SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 2450 Location: Highnam, UK
Posted: Mon Jan 31, 2011 1:41 am Post subject: |
You can run 225/75/16s on syncro 14 rear arms without modifications but go above that and it's time for metal work... you do however need to either jack the Syncro up or modify the arches.
MG _________________ T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD |
svxcarat Samba Member
Joined: May 19, 2009 Posts: 127 Location: San Francisco
Posted: Mon Jan 31, 2011 7:15 am Post subject: |
SyncroGhia wrote: |
MG |
That's good to know cause moded arms are not cheap. I will try running the wheels with a lift kit only and see how it goes.  |
fairweather Samba Member
Joined: August 26, 2007 Posts: 663 Location: Aspen, CO
Posted: Mon Jan 31, 2011 8:21 am Post subject: |
That size will fit with stock equipment with a little grinding. Here are some pics of my setup; 16x6.5 with ET 20 in back and ET 24 in front.
Lip is ground about halfway, tires are worn about halfway down.
Trimming at front fender to prevent rubbing.
burleymotorsports Samba Member
VWhead Samba Member
Joined: September 27, 2009 Posts: 337 Location: Pacific Grove,CA
Posted: Mon Jan 31, 2011 10:13 am Post subject: |
Thanks Burl
This truck is sure a lot tougher(burley) now thanks to your products! _________________ 81' Single Cab Syncro 1.8T GMW
88' 2wd Westy 1.8T GMW
www.gmwerks.com
keving Samba Member
Posted: Mon Jan 31, 2011 10:24 am Post subject: |
svxcarat wrote: |
Yes, those are Mefro center caps from Peter. I got the rims for 83$ a piece but I get a discount through my shop. I thing list price is 110$ maybe. I agree,they should be plenty strong. The machining was 25$ a rim but you could do it yourself since they don't hub center. Depending on you machine shop, it could be cheaper. Saving up for some Duratrac's to put on there now.  |
Not to jump off topic but those center caps look sweet. Here's hoping some 2wd ones come up soon. Wheels look great as well. _________________ 84' Westy |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 11497 Location: Santa Cruz, CA
Posted: Mon Jan 31, 2011 4:23 pm Post subject: |
Quote: |
You can run 225/75/16s on syncro 14 rear arms without modifications |
I tried a set of 225/75/16 BFG A/T tires on my van with CLK, Mefro and a set or Mercedes rims and they all had so little clearance that you could not slide a piece of construction paper between the tire and the trailing arm seam. Unless the duratracs are significantly different than BFGs the trailing arms will need to be modded.
SyncroGhia, I never thought I would be contesting something you said but I have actually installed these combinations. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5604 Location: Crescent Beach, BC
Posted: Mon Jan 31, 2011 4:46 pm Post subject: |
I'm wondering why you'd go to the expense and trouble of machining the centre of a steel 16" x 6.5"VW wheel when a steel 16" x 7" Mercedes Benz rim bolts right on...
Anybody know? _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
toomanyveedubs Samba Member
Joined: November 26, 2007 Posts: 594 Location: Great White North
Posted: Mon Jan 31, 2011 4:47 pm Post subject: |
I think the 225/75r16 will fit with certain offsets(25 or 23) as this brings them out a little more than the 30 or 33 ET. The difference is only mm. I fit a 235/75R15 with no mods to trailing arms. |
Posted: Mon Jan 31, 2011 6:01 pm Post subject: |
Quote: |
when a steel 16" x 7" Mercedes Benz rim bolts right on... |
The MBZ rims are known to be bendy. |
Posted: Mon Jan 31, 2011 7:12 pm Post subject: |
burleymotorsports wrote: |
Speaking of MBZ rims, I have a set here that are et 34 and 8'' wide not sure which MBZ they are off of. will these work on a Syncro? |
Check the ultimate wheel post sticky on this forum. I think they should provided the center bore is large enough and you may need to drill the lug holes bigger too. But Loogy will tell you to stay away from 8" wheels. |
Posted: Mon Jan 31, 2011 7:19 pm Post subject: |
syncrodoka wrote: |
Wow - I find that hard to believe. They are from a car that weighs just as much as my van and is fitted with tires good for 140mph or so... I have two sets (summer and winter) and they feel rock solid under my van. As a former road racer I will take the occasional corner at speed!
Or did you mean for off roading? _________________ '84 Vanagon GL 1.9 WBX
Posted: Mon Jan 31, 2011 9:11 pm Post subject: |
Yes he was talking about off roading in a Syncro |
Posted: Mon Jan 31, 2011 9:13 pm Post subject: |
Those wheels are off of a '90-'98 300SL/500SL, '92-'93 500/600 and '94-'98 S Class.
They will work on a Syncro (not so hot on a 2WD), but a 225 tire will be extremely close to the upper control arm. In fact due to variances in tire widths from one manufacturer to another, one 225 might just barely fit while another might rub...it's that close. You could run some 3mm spacers on the stock length studs to give you just that extra bit of clearance.
These wheels came on cars that had 14mm wheel hardware, so the lug holes don't need to be drill and you can use the stock Vanagon steel wheel lug nuts. _________________ Christopher
Posted: Mon Jan 31, 2011 9:17 pm Post subject: |
loogy wrote: |
These wheels came on cars that had 14mm wheel hardware, so the lug holes don't need to be drill and you can use the stock Vanagon steel wheel lug nuts. |
Do you think the Tiguan rims will work being 6 1/2 wide with an ET33? |
Posted: Mon Jan 31, 2011 9:45 pm Post subject: |
Quote: |
Or did you mean for off roading? |
Yes. Road driven cars can get away with a lot different rim. |
VWhead Samba Member
Posted: Mon Jan 31, 2011 9:58 pm Post subject: |
I wonder how thick they are? The Eurovan rims are pretty thick.
The MB and Passat rims seem to be awfully thin for off roading? _________________ 81' Single Cab Syncro 1.8T GMW
www.gmwerks.com
