candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Tue Feb 01, 2011 9:56 pm Post subject: |
Really nice write up and photo journal! My only question is did you get rid of the fiberglass rustulation? |
Racerrojo Samba Member
Joined: August 01, 2006 Posts: 827 Location: ALBUQUERQUE 87120
Posted: Thu Feb 03, 2011 8:08 pm Post subject: |
candyman wrote: |
No I did not, unless I was going to replace the insulation on the whole Van.The point is to warm up the rig. _________________ Tight is tight... too tight is expensive!!!!
Too many vans and mostly all projects |
Posted: Thu Feb 03, 2011 8:16 pm Post subject: |
This are the Propex pipes from under the van
The auxiliary Battery, power inverter are done also.
the Solar panel is next, I just need for the weather to go over 45* to get motivated (it was 33* in my garage by the time I was done last night.) _________________ Tight is tight... too tight is expensive!!!!
Posted: Tue Mar 22, 2011 8:22 pm Post subject: |
the propex is working very Nice, I made some window insulation, that attaches with magnets, and could be use on the inside and out side off the van.
My problem now is that after installing the solar panel, the auxiliary battery and power inverter, some thing is draining both batteries,
any ideas, on where or what to look for? _________________ Tight is tight... too tight is expensive!!!!
buildyourown Samba Member
Posted: Tue May 24, 2011 10:20 pm Post subject: |
I finally finished mine up and I thought I'd tag my pics onto your thread rather than create a parallel one. Thanks for the inspiration and the dimensions. It helped a lot.
I cut about 5.5" out of the fridge door and everything fits nicely. I could have done a better job scabbing the door back together but I didn't have a biscuit joiner.
This really is a great place for the propex. The propane is right there already. The burner lines are easy to vent and the hot air vent it perfectly placed in the van IMO. That was probably my biggest motive. I wanted a vent that wasn't likely to be blocked by a pile of shoes or other gear.
Posted: Wed May 25, 2011 6:04 am Post subject: |
Nice!!
I'm having issues on how to cut the door, and still fit the plastic strip. I like the way you did it. _________________ Tight is tight... too tight is expensive!!!!
Posted: Mon Jan 09, 2012 5:09 pm Post subject: |
buildyourown wrote: |
I figured that pin striping decal works nice to finish and cover the cut on the door _________________ Tight is tight... too tight is expensive!!!!
Jedi Samba Member
Joined: October 23, 2007 Posts: 734 Location: Cool California
Posted: Mon Jan 09, 2012 6:06 pm Post subject: |
Here is my set up.It is nice to see the different set ups. I am going for a Truckfridge for mine. _________________ 1961 Westfalia SO23 Mango Green/Seagull grey
1961 Westfalia SO34 T/BW
1961 Westfalia SO34 SWR
1964 Westfalia SO33 pearl white
1965 Westfalia SO42 Velvet green
1986 Syncro Wolfram grey with black int GL
1986 Syncro Doka
1987 Syncro Sevana beige Adventurewagen
1987 syncro Sevana beige GL
1973 Pumpkin orange Thing
2 1963 Rag top bug's
1965 Manx
1970 Single cab
1971 combi
1990 Vanagon GL
2007 Audi A4 3.2L quattro |
carterzest Samba Member
Joined: January 22, 2008 Posts: 3842 Location: Eagle, ID/Sun Valley, ID
Posted: Mon Jan 09, 2012 8:35 pm Post subject: |
Jedi wrote: |
Here is my set up.It is nice to see the different set ups. I am going for a Truckfridge for mine. |
This is just killing me I have toiled over the fridge replacement and finally decided I am doing the Truckfridge as well, therefore I will be doing a fridge cabinet rework as well. I have to say, 71 Mystaboo, Claire and Eileen's setup is the best one I have seen.
It vents right over the table which gives the heat to the bed area on cold nights, and, heat rises. I do like the bottom of the fridge cabinet mod as well. They had their portajohn slide right in the bottom of that cabinet where your propex is. Decisions!
fixed link _________________ Happiness=Portland, Oregon in the rearview mirror!
Posted: Mon Jan 09, 2012 9:14 pm Post subject: |
I've seen that. it is slick and super clean, the only problem I see is the heat come right by the window, and that can waste some of it, and you can't direct the air flow.
My friend really loves where I installed his, it warms the camper nicely, even when the sit is up. And you can turn the Blower vent up down or to the front of the van thus heating quicker _________________ Tight is tight... too tight is expensive!!!!
Derskiier Samba Member
Posted: Tue Jan 05, 2016 7:44 pm Post subject: Re: Propex, Solar, and Auxiliary battery |
Hi,
I like both of the propex installs I saw on this thread.
I have one question; I have the green propex ( hs2800), I noticed that one installation is facing the door of the fridge and the other routes into the adjacent closet space and back into the front of the fridge area (perpendicular to the other installation). Can I mount the hs2800 either way?
Or am I limited to routing that model into the closet first? |
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1649 Location: Between Here and There
Posted: Thu Jan 07, 2016 11:59 am Post subject: Re: Propex, Solar, and Auxiliary battery |
I'm curious about this too as I am trying to decide between the 2000 and the 2800. For various reasons I think the floor of the former fridge location is the best spot for me.
This famous thread has the 2800 mounted sideways, another nice install: http://www.thesamba.com/vw/forum/viewtopic.php?t=5...;start=360 _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
