type117 Samba Member
Joined: December 18, 2005 Posts: 47 Location: Hasselt - Belgium
Posted: Sun Feb 09, 2020 9:49 am Post subject: Re: 61-64 convertible thread and registry |
Nice!
Show us the car when finished with the new top and rims.
May we know the chassis and motor number? _________________ 1962 type 117 (black beetle sunroof)
1962 type 151 (blue beetle convertible)
1974 type 265 (Baywindow double cab) |
bugmandave Samba Member
Joined: December 30, 2005 Posts: 642 Location: Illinois
Posted: Sun Feb 09, 2020 10:25 am Post subject: Re: 61-64 convertible thread and registry |
type117 wrote: |
Nice!
May we know the chassis and motor number? |
Thanks! Here is some paperwork that came with the car
_________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
'71 Westfalia campmobile tourist delivery
January '59 SWR panel
'63 Karmann Cabriolet L54 Poppy Red |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sun Feb 09, 2020 10:43 am Post subject: Re: 61-64 convertible thread and registry |
^ very nice indeed.
Ill be acquiring a BC for my 61 Convertible soon .. .. Even though its far from original now.. and will be far from original later.. it will be the last VW I rebuild ... so feel its worth it to have..
The 58-64 convertibles are the cream of the Beetle crop .. IMO ...
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
wagenbits Samba Member
Joined: September 11, 2006 Posts: 9 Location: USA - Boise, Idaho
Posted: Fri Jul 17, 2020 5:50 pm Post subject: Re: 61-64 convertible thread and registry |
Wondering if anyone has documented wheel rim color and/or paint code for
a 1962 Convertible in L1009 Yukon Yellow.
Talking with different wheel paint authorities, Moss Green and Olive have been
mentioned. Does anyone have a reference as to what is correct?
The wheels on Mary Jane's car were spray bombed black over some shade of pea green color.
Got down through the black to find that all the pea green was sanded off the
outer rim flange down to the wheel center seam, before they got spray bombed black, so the previoous intention to use them in original paint is not possible.
Hoping to get the right color identified and paint the wheels, as the Cabbie is
otherwise a finished driver. |
Posted: Sat Jul 18, 2020 6:56 am Post subject: Re: 61-64 convertible thread and registry |
wagenbits wrote: |
I believe all convertible wheels had black rims since they came from factory with beauty rings, the color on the center disc would be an accent color. _________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
Posted: Sun Jul 19, 2020 6:27 am Post subject: Re: 61-64 convertible thread and registry |
wagenbits wrote: |
Talking with different wheel paint authorities, Moss Green and Olive have beenmentioned. Does anyone have a reference as to what is correct?. |
I cant answer your question to specifics.. but here a couple examples of higher end restorations .
I feel the first one is the most accurate.
These . while the disc is correct, the rim is a bit too brown most likely to match the brown top it had..and... no beauty rings.
IMO if 100% know your wheels are original to the car.. you have the best evidence at your disposal.
Posted: Sun Jul 19, 2020 7:30 am Post subject: Re: 61-64 convertible thread and registry |
Your original rims are probably the correct colors. Black outer rim is correct on a convertible and the green center disc is most likely going to be the correct accent color. If all the date stamps are correct I would bet they are original. Karmann produced convertibles as well Karmann Ghias came factory equipped with beauty rings which is why the outer rims were painted black. No need to paint them in a color since they are mostly covered up. This is my '63 vert wheel in original paint, cadmium red /black on a poppy red car. Hope this helps.
theastronaut Samba Member
Joined: November 19, 2007 Posts: 1631 Location: Anderson, SC
Posted: Sun Jul 19, 2020 6:57 pm Post subject: Re: 61-64 convertible thread and registry |
A black outer rim should be correct.
Another difference I recently learned about is that vert wheels were masked differently than sedan wheels. The center color extended out onto the rim, and the mask line was under the trim ring so that the center color shows on the rim inside of the trim ring, and black only shows outside of the trim ring.
As seen on this original paint wheel.
While we're on the subject of Cadmium Red vert wheels, this is a really nice example I came across on Facebook.
Been doing my homework on wheel colors and paint variations since my '63 I posted earlier is going back to stock wheels and suspension. I may do a second set of 356 wheels with Vredestein Sprint Classic tires. Also bought a Judson supercharger for it.
_________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
Posted: Sun Jul 19, 2020 8:21 pm Post subject: Re: 61-64 convertible thread and registry |
I will confirm the paint line does split under the chrome rings, the original paint rim I showed above is the same way. Also, the ruby vert with cadmium rims above was also mine but has since been sold. My current one is poppy red. _________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
Posted: Mon Jul 20, 2020 5:01 pm Post subject: Re: 61-64 convertible thread and registry |
Great information gentlemen... Masking under the ring makes perfect ease of production sense especially since the Sedans of the era had full black wheels.
John.... I thought you sold that red 63?
Posted: Mon Jul 20, 2020 6:19 pm Post subject: Re: 61-64 convertible thread and registry |
Convertible wheel disc color for 1962 L 1009 Yukon Yellow?
Thank you BUGMANDAVE, THEASTRONAUT, AND VOLKSWAGENUT for the
confirmations of the correct, original color line of demarcation for Convertible wheeels. All is clear.
Who has dealership paint color binders, Berater, Parts Lists or best, KARMANN documentaion naming the Rim color?
Pics of the original color found on all four (spare MIA) 10/61 wheels:
Posted: Mon Jul 20, 2020 6:34 pm Post subject: Re: 61-64 convertible thread and registry |
1962 L 1009 Yukon Yellow Convertible
VIN 4 250 4xx, built Novermber, 1961
Body No. 911
Interestingly, and in confirmation of earlier Body Match Number posts;
page 4, 9th post, 3rd pic of this thread shows the red 1967 with Body No. 944.
Engine No. 6220897
Sold at Capitol Sales, Boise ID
Original Owner Mary Jane's (really, truly) personal conveyance from 16 January 1962 through April 2020.
She's a plain Jane, radio delete blockoff, no accessory piece of KARMANN.
Light green canvas top and boot
Very light green white seat vinyl
Very light green white and light green door panels
Light green shift lever and E-brake handle
Green floormats
Light green rim discs, black outer lips
Rims sometime later spray-bombed black all over, after the lips were sanded
Carpet has been very incorrectly replaced
Posted: Mon Jul 20, 2020 6:40 pm Post subject: Re: 61-64 convertible thread and registry |
VOLKSWAGNUT wrote: |
Not yet, had an issue with the trans popping out of third, and the new rings gave up sealing at 2800ish miles so it had to come back apart. Still planning on letting it go once I finish it, probably on Bring A Trailer. _________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
hotchkiss_m201 Samba Member
Posted: Wed Jul 22, 2020 4:27 am Post subject: Re: 61-64 convertible thread and registry |
Just been following this thread and I'm surprised to find about the colours of the rims, always assumed they were the same as the sedans black/white. I've got a Poppy Red 1964 convertible, so would my rims have been Cadmium Red centers? |
Posted: Wed Jul 22, 2020 7:39 am Post subject: Re: 61-64 convertible thread and registry |
hotchkiss_m201 wrote: |
Sorry to say, after 63 they stopped with the accent colors and went black/ white on sedans and all black on convertibles. I believe they also used slotted chrome full wheel covers on the convertibles. _________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
Posted: Wed Jul 22, 2020 1:11 pm Post subject: Re: 61-64 convertible thread and registry |
Thanks bugmandave, slightly gutted that they changed that on the 64 model year. One thing that's puzzled me about my 64 is the headliner, it's cloth and as far as I'm aware they'd already switched to vinyl? |
Posted: Wed Jul 22, 2020 4:22 pm Post subject: Re: 61-64 convertible thread and registry |
It may have been optional, my 63 had cloth also but I've read that perforated vinyl was also used in 63. _________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
dougallison Samba Member
Joined: June 26, 2019 Posts: 40 Location: Arlington, Tx
Posted: Mon Sep 28, 2020 1:14 pm Post subject: My 1962 VW Yukon Yellow convertible |
So I just purchased a 1962 convertible in yukon yellow vin 4620960 with the OG 40HP and still 6v. I've had other early bugs, but no convertibles. Trying to find out more about these and what all is different. The previous owner has had it since 1995. Previous to that, it looks like that owner purchased it in 1991, put in new pans and did a light refresh and outside respray. I there seems to be some type of square box rails on the underside with rust issues, but nothing else that I've found. Don't have pictures of that yet, but here are some of the car.
Posted: Mon Sep 28, 2020 5:50 pm Post subject: Re: 61-64 convertible thread and registry |
So apparently the coach Build# is 5338, built March 1962.
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Tue Sep 29, 2020 8:23 am Post subject: Re: 61-64 convertible thread and registry |
Two YY '62s on one page of this thread? A seldom-seen beautiful color.
Wagenbits- having slobbered on your car in person- it's great to see it here.
I have a theory regarding black outer rims. Since Karmann intentionally scratched every convertible rim on their cars (spares included), it makes good sense they sprayed black under there. Kind of a preemptive strike and apology combo. _________________
EverettB wrote: |
FU#5 |
