ricky.santillan Samba Member
Joined: June 16, 2009 Posts: 125 Location: Makati, Philippines
Posted: Mon Jan 17, 2011 8:04 pm Post subject: Did early 1302 SBs have drums or discs? |
Am looking at what appears to be an early SB. Did they have 70 models? If not then maybe its a 71 and am veryfing this. I thought they came with front discs. Did they have drums? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Mon Jan 17, 2011 8:05 pm Post subject: |
71was the fist year of the Super. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Jan 17, 2011 8:08 pm Post subject: |
Glenn wrote: |
71was the fist year of the Super. |
Okay will verify as it may have a typo on the registration here. Did they have drums or discs for the 1302? |
Glenn Mr. 010
Posted: Mon Jan 17, 2011 8:11 pm Post subject: |
In the USA they only had drums. _________________ Glenn
Member #1009
#BlueSquare |
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Tue Jan 18, 2011 12:18 am Post subject: |
Glenn wrote: |
some country's go by year of manufacture (YOM) in the Philippines it might be A 1970. _________________ 1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods!
Posted: Tue Jan 18, 2011 12:19 am Post subject: |
Some had disk, and some had drums, It just depends what country your in.. _________________ 1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods! |
Aussiebug Samba Member
Joined: June 03, 2002 Posts: 2162 Location: Adelaide Australia
Posted: Tue Jan 18, 2011 1:23 am Post subject: |
The model year confusion often comes about because VW used a different "year" to the calendars the registration folks use.
The 70 model year was from 1 Aug 69 to 30 July 1970, so if it was sold and registered in 69 the rego folks would call it a 69, but if it was made late in the model year and first registered in early 71 then they will call it a 71, when in fact both are wrong - it's still a 70 model.
Go by the chassis number - from 65 onwards the third digit is the model year, so a 70 is 110,xxxx,xxx with the "0" meaning 1970.
70 models did not have superbugs. 71 was the first model year (chassis 111,xxxx,xxx) for superbugs and they started building on 1 August 1970.
In the USA, all bugs came with drum brakes, but only ever got the biggest engine offered in that year. Other countries got several engines offered in each model year.
In most other countries, the 1500s from 68 to 70 had disc brakes and the 1300s had drums. From 71 onwards, the superbugs had the 1600 engine and disc brakes, the standard bugs had 1300 engines and drums brakes. There are probably some exceptions to that general rule though.
Through all this the 1200 was offered as a base model in most European countries and stayed 6v well into the 70s. The last German built bugs in 1986 were all 1200s. _________________ Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com |
