Locking Doors after handles removed?
randywebb
randywebb is offline
PostPosted: Mon Mar 12, 2012 11:16 am    Post subject: Locking Doors after handles removed? Reply with quote
Is there any way to secure my van from theft and interior vandalism if I remove the front door handles (and the slider) for powder coating?
We have a lot of thievery around here and I need to secure it.
Thanks!
1986 2.1L Westy 2wd Auto Trans.
danfromsyr
danfromsyr is offline
PostPosted: Mon Mar 12, 2012 11:46 am    Post subject: Reply with quote
recruit some local canines
but with the handles off any semi-VW knowledgeable person can push the lock tab to release..
maybe a 2nd set of handles to stand in while you're prettying up your OGs. Question
Abscate wrote:
kamzcab86
kamzcab86 is offline
PostPosted: Mon Mar 12, 2012 12:37 pm    Post subject: Reply with quote
Lockable car cover.
~Kamz Anxious
2016 Golf GTI S
"I fear the day that technology will surpass our human interaction; the world will have a generation of idiots." ~Albert Einstein
syncrodoka
syncrodoka is offline
No way at all. Park it in a locked garage
PDXWesty
PDXWesty is offline
PostPosted: Mon Mar 12, 2012 12:39 pm    Post subject: Reply with quote
Move it to a locked garage.
89 Westy 2.1 Auto
hazetguy
hazetguy is offline
PostPosted: Mon Mar 12, 2012 12:41 pm    Post subject: Reply with quote
i would suggest parking it in a locked garage until you got the handles back.
Parts and mechanical restoration services available. I restore and rebuild fuel pumps, distributors, spindles, etc.
Check my ads or send a PM.
carterzest
carterzest is offline
PostPosted: Mon Mar 12, 2012 12:43 pm    Post subject: Reply with quote
Has anyone mentioned a locked garage?
Happiness=Portland, Oregon in the rearview mirror!
Perales
Perales is offline
PostPosted: Mon Mar 12, 2012 12:44 pm    Post subject: Reply with quote
Funny, I was just going to say that! Shocked
-- 1987 Westfalia automatic (Captain Vino)
dubbified
dubbified is offline
PostPosted: Mon Mar 12, 2012 1:06 pm    Post subject: Reply with quote
Curiously.. why wouldnt you get to the yard.. get some handles to refinish.. and keep that from being a issue in the first place?
joseph928
joseph928 is offline
PostPosted: Mon Mar 12, 2012 1:13 pm    Post subject: lock your van Reply with quote
Blue Bay Bus- X8- It only takes one day to get the handles done, sleep in your van with a 45 for one night!. Very Happy
1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug.
MayorMcCheese
MayorMcCheese is offline
PostPosted: Mon Mar 12, 2012 1:15 pm    Post subject: Reply with quote
Rope the doors shut from the inside. Climb out the rear hatch and lock it. Very Happy
Perales
Perales is offline
PostPosted: Mon Mar 12, 2012 1:18 pm    Post subject: Reply with quote
Assuming you can still lock the rear for access and egress, perhaps there is some way to tie the doors together from the inside. For example, remove the inside panels and use heavy rope or cables looped through the door frames and tie them together across the inside of the vehicle. The slider might be a bit tricky but it just might work.
Edit: damn, you beat me to it!
MrBreeze
Samba Hitman
MrBreeze is offline
PostPosted: Mon Mar 12, 2012 1:42 pm    Post subject: Reply with quote
Wrap a huge chain around the whole van.
Make sure you run it through the spokes.
-=Rob
WTB: Bay Shore or Queensboro VW Frames
HBB 1984-2009
RW 1943-2011
Perales
Perales is offline
PostPosted: Mon Mar 12, 2012 1:46 pm    Post subject: Reply with quote
Sorry Randy, everyone seems a bit randy today, it is a full moon after all.
Not much help I'm afraid.
randywebb
PostPosted: Mon Mar 12, 2012 2:48 pm    Post subject: Reply with quote
not available
dubbified
PostPosted: Mon Mar 12, 2012 2:54 pm    Post subject: Reply with quote
Merely removing the handles for paint...you can do that.. and lock the sucker from the inside.
Then exit the hatch, lock said hatch.
Issue resolved.
Hell, I went 2 years without handles on my MKII Gti.. no one wanted to stick their fingers in a unknown panel/hole..
randywebb
PostPosted: Mon Mar 12, 2012 3:35 pm    Post subject: Reply with quote
ok, Thx
I'll fix the rear hatch lock first then
for some reason it now cannot be opened from outside -- the "new" open from inside latch I installed is the only way to get it open right now...
syncrodoka
PostPosted: Mon Mar 12, 2012 5:41 pm    Post subject: Reply with quote
They are going in for powder coating so they will be out for a few days at minimum. The front doors can be locked/unlocked and opened easily through the hole that is much more visible than a golf.
Getting a spare set of handles to use in the down time is a good idea as it will also keep out water as well as thieves. Rebuilding the handles once they come back can add a day or 2 to the mix depending on your schedule. You will have to spend time cleaning the PC out of the lock core holes, off of certain parts of the handle and out of the grub screw holes.
