airkooledchris Samba Member
Joined: January 25, 2005 Posts: 2640 Location: Where the pacific ocean meets the redwood forest
Posted: Sat Jan 29, 2011 4:02 pm Post subject: 79 bay - cooling flap screwed closed/open |
I hope the pic is obvious enough. the PO removed the cooling flap rod/thermostat setup, so the cooling flap on the drivers side by the oil cooler is the only one still there.
is this the default position that you would want it to stick in? he's got it screwed into place so it cannot move at all the way it is. im guessing this is the position it would be in with the cooling flap rod in the 'closed' position, meaning the motor was already warm.
when I eventually pull the whole motor ill reinstall the flaps properly, but is it ok to leave this setup in this position for now? _________________
metahacker wrote: |
... i would say that, if it's an option, (edited) not listen to any forum pessimism.. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 45371 Location: Surrey B.C. Canada, Land of the giant flying moose!
SGKent  Samba Member
Joined: October 30, 2007 Posts: 35391 Location: Retired so can be anywhere now - NorCal
Posted: Sat Jan 29, 2011 7:17 pm Post subject: |
Is there a reason you don't just replace the parts and make it operational? _________________ American Standard Snorkeling Terrier
Preserve YOUR Freedom of Speech ~ as best you can, avoid Amazon, Facebook, Twitter, and Google. Support businesses near you, and buy local whenever you can. |
Posted: Sat Jan 29, 2011 7:39 pm Post subject: |
SGKent wrote: |
Is there a reason you don't just replace the parts and make it operational? |
it's not a question of if, it's just a question of when. I have nearly the entire brake system torn apart right now and that's gotta to together first. throwing the CHT gauge on it was just a 'while I have some time' project earlier today when I ran out of brake parts to finish.
I just wanted to be sure this was the OK position of the flaps, for when they are essentially not hooked up, until I can properly pull the motor.
if im going to pull the motor though, I may as well do the clutch and some other bits that im not in a position to take care of properly right now. (parts themselves, time, and dry location)
thanks for the replies. I think my sender is hooked up well enough that it won't rotate or bend in position when I install the plugs, so im going to put it back together the way it was for now, after replacing some of the fuel hose and clamps. _________________
metahacker wrote: |
