headers installed,now what..
NONYA
Banned
NONYA is offline
PostPosted: Thu Jan 27, 2011 7:16 pm    Post subject: headers installed,now what.. Reply with quote
DO I do for with the down tubes that used to go to the heater boxs?Leave the flex tubes off?run them down through the tin?Thanx
gt1953
gt1953 is offline
PostPosted: Thu Jan 27, 2011 7:36 pm    Post subject: Reply with quote
https://www.thesamba.com/vw/gallery/pix/297162.jpg
https://www.thesamba.com/vw/gallery/pix/297160.jpg
https://www.thesamba.com/vw/gallery/pix/297161.jpg
Mak a set of these above I have them on my car. The do not melt tear or break. Exhaust scrap from a muffler shop. PM me if you need to.
72 type 1
72 Squareback
adams77
adams77 is offline
PostPosted: Thu Jan 27, 2011 7:37 pm    Post subject: Reply with quote
some guys plug the holes, some don't, some even plug the holes with plugs that have holes. Try a search and you will find lots of info. The hard part is deciding what to do once you have all the info.
If Stupidity got us into this mess, then why can't it get us out? ....Will Rogers
NONYA
Banned
NONYA is offline
PostPosted: Thu Jan 27, 2011 7:43 pm    Post subject: Reply with quote
Do you have a pic of them installed?If they are plugged do you risk overheating?
vw_hank
vw_hank is offline
PostPosted: Fri Jan 28, 2011 1:15 am    Post subject: Reply with quote
Laughing gt1953, I think you might need to start A tread/how-to..
I got the parts for mine, waiting to git some time to crawl under and start
1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods!
Chris Vellat
Chris Vellat is offline
PostPosted: Fri Jan 28, 2011 1:41 am    Post subject: Reply with quote
Original poster, what's the engine and what type of header? Heaterbox delete tubes are often called "J-tubes" - even when on a competition style header.
If you're leaving off the heaterboxes, you want to block the holes in the tin, you can buy '2" knock-out seals' for electrical work that do the job quite well...as well as installing 1-7/8" freeze plugs in the shroud itself - this is where some people prefer to have holes drilled.
Here is a heaterbox riser I made to fit the customized header on my Baywindow...
vw_hank
vw_hank is offline
PostPosted: Fri Jan 28, 2011 1:47 am    Post subject: Reply with quote
damn Chris, yours look good to!!
1302s sunroof..
NONYA
Banned
NONYA is offline
PostPosted: Fri Jan 28, 2011 6:56 pm    Post subject: Reply with quote
Here we go,problem solved! Laughing
vw_hank
vw_hank is offline
PostPosted: Sat Jan 29, 2011 3:11 am    Post subject: Reply with quote
Laughing Laughing LMFAO Laughing love it!!
don't think your going to git A lot of heat tho...
1302s sunroof..
NONYA
Banned
NONYA is offline
PostPosted: Sat Jan 29, 2011 3:32 pm    Post subject: Reply with quote
heaters are a thing of the past on this buggy,does anyone have a diagram showing the airflow of the aircooled vw motor?
