Who has ever broken an axle??
traviswx1
traviswx1 is offline
PostPosted: Mon Feb 14, 2011 4:21 pm    Post subject: Who has ever broken an axle?? Reply with quote
I am about to buy some used sway a way axles, the guy has two pairs, I only need one pair, and was thinking about getting extras. Do I really need them? Or should I go with just one pair. The axles are being sold on this site too. I am only running a stock 1600... I doubt I will break one... Any input helps..
69 Baja, 091, 2x3, cage, 1600dp, bj front, and a sh!t load of labor!
thesatelliteguy
thesatelliteguy is offline
PostPosted: Mon Feb 14, 2011 5:21 pm    Post subject: Reply with quote
Blow out a CV with a stock 1600, possibly.
Brake an axle....i really doubt it.
Toyotas are so bumpy it makes me sick, literally.
My build Page http://www.thesamba.com/vw/forum/viewtopic.php?t=383878
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Mon Feb 14, 2011 6:04 pm    Post subject: Reply with quote
Yes I broke and IRS axle in off road race car.
Have seen many over the years break in off road racing.
In a play car not that much of a chance unless they get nicks in them and are not taken care of.
Remember they made of torsion material and should be installed so they rotate the way they were installed new.
They twist and if installed backwards they will break.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
STOICH
STOICH is offline
PostPosted: Mon Feb 14, 2011 6:20 pm    Post subject: Reply with quote
i've broken a Sway-away axle... they replaced it at no charge because they said it was unheard of...
My classifieds
https://www.thesamba.com/vw/classifieds/search.php?username=stoich
jsturtlebuggy
PostPosted: Mon Feb 14, 2011 6:30 pm    Post subject: Reply with quote
I guess if you break them in racing you own both halves and they would sell you a new one.
Found it was always best to replace in pairs.
This was before having my own magnaflux setup.
Joseph
Elrod Motorsports
traviswx1
PostPosted: Mon Feb 14, 2011 8:02 pm    Post subject: Reply with quote
Thanks guys, just what I was loking for.
cmiller95
cmiller95 is offline
PostPosted: Mon Feb 14, 2011 8:36 pm    Post subject: Reply with quote
We bought a sand rail with every tooth in 2nd gone. A couple on 1st, 3rd, 4th, and reverse was toast. The passenger side axle was shattered too. I cant imagine how much power he had behind that thing.
Swing axle: Eating tires since 1938
My Rail Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=427627
My Baja Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466974
surewriting
surewriting is offline
PostPosted: Mon Feb 14, 2011 9:03 pm    Post subject: Reply with quote
Ive broken a swing-axle shaft before, with a 1600dp. Of course, I had 31X10.50s and I dropped the clutch (like an idiot) on asphalt, and POW! presto-magico, a snapped axle. When I jacked the car up to see what was wrong I was able to pull the whole wheel and drum still attached to the broken shaft.
So, yes, its possible, but pretty unlikely, as Im just one of those kind of folks who can break an anvil.
tripicana
tripicana is offline
PostPosted: Tue Feb 15, 2011 8:47 am    Post subject: Reply with quote
has the seller marked the direction of rotaion of prior use?
you might break an axle if you reverse the direction..
foam cowboy hats aren't good helmets.
joescoolcustoms
joescoolcustoms is offline
PostPosted: Tue Feb 15, 2011 1:10 pm    Post subject: Reply with quote
I have twisted a few spades off on stock axles and shattered CV's, but never broke a IRS stock axle.
I run SAW axles in my drag rail, hit it at 8000 rpm launch and carry the front wheels about 70 feet, but never broke a SAW axle.
UnKlear Racing TAT 2020
Bad News Racing 2018 NORRA 1000 3rd in class, 120/270 overall
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
quadrazer
quadrazer is offline
PostPosted: Tue Feb 15, 2011 2:38 pm    Post subject: Reply with quote
I've never broke an axle, and I'm running custom length axles in mine. I did however grenade a CV joint (or 2 or 3), and I should have took the entire axle/CV assembly out before I got towed off the dunes. Because when I got back to the pits and disassembled it, I found that the grenaded parts had tumbled around inside the boot while I was being towed in and had boogered up a few splines on the axle. Confused Took a while to get the splines straightened out. I need to get another set....just for backups. Live and learn I guess.
I DID wash my hands....the rest is 'built-in' dirt!
My build: http://www.thesamba.com/vw/forum/viewtopic.php?t=409845
SamT
SamT is offline
PostPosted: Tue Feb 15, 2011 4:47 pm    Post subject: Reply with quote
With a 1600 the direction of the axle wont even matter. I have thrown no telling how many axles on sandrails and never had any trouble, even some that ran slicks on the drag strip occasionally with a less than 120HP engine.
I occasionally break a VW axle with my 200HP VW and 16.50 comp cut paddles, maybe 1 every 2 years. Never had any trouble with a 150 HP engine.
