vwsteve Samba Member
Joined: March 18, 2004 Posts: 1047 Location: Virginia
Posted: Tue Jan 18, 2011 4:53 pm Post subject: 1835 power? |
Will changing p/c to 92mm with everything else stock except for header exhaust be much more power than a 1600? It is a dual port. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Tue Jan 18, 2011 5:01 pm Post subject: |
Define "much".
A 25% increase is about 12hp. _________________ Glenn
Member #1009
#BlueSquare |
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Tue Jan 18, 2011 5:19 pm Post subject: |
Glenn wrote: |
Define "much".
A 25% increase is about 12hp. |
and you won't get all that without a carb change. _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
Derek Cobb Annoying
Posted: Tue Jan 18, 2011 5:59 pm Post subject: |
You will feel a differance, but without improving the induction it won't be a big change. |
volkyoo Samba Member
Joined: July 26, 2010 Posts: 417 Location: dominican republic.
Posted: Tue Jan 18, 2011 7:18 pm Post subject: |
something to think about is, that if your "stock" 1600 is "tired" you will notice a diference.... |
Posted: Wed Jan 19, 2011 6:08 pm Post subject: |
Well its going in a 61. The 4.375 tranny in it is shot. I am going to replace it with a 67 4.125 tranny and swap out the tired 1200 for the 1835....should be a little quicker. |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Sun May 15, 2011 5:41 pm Post subject: |
I ended up using a progressive weber that I found in my spare parts. I think the main barrel is only 26mm and I can't even tell a difference when the secondary opens. Car definately has more power. I don't have a tach, but it feels right at 75 mph on the interstate now. It does have a counterweighted crank which is probably why it feels smoother at 75 mph. I never liked the solex 34 pict carbs, but I wonder if it wouldn't actually have more power than I do with the progressive.? Anybody know how the progressives are on gas milage? I am thinking the small main barrel might be good for mileage. I am running dual exhuasts (1&4 together and 2&3 together) with a modified heat riser setup. It has good heat through the riser. |
nbuscemi Samba Member
Joined: May 30, 2009 Posts: 733 Location: Fort Worth, Texas
Posted: Sun May 15, 2011 6:21 pm Post subject: |
I have the same setup your looking at: 1835cc with headers and glass pack with a stock 34Pict-3 carb. You'll get more "seat-of-your-pants" torque, but the engine runs out of breath just like your 1600cc does. I still get decent milage, great drivability. If I had the right carburation, I'd probably feel like a completely different motor.
-Nick- |
