JLT Samba Member
Joined: September 23, 2008 Posts: 162 Location: Sacramento CA
Posted: Sun Nov 17, 2013 11:09 am Post subject: |
vintagevwnut wrote: |
I use a inner tube on mine. Won't have to worry about that. |
I contacted Aaron of singlewheel.com, who is Da Man when it comes to all things single-wheeled. He wrote back:
Quote: |
You're right about the bead popping and the cause being the small back and forth motion getting into the parking spot. It sounds like the wheel assembly got a little bound up, and pushed the tire sideways against its normal direction popping the bead. The tube should help to resolve the problem, but I would also look into the play on the wheel assembly, the tire pressure you are running, and even your hitch. If you plan on doing something like that again, the least amount of play in the wheel assembly and the hitch the better. Or just go lift the back end of the trailer up and spin the wheel so that it rolls. That's what I've done in the past. Also I run tubes in all my trailers, as I'm not comfortable with a bead lock on a tire that small
FWIW, I checked the play in the wheel assembly and the wheel swivel when I took the tire off, and nothing was sloppy-loose. There is zero play in the hitch.I've also been running the tire inflation at 45 psi, which is what the Sears manuals recommended. The guy at the tire store said it should be more, but the wear on the tread looked to me like the inflation was just about right. Anyway, now I've got a new tire, with a tube, on the trailer, and I've kept the other tire as a spare. _________________ -- JLT
Present bus: '71 Dormobile Westie
with an Allstate single-wheel trailer
Past buses: '61 17-window
'70 Frankenwestie
'71 Frankenwestie |
Suboval Samba Member
JLT Samba Member
Posted: Mon Nov 18, 2013 11:17 am Post subject: |
Good info there. I've had the wobble thing happen while the trailer was empty, never when it's hauling at least a hundred pounds. I deliberately engineered mine to be as light as possible (that's one of the reasons I used the car-top carrier instead of a conventional box), but that was before I realized that you do need a little weight back there to stabilize the trailer. _________________ -- JLT
'70 Frankenwestie
'71 Frankenwestie |
bchitwood Samba Member
Joined: February 25, 2014 Posts: 1 Location: anderson sc
Posted: Tue Feb 25, 2014 1:59 pm Post subject: |
HELLO I am new to the site i have a allstate trailer that belonged to my dad i remember it from when i was a young boy i put it behind my old 64 mercury comet and it shimmy and shook the whole car i had to stop and start over and it done it again it has a new tire and everything has been greased does anybody know what i can do to stop it from doing this i remember it doing the same thing when my dad would use it. thanks for any help |
RocketSurgeon Samba Member
Joined: May 26, 2005 Posts: 442 Location: Roseville, CA
Posted: Fri May 30, 2014 1:22 pm Post subject: |
I just bought an allstate frame and was hoping for some help.
my axle is chewed up an pretty much garbage but the rim and tire are new looking but missing bearings. No big deal I can buy bearings and an axle.... but whats this cone spacer? Its on both sides and rides in between the cone and fork correct? Then the grease seal rides on the spacer... right? Does any one have any pics of it?
One more question, what is the measurement between the forks? Mine was bent to shit and I was able to heat and bent back but just want to double check the spacing. I have about 4 1/4". looks good but I guess it will be determined by the cone spacers.
Thanks in advance. _________________ 69 Westy |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Fri Oct 17, 2014 6:58 pm Post subject: |
What tires are folks using? I see a cool white wall tire here, is it street legal? I need a tube type tire in 4x8 size for my trailer. What makes a scooter tire bad to use? They are tube type and dot approved.
_________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
Envious Samba Member
Joined: January 08, 2003 Posts: 1821 Location: Toronto, Ontario, Canada
Posted: Fri Oct 17, 2014 7:13 pm Post subject: |
Red Fau Veh wrote: |
What tires are folks using? I see a cool white wall tire here, is it street legal? I need a tube type tire in 4x8 size for my trailer. What makes a scooter tire bad to use? They are tube type and dot approved. |
I use a Cushman scooter whitewall tire. It works great. I've had it up to highway speeds on a regular basis. _________________ 71 Type 1302 Custom
64 Type 151
63 Type 117 L469 Anthracite
64 Type 361 L575 Nutria
64 Porsche 356c
56 Type 113 L227 Strato Silver
52 BSA C11G
59 Heilite Single Wheel Camping Trailer
56 Allstate Single Wheel
84 Vanagon Westfalia
http://www.thesamba.com/vw/forum/viewtopic.php?t=388225 |
Posted: Fri Oct 17, 2014 9:44 pm Post subject: |
Very cool, I need to find the best place to buy one! I notice you list your single wheel trailers in your sig., I want to do that too now but need to find out what years my trailers are. Here they are.
The Rose Trailerette
The Allstate
The Harris
Posted: Sun Oct 19, 2014 6:48 pm Post subject: |
I got these hitch brackets that attach to the bumper. I might use them to see how it feels to tow one of these trailers.
Gehackt Samba Member
Joined: February 28, 2006 Posts: 31 Location: Aurora, Illinois
Posted: Wed Apr 01, 2015 8:02 pm Post subject: |
Just finished my Single wheel.... Hey WingNut, you still out there?
vintagevwnut Samba Member
Joined: November 25, 2007 Posts: 175 Location: Plainfield, Il
Posted: Wed Apr 01, 2015 8:07 pm Post subject: |
I get notifications. Hell yeah man!!!! That is so sweet. Lookin good man!! |
Posted: Wed Apr 01, 2015 8:31 pm Post subject: |
After I get rid of the wobble. I'll let you know if it holds up to 100mph! lol No 4th gear though! Ha |
Posted: Thu Apr 02, 2015 6:05 pm Post subject: |
Thanks. Yeah I read that topic yesterday while I was reading through the thread. Gonna lower it some more and take the air pressure down to 45! |
Posted: Sun Apr 05, 2015 6:29 am Post subject: |
Well, lowered the hitch point 2"s lower and took the tire pressure down to 35. Tightened the center pivot nut down tight and backed of just 1/8 of a turn, it was a little sticky at first but then was spinning it around under the trailer while it was lifted and it loosened up just perfectly. Took it out and did a hard 1st gear pull and banged a 2nd gear hard. Checked the bumper bracket bolts (weakest points) and seamed to be fine. Still might reenforce that area too.
BTW Happy Easter! |
Posted: Sun Apr 05, 2015 7:24 am Post subject: |
The worlds fastest single wheel trailer. Lol. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Apr 05, 2015 2:04 pm Post subject: |
It would ride better with the air pressure at 25 lbs. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sun Apr 05, 2015 4:26 pm Post subject: |
Mike Fisher wrote: |
It would ride better with the air pressure at 25 lbs. |
since it is for novelty and not really to haul, you're probably right. Will have to try that too. |
MonkeySee Samba Member
Posted: Fri Apr 17, 2015 12:28 pm Post subject: |
Thanks for this thread! I'm working on my recently purchased trailer and hope to have it behind my Bay very soon.
Posted: Thu Apr 23, 2015 4:03 pm Post subject: |
Oh snap! It seems I have an extra part I can't remember where it goes. I thought this washer went between the pivot washer and the castle nut but it hits the rocker axle. Any other ideas?
