Bones 53 Samba Member
Joined: February 19, 2005 Posts: 661 Location: Reno NV
Posted: Thu Feb 03, 2011 7:13 am Post subject: rear window question |
My son has a 67 bug and wants a rear window defoger. Will a later year with a defoger fit? If so which years? Thanks |
marklee Samba Member
Joined: March 24, 2009 Posts: 821 Location: Flintshire, North Wales
Posted: Thu Feb 03, 2011 7:51 am Post subject: |
up to 71... _________________ CGLI qualified body repair and refinish tech
CGLI qualified motor repair tech
Qualified automotive Glass installer
Motor Insurance Repair and Research Centre,Thatcham, Advanced Vehicle Damage Estimator.
Police qualified vehicle examiner
Police Class 1 High performance, pursuit trained Advanced driver |
PSScoots Samba Member
Joined: January 06, 2007 Posts: 504 Location: Chattanooga TN
Posted: Thu Feb 03, 2011 8:32 am Post subject: |
Be careful with the purchase. A lot of times in used glass, the heating elements are broken and you can't see the damage. You should at least do a continuity test to be sure that ANY of the wires are still intact. Maybe somebody knows a way to test each wire individually. _________________ Rebuilt to drive not decorate. -VOLKSWAGNUT
"Service the car and it will give you good service." |
Posted: Thu Feb 03, 2011 7:11 pm Post subject: |
Thanks for the info!! |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Fri Feb 04, 2011 8:13 am Post subject: |
Does anyone still make a glue on defroster or are those a thing of the past?
Maybe a small fan in the parcel area blowing on the rear window would help. _________________ Mother Nature is a Mean Evil Bitch! |
69vwguy Samba Member
Joined: February 02, 2011 Posts: 77 Location: Denver Colorado
Posted: Fri Feb 04, 2011 8:34 am Post subject: |
Does anyone know if the 69 beetle came with a rear defroster? Mine has always had one (doesnt work) but I never thought it was a standard option. Just wondering if anyone knows? |
Miklo ¡Chale!
Joined: August 27, 2008 Posts: 2058 Location: Antelope Valley, Ca
Posted: Fri Feb 04, 2011 8:40 am Post subject: |
I've worked on a 69, it had a rear defroster. _________________ ✠Miklo✠
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote: |
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche... |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Fri Feb 04, 2011 8:55 am Post subject: |
drscope wrote: |
Yep...
http://www.frostfighter.com/index.htm _________________ aka Ken {o\!/o}
Usually and often edited |
Pretty sure I know how to do it but does anyone have any advice on tracing the lines and testing where the problem is so I can maybe have it work again? |
Posted: Fri Feb 04, 2011 10:12 am Post subject: |
All these can be performed out of the car.
12 volt power on one side Ground on the other.
Lightly trace across each strip with a test light near the power then ground sides, as well as across each strip. If you find an area where the test light quickly changes from either on to off, or, off to on, you have found a break.
Feel. It will get warm as it heats up when powered. You can use a IR thermometer too.
And probably the most dangerous, but it works. Take fine steel wool, stray it so it resembles a 1 inch very fine brush. With the glass powered up lightly swab across (side to side not up and down) a long each glass strip one at a time. If you see a spark, thats a break. BE CAREFULL as I have had the steel wool actually burst into flames after it sparks. Dont cross over from one strip to the another either. _________________ aka Ken {o\!/o}
Bruce Samba Member
Posted: Fri Feb 04, 2011 1:35 pm Post subject: |
VOLKSWAGNUT wrote: |
Lightly trace across each strip with a test light near the power then ground sides, as well as across each strip. If you find an area where the test light quickly changes from either on to off, or, off to on, you have found a break. |
That doesn't work. Each strip is connected at each end. You can't isolate them to test them.
Feel. It will get warm as it heats up when powered. You can use a IR thermometer too. |
The amount of heat generated is so small, you'll never feel anything.
Trying to get a dead rear window defogger working is a POINTLESS effort. You can't bring back the dead!
If you want a rear window defogger, go to your local glass shop and see if they can get one for you, NEW! About 7-8 years ago, my buddy wanted his defogger to work in his 71, so he bought a new window from VW. Give them a try, they may still have them. _________________
Posted: Fri Feb 04, 2011 4:19 pm Post subject: |
The test light works. If there is a break in a leg it is essentialy an open circuit, and will change the light from either on or off or vice versa, depending if you have your test light clamp to power or ground. You can also test the voltage drop of each leg the same way.
You can feel the temeprature change. Not everyone has the same sensitivity, that's why I suggested the IR thermometer. It is a heater and does generate heat. It is best to start with a cool glass, and feel it on the inside, not the outside.
I repair grids all the time. So it is not pointless in my opinion. _________________ aka Ken {o\!/o}
Posted: Fri Feb 04, 2011 4:27 pm Post subject: |
So what do you do when you find a break to repair it? |
Posted: Fri Feb 04, 2011 4:33 pm Post subject: |
Depending on the type of grid there are a few inexpensive grid repairs available.
Here is a kit, but it is more than finding a good used VW defroster glass.
http://www.frostfighter.com/prt2700.htm
Cheapest way by far for most is to have a glass shop repair it for you, if you dont want to invest in a repair kit. _________________ aka Ken {o\!/o}
Bruce Samba Member
Posted: Fri Feb 04, 2011 8:30 pm Post subject: |
The test light works. If there is a break in a leg it is essentialy an open circuit, and will change the light from either on or off or vice versa, depending if you have your test light clamp to power or ground. You can also test the voltage drop of each leg the same way. |
You don't understand the basics of electricity.
The only way what you say can work is if you take a knife and cut all the traces at one end.
If you think the current is flowing through the grid line you are testing, you're wrong. It's going around through the other 7 lines. The only way to isolate one line is to cut it at one end. _________________
Posted: Sat Feb 05, 2011 6:34 am Post subject: |
I understand more than basic electrical testing. I agree the current will flow around a break on the remaining operational grid lines, but the voltage and ground are still still there on both sides of a break waiting for a path to ground to complete. The light gives it the path it needs. Grids are nothing more than parrallel wires. If you have a break in a leg you will have voltage on one side of the break and ground on the other. The light will change state after the break. The determining factor of the state of the lamp depends on where you have the clamp end of the test light positive or negative. _________________ aka Ken {o\!/o}
