damicotile Samba Member
Joined: September 16, 2004 Posts: 1069 Location: WOODLAND CA.
Posted: Wed Jan 19, 2011 8:30 am Post subject: New heads, lost torque |
I just put on some new heads from Steve Tims, some stage 2's.
It seems to have lost it's low end torque. It's just not that torquey (sp).
I split the case while I was at it to check the cam and lifters for wear as my old engine before this one went flat after about a couple of thousand miles.
Cam and lifters mic'ed out perfectly BTW.
While I had the case open, should I have changed the cam to match the heads?
I am running a W-120.
Maybe low port velocity?
Anything to bring back the low end torque?
I went from 40x35 to 42x37 _________________ '73 SB
82x94
W-120 w/ CB light weight lifters
Silicon bronze sleeves
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
A-1 Sidewinder coated
__________________________________ |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Wed Jan 19, 2011 8:50 am Post subject: |
Which heads were on the engine before, are the manifolds port-matched to the heads, did you change the jetting on your carburettors, and did you change your timing? _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Wed Jan 19, 2011 8:51 am Post subject: |
With the 40x35's you may have had more port velocity at lower rpms. With the bigger heads now you seem to have to build more rpms to get the performance out of the head. Valve lash set correct? Try and reset your timing and advance a bit more if possible. Did you rejet your carbs and retune your A/F mixture? _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Chuey Samba Member
Joined: October 18, 2010 Posts: 858 Location: Oceanside, California
Posted: Wed Jan 19, 2011 9:14 am Post subject: Who you gonna call? |
Did you ask Tims what cam would work best? By buying his heads, it seems that he would naturally be willing to help you make them perform at their best.
Chuey |
mark tucker Samba Member
Posted: Wed Jan 19, 2011 10:00 am Post subject: |
addvance the cam about 4-6 degree. but first are they the same cc chambers? is the cr the same?? that might be where it went. those ports are so short port velocity should not be the problem,what about the timing??did you get the gears a tooth off?? If you have a degreed pully you can check the cam timing easy by pulling the vc and a set of rockers and use a dial indacator.make sure your pully has the tdc at tdc if not ,make a pointer. use the positive stop method to find tdc. is it jetted corectly?addvance curve working good? what intake? is it a deferent intake system?I dont think it is the heads. there is somuch that can cause this ,and a lot can be done. deferent header? cam can be addvanced by removing the oil pump to get to the bolts & useing offset washers.you may need to drill the gear out witch might be a bitch, I cant remember. I dont know if you have the gear off by a tooth if you can move it buy removing the oil pump&camgear but if you check the degree and find it is off that would be the first thing I would try Insteaad of spliting the case. good luck. |
Posted: Wed Jan 19, 2011 1:28 pm Post subject: |
The heads I had before were BugPack 40x35 non ported heads.
My manifolds were match ported to these new heads.
The jets are 55 idles, 160 mains and 200 airs.
I did adjust the A/F and sync'ed the carbs plus put on a CSP center pull.
The timing is @ 7.5 at idle and 28 degs advanced with a cast iron 010.
Valves are set to .006 with aircooled's alum push rods.
With the old heads I put in the 60 idles but it was too rich so I took them out.
I may put the 60's back in.
I took it out on the freeway last night and it was so smooth compared to the old heads and reached 98mph lickity split before my son told me to knock it off.
It scared him. He's 17 1/2 yo.
No guts, no glory I say.
Anyway it just has no real bottom end like the old heads had but the top end is awesome.
I'll try advancing it a few degrees and see what that does and then put the 60 idles in after that and see what that does.
I am not about to split the case again for a new cam but really should have asked Greg or Steve about if I should have.
I did tell him which cam I had though.
Sometimes people won't tell you anything unless you ask, and I forgot to ask. My bad. _________________ '73 SB
82x94
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
Posted: Wed Jan 19, 2011 2:35 pm Post subject: |
main jet seems a little high,but that isant the problem check the cam deg.I didnto notice you had stright cut gears so they should be ajustable just fine. and thats easy to do. just rember witch way to go to addvance the cam. check the head cc on the old heads and ask what they are on the new heads.if you had 9.5 cr befor and now have 8-8.5 there is where it went.but addvancing the cam will still help.you might try a bit more timing but be carfull. 17 1/2 and skeered???at only 98?? my daughter started riding with me on my yz 250 at 5 years old or less.and it wasent fast enough for her then. If I hadent gotten cancer and effed up by mr slice&dice& his kissen coussen raidoactive ray.she would be racing my 800+hp roadster now at 16.but the roadster never got finished.any body want a "new" not finished all round tube roadster? |
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Wed Jan 19, 2011 3:58 pm Post subject: |
Too far too fast. I bet you'd have been thrilled if the 40 x35.5 BP's had gotten the port job.
Did you discuss compression with the head builder?
I would start with the ignition timing but consider the cam advance...it really is a pretty good compromise.
RC _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
Posted: Wed Jan 19, 2011 4:42 pm Post subject: |
RockCrusher wrote: |
RC |
My old heads were 60cc and he did my new heads the same.
My CR is 9.1
Doing the cam advance should have been done while the case was split. Right now my cam is setup without any offset.
Doing so now would with the engine in the car would be impossible, no?
I'm not sure how to do it. They did give me offset washers with the cam but I set it up with the straight washers. _________________ '73 SB
82x94
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
Posted: Wed Jan 19, 2011 4:48 pm Post subject: |
then pull the pump and put in the offset ones in the cam should addvance by going counter clockwise.witch would be the gear going closkwise.you dont need to split the case. |
Fairly impossible to advance the cam in the car. Do the timing and see how that goes.....Try to go up from 28 now to 30 total to start with. Be real careful about pinging.
You might consider an SVDA to get that nice bottom end drivability without messing up the top end. _________________ [email protected] Please use email for all general inquiries.
midtravelmidengine Samba Member
Joined: August 06, 2009 Posts: 861 Location: Riverside, Ca
Posted: Wed Jan 19, 2011 5:00 pm Post subject: |
maybe it just feels like you lost TQ because you gained SOOOOO much top end? Just a thought. _________________
modok wrote: |
And I know you don't know because if you did you would know the reason for my knowing you didn't. |
youngnstudly wrote: |
I just wasn't sure if I should recommend the 1/3 race cam, the 1/2 race cam, or the 5/8 race cam instead...guess it depends on how much of the race he wants to lead???
Posted: Wed Jan 19, 2011 5:40 pm Post subject: |
You might consider an SVDA to get that nice bottom end drivability without messing up the top end. |
how is that??? pull the pully &oil pump and you are right there. opps you might need to remove a bit of tin but thats just a few screws,and since the motor was just put back in they should come out just fine. it's realy not hard or diffacult at all. you may want to drain the oil so it dont run out the pump hole.or put the rear of the car 3 -4feet in the air.it,s time for an oil change any way. it may be a little easyer if you remove all of the rockers but I think just 1 side will do. |
Posted: Wed Jan 19, 2011 8:05 pm Post subject: |
Don't forget removing the exhaust system too, Mark.........Hence the wording "FAIRLY impossible" _________________ [email protected] Please use email for all general inquiries.
SRP1 Samba Member
Posted: Wed Jan 19, 2011 8:58 pm Post subject: |
Don't forget removing the exhaust system too, Mark.........Hence the wording "FAIRLY impossible" |
Nonsense pull the pulley, pump, and exhaust if in the way and make the change. However I would do some testing prior to tearing into the engine, such as compression, and cylinder leakdown tests to verify the validity of your newly installed components. |
Posted: Wed Jan 19, 2011 9:06 pm Post subject: |
SRP1 wrote: |
OK............. _________________ [email protected] Please use email for all general inquiries.
Posted: Wed Jan 19, 2011 9:32 pm Post subject: |
Ive done it before. You gotta have elf fingers and lots of patience. If you have stubby hands like me x2 lots of patience. Break em all first then remove one by one and swap the washers.Remember to use a long skinny screwdriver when removing the washers so they slide on the shaft or a extendable magnet. _________________ 2276 IDA's 86C 11-1 DD !
Posted: Wed Jan 19, 2011 11:29 pm Post subject: |
midtravelmidengine wrote: |
maybe it just feels like you lost TQ because you gained SOOOOO much top end? Just a thought. |
I like your thought better. Maybe thats true.
Mark, Jon and Rocky, you guy's can fight over how easy it is to do that in the car but I would just pull the motor to do that since by the time you remove all the tins, exhaust, drain the new oil I just put in, remember I just split the case, it would be easier to just drop it down and do the cam advance.
Now, all I have to do is figure which washers to use.
The cam gear set came with 3 sets of washers.
Silver was the straight ones and then there was a gold and black set.
Not sure which ones are which. _________________ '73 SB
82x94
Scat 1.25:1
CB H-Beams
Straight cuts
42x37 Steve Tims
44 IDF's
9.2:1
steve34 Samba Member
Posted: Thu Jan 20, 2011 12:50 am Post subject: venturis |
You might put smaller venturis in. That is whyI think a 40 by 35.5 ported head is better for the street and sand. |
mightymouse Samba Member
Posted: Thu Jan 20, 2011 1:55 am Post subject: |
Go drive a bug with a bone stock 1600, no hop back into your car and drive.
You will then stop complaining. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
