: |
Well then, could you tell a noob how to determine what dizzy you have and what dizzy you SHOULD have?
I ask because I want to buy points and a rotor this week, but my engine, I think, is far from original. When a local mechanic opened the engine hatch he shook his head and said "another hodge-podge pos..." I'm not sure the pos is accurate but it was to that effect. POS is what I think about it |
