Replacing high beam indicator bulb
Californio
Californio is offline
PostPosted: Mon Feb 07, 2011 1:15 pm    Post subject: Replacing high beam indicator bulb Reply with quote
Hi folks,
Anybody know what the high beam indicator bulb is supposed to be and how hard it is to replace?
The plastic is breaking up in my instrument cluster and I'm not sure whether to risk more or just live with the dead bulb. 1987 Syncro and the foil doesn't match Bentley so I'm thinking it will be hard to find if I mess something up.
Is this bulb a Radio Shack item or?
Timwhy
Timwhy is offline
PostPosted: Mon Feb 07, 2011 2:09 pm    Post subject: Reply with quote
Those indicator LEDs just pull straight out and yes you can get a replacement
from Radio Shack.
http://www.radioshack.com/search/index.jsp?kwCatId...T-1-3/4%20
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
erdonline
erdonline is offline
PostPosted: Mon Feb 07, 2011 2:46 pm    Post subject: high-beam bulb Reply with quote
The original high-beam indicator is an incandescent bulb with a blue sleeve over it. There were some other threads about replacing it with an LED, but as I recall, some had issues with them being too bright. When Vanagons were first made, there were no blue LEDs available, so they used an incandescent.
Ed
'85 Vanagon Westfalia
'84 Vanagon 7-passenger
'98 Mexican air-cooled Beetle
0to60in6min
0to60in6min is offline
PostPosted: Mon Feb 07, 2011 2:49 pm    Post subject: Reply with quote
thanks for the help ..
but a question .. why my original high-beam indicator is white flat on the top
btw the blue cover is missing too...
Californio
PostPosted: Mon Feb 07, 2011 4:38 pm    Post subject: Reply with quote
Hmm...Bentley (1991) already calls them LEDs and emphasizes polarity. Maybe they were already an upgrade at that point? Sounds like just getting the blue LED is the way to go. Thanks for the responses.
7thing3
7thing3 is offline
PostPosted: Mon Feb 07, 2011 4:46 pm    Post subject: Reply with quote
I would guess if you go with a LED you will have to hook it up with a resistor. LEDs like 2-3V. The original light is probably 12v. Maybe not. Also looks like you would have to mess with the wiring, etc., to get an LED in there.
'73 Thing--Ted
'77 Super Beetle Convertible
'87 Vanagon GL Syncro
'84 Mercedes 280 CE
Californio
PostPosted: Mon Feb 07, 2011 4:48 pm    Post subject: Reply with quote
yezbut...Bentley 90.18-19 clearly calls out LED's...??
crazyvwvanman
crazyvwvanman is offline
PostPosted: Mon Feb 07, 2011 5:11 pm    Post subject: Reply with quote
Look closer?
My Bentley page 90.18 says ...
K1 = bulb, high beam
K2 = LED, red, alternator
A BULB is spelled out for high beam, LEDs for the other lights.
The picture shows a small bulb in the K1 position and larger LEDs in the others.
Mark
Californio
PostPosted: Mon Feb 07, 2011 5:13 pm    Post subject: Reply with quote
yup, duh...
Pascal
Pascal is offline
PostPosted: Mon Feb 07, 2011 7:17 pm    Post subject: Reply with quote
I put a blue LED in and soldered a resistor in the positive LED lead, but it is still way too bright. I'll put the bulb back in Sad .
'84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby
